Is this explainable from your hypothesis of operation?
I do say that SM was switching things all the time to keep the mystery a float. It could be that UEC was driving the boat at the time too.
I use mine as the Tesla coil primary. This propels a high speed emp into the already resonant outer twin lead. Which in turn sends that shock wave around the ring. If there are two then that substantiates drawing current off it. The other test I did was to use that as a tickler into a 'q circuit'.
So the 'Q circuit fits into the ResonantCoupler block drawing,
which makes this look very much like the one wire cannons that Wattsup showed. Only larger. In the shape of my avatar.
A circular Tesla coil. Match the forward triggering primary with the previous finishing revolution.
It is at this point I cease to connect the blocks ever further. This turns on the device and I want to take extreme precautions. What controls are really in place to prevent run away? We all can talk about that. But I dont feel particularly safe with this next step having seen what the smaller coils do. Why should the larger platform be any different? I have connected these larger building blocks together in sub fashion in case I want to run this up the wall. This is nothing more than a Tesla coil with a pre-resonant secondary that is powered in addition to receiving EMPs from the primary. And this design eliminates the high level of specification demand on the physical build. Maybe the physical specs we see from the images have already solved that. The circular nature of the build is also a feedback loop. This also creates its own reflections so to speak by using the secondaries at each end to simulate a reflection to each other. Heterodyning. Sounds like a rogue wave to me.
With two primaries the secondary can be driven from both ends to set an impact at 180 degrees out. This squeezing of the resonant field of the secondary makes it also like the Kunel patent.
When you say you went from audio drive to natural resonance what do you mean by natural?
The coil has a natural resonant frequency. Adding a cap we can change that up and down the scale. Thanks for catching that. I didnt finish my thoughts.
You said operation between heat and power output is a function of thumping frequency. Can you clarify?
The thumping is either the reverberation due to reflection or the emp through the device.
Also that "90 degree coupling between iron wire and the lamp wire is the diode". I almost get it but a little more explanation would help.
Easy. When you run current through the lamp wire the 90 degree iron wire sees the inductive connection. No different than a core. When you run current through the iron wire the 90 degree lamp wire does not see the activity. Many educated thought I was trying to rewrite the laws of physics. I had the last laugh on that one as I am sure SM did too. Otto showed the one wire configuration that boosted the whole OU scenario.
You are a gifted writer, have you ever considered putting this saga into a complete document, instead of bits and pieces cast on many disconnected threads?
I did. It is on amazon. Savant by Paul Moore. There are many other books named Savant. At the time Israel was not surrounded by her enemies like it is now so I thought at the time there would be more for time for disclosure. The story is wrapped around clues in a coffee shop where the main character hides out and screws with the public. From the readers that have read it seems very plausible scheme of what could possibly be happening today. The ultimate unstoppable criminal.
Of course some are still shouting "reed switch" without thinking deeper about the whole picture.
Actually it is like a reed switch only we are talking core biasing. But the mechanical people don't see this. That is why the term 'Energy from the vacuum' sounds like hocus pocus to so many. I love a good twist. It keeps the game a foot.
And actually the postings all over the threads are a self protection scheme. Other wise I would have to act crazy like Dollard, Hutchison, and Manson. Crazy is their game and they play it well. I ain't caught so I can run it different.
Now if and when the TPU specifications are published by some poor unwitting prairie dog, they will take the fall but the design will fly immediately around the world and the facts of operation and design will be known from whom and what was posted. I have posted enough to make the whole thing simple and open source, meaning it can simply be built by any one. I know a few kids in Africa that will topple regimes with this. I plan on building wells in3rd world countries that are self contained and self running, like no pump handle. But this is an action item for a longer time frame. Through the grand management use of time the builder crowd has amassed as a large unstoppable force. The only thing the authorities could do to stop it is make ownership of copper illegal. I see a huge market spike in the world wide iron commodity.
It is based on controlled, channeled destructive power reflections. That is: it can not be grounded. Look at the charge pump(middle) stage of the stung gun or Tesla circuit. It floats.
The only tight specification is the resonant charge, the synchronized triggering, the reflections. This needs component values. I like SM's 'No' when I mentioned a 20 foot circumferal loop. While the world heard 'That will get you busted, but I heard 'That, my friend, is a better specification', as in lower frequencies. The impetus is to acquire transmission reflections. 'Just like a radio.' like SM stated.
Here are reference pictures. The long wire pair with the cap on the end is one Mannix sent me privately. He is probably passed away by now so no harm, no foul.The Q multiplier has TPU written in it all over the place. Tickler feedback included.
Everybody cries for a circuit. Well here you go, staring the viewer right in the face. It even has the hidden mysterious 9 volt battery there too. I built that on the 17"LTPU. It became an essential tool for tuning. Looks like this little circuit simplifies and answers alot of needs from the community.
Well it looks like the whole package right here, no? For prosperity's sake.
