Thanks for you help guys, i shall need plenty more, not quiet ready for tuning yet WW but will need some help here soon, great idea with the scope, i would also need to divide by 8 as the magnets pass 8 times per rev or just multiply by 7.5 Wattsup i am using the same rotor diameter and magnet diameter as Romero and also same magnet and coil number and spacing. Rotor Magnets are 2cm by 1cm height south pole facing up. Rotor Diameter is 25cm using 1cm thick Perspex. Now something else i can confirm the added magnets are indeed all north facing up, and there needs to be only 1 big magnet on one selected coil, the reason is it biases the start position of the rotor, if i place magnets south up then the rotor starts in a position that does not allow a magnet near the rotor hall and hence you don't get any trigger at power on and don't get the rocking back and forward, but with the magnets north up and the bigger magnets on the correct coil pair the rotor rocks back and forward as both halls fire one after the other rocking the rotor back and forth. Mr Lenz still visits me with the magnets in position  still next i will roll the scope out and see what i have on the gen coils, i am all wired up so all gen coils are connected up, at the moment i have the cap after the switch, so when i switch on the load i also switch on the cap or to put it another way i have the cap across the load, i am using a 33000uF cap, dont have the 47000uF, i am wondering if i can get away with adding more caps in parallel to make up to 47000uF. When i get to work i will upload some pictures and 2 videos of it running.
« Last Edit: 2011-06-17, 09:34:43 by Peterae »
