Home
Help
Search
Login
Register
Welcome,Guest. Please
login
or
register
Benches
giantkiller
(Moderator:
giantkiller
Simplicity
2025-03-28, 10:36:48
1 Hour
1 Day
1 Week
1 Month
Forever
Pages:
1
2
3
4
« previous
next »
Author
Topic: Simplicity (Read 28494 times)
Topic Options
View User Profile
Email
Show Posts by this user
Show Stats of this user
giantkiller
Re: Simplicity
Reply #75 on:
2024-08-01, 19:00:45 »
This is basic premise which non grounded OU must follow. Devices that have a ground connection are pulling electrons from there.
The non grounded must excite to ring then pick a spot along the ringing to attach to or buffer for a useful looping to occur.
Study the Armstrong and you will see whether a proclaimed OU device is worth your time. If you dont see an Armstrong then move on.
For instance does anyone see the Armstrong in the Witt device? I do. The looping is handled by the parallel proximity and the buffering is handled by the rpm limiting.
It wont work on a single axle because the field is not coupled to the driver. YOU CAN NOT MANAGE ENTROPY in a reasonable way. It cost too much in componentry and effort.
The Bedini motor(little school motor(its not his invention)) is a joule thief with mechanical buffering. Not sorry to burst egos.
Oscillate, pump, harvest are the only steps one needs. Any configuration needs buffering to get or limit to a usable current level.
The configuration is the mechanical output head which is the builder's choice.
So once the current or emp is seen then you have completed Oscillate and pump. Harvesting take control/buffering. HV diodes are a good start.
A simple OU start is to build an Armstrong oscillator with microwave transformers. This can be driven with joule thief. One might not see this on the internet because its such a great start that HV is no problem to get but to manage. I accept no liability for your efforts. You are basically building an arc welder but instead of shorting through metal connections you would want to buffer that explosion of energy after the pumping.
Each step has its experts and very detailed posting of builds and science behind it. Great nuggets for forward progress if one cares to stuff immeasurable diatribe into their brain bucket.
The quickest way is to accept the Armstrong model as a lens to look through. You'll find this adheres to non grounded devices. Now if you want to use a Kapanadze to drive an Armstrong then this will put you well ahead of where most get stuck but you will be forever be attached to ground. Iron wire cores are great to reduce eddy currents.
This excerpt here is the most complete description one will find explaining OU and not trigger TPTB.
Use a microwave oven circuit and replace the magnetron with a Tesla coil secondary. Immense amount of energy will exit. That emp will cause a suitable ringing for most to experiment with. I started out there after I told SM the TPU was driven by a stungun circuit (Armstrong with a charge pump) then moved to uwave xfrmrs. I eventually moved back to using/harvesting electric flyswatter ckts. Its cheaper, done and expendable.
There are a lot of categories of builds and circuits to use because all fall into the trap of their area of soapbox. If one doesnt see the Armstrong then make no further attempts as there will be no progress.
Self oscillation is the primary mover.
http://purco.qc.ca/ftp/
giantkiller
Re: Simplicity
Reply #76 on:
2024-08-07, 00:14:56 »
Just bounce a weak magnetic field in resonance.
The resonant frequency is dependent on 3 things:
1) The configuration of the head, i.e. material and shape.
2) The space/distance that the bounce is to occur in.
3) The relation of the space/distance to the field strength.
This is why Bedini, SM, and Mueller used cabinet magnets.
This is why Bedini stated Neodyniums were to strong.
Coral castle is based upon the distance as a major factor because the head was crystaline.
Don Smith's units were the distance of the spark gap to the resonant coil field.
If you see a spark gap then the field is being micro pressured/thumped(SM) from it resonant statis base.
If you want a unit with out a spark gap well good luck.
Only the EMP shakes the stability into ringing
Review the Witt device again to see the large field interaction with the commutator sparking inside. Sounds like a magnifying transmitter to me.
The comp wave generator does just this to expose the slight pressure return from the aether.
Funny thing I never get arguments for pointing out the obvious.
Just enough truth to not get disappeared.
View User Profile
Email
Allcanadian
Re: Simplicity
Reply #77 on:
2024-08-10, 03:29:49 »
It sounds easy, the only thing missing is all the relevant details between the the cause and the effect.
which is of course basically everything...
giantkiller
Re: Simplicity
Reply #78 on:
2024-08-14, 01:55:59 »
https://thedebrief.org/scientists-have-solved-this-anti-gravity-mystery-while-confirming-new-form-of-magnetic-levitation/
giantkiller
Re: Simplicity
Reply #79 on:
2024-09-09, 06:41:18 »
Since the magnetic field does not rotate with the rotating magnet(Maxwellian proof) then the magnetic moments are rotating with in the magnet. Are the moments aligning to the planet? If so then the planet is aligning to a greater external static force that does not modulate on the vertical/torus axis. That toroidal field must be the solar system to galaxy to universe.
Since the moments are rotating then there must be a frame drag between the moments and the molecular structure.
...but the molecular structure doesnt exhibit any change.
Pages:
1
2
3
4
« previous
next »
Home
Help
Search
Login
Register
