Hi ION, PM ION I will get back to you on your question, I want to get PM hopefully in the same area that I am with the changing of inductance in charge and discharge using only a switch (mosfet). PM, you need to measure the individual inductance of each coil, then measure the inductance of the coils in series. I presume you have wound the L1 and L2 as I have said, L2 is 3 turns of insulated iron wire (+- 17cm dia: coil), L1 is a copper wire wound around the L2 like a toroid using L2 as the core. Don't make too many turns, about 20% of the circumference or less and make it so you can move it by sliding around the L2 (not too tight). Your idea of measuring the drain resonant frequency is good, but you need to put a cap across the source and drain and measure the capacitance. The combined series inductance of L1 and L2 is not a straight addition, it is a lot more as they are basically two coils in series on a magnetic core and not air coils (that is if you wound them like I have said). The other thing is to do circuit 1 and test, then change the connections and do to circuit 2, all at the same settings and see the difference. Back later, getting very hot here, reached 35ºc yesterday. Great work PM Regards Mike
