2025-04-01, 01:08:10
Pages: 1 ... 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18]
Author Topic: The final answer...  (Read 145642 times)
Center Toriod
Probable field definition of the Hutchison effect:
https://rumble.com/v4buxm9-february-6-2024.html
A very tight resonant bandwidth:
https://rumble.com/v4bvrwr-h-field-modulation.html
Probes:
https://www.aliexpress.us/item/3256805420265954.html?spm=a2g0o.order_list.order_list_main.23.4d0c1802cd4ehW&gatewayAdapt=glo2usa
https://www.amazon.com/SaiDian-9KHz-3GHz-Antenna-Conducted-Radiation/dp/B097YCVCTX/ref=pd_bxgy_d_sccl_2/136-1061201-5820906?pd_rd_w=QxrQ7&content-id=amzn1.sym.839d7715-b862-4989-8f65-c6f9502d15f9&pf_rd_p=839d7715-b862-4989-8f65-c6f9502d15f9&pf_rd_r=PQF76PE0AK2MED7WKDY0&pd_rd_wg=vfINt&pd_rd_r=3d58bcf9-8093-4630-8d54-ab7f1fad834b&pd_rd_i=B097YCVCTX&psc=1
The keynote take away is this H field modulation can only be seen a few points off resonance and a slight sweep range.
I do believe this breaking new ground.
So when one has a device that worked temporarily then they stumbled upon this protocol.
It remains a mystery because of the lack of H probe.
« Last Edit: 2024-02-07, 17:16:26 by giantkiller »
GK
The effects seem pretty easy to understand.
For example, years ago I thought doctors, ie. surgery for cancer, were primitive and barbaric and I still do. Rather than cut people open like animals why not converge multiple beams of energy like IR lasers on a point to destroy the cancer inside the body. Then 10 years later I heard someone actually figured it out and a friend with cancer near his brain was healed using this new technology.
The process is simple, no one beam of energy has enough power to disturb the material it moves through but where all the beams of energy converge it can. Obviously this is not induction nor should it be confused with induction. Were transporting EM energy to a point within a material which then dissipates and radiates energy outward from said point.
It should also become obvious that the point where the energy converges appears as the source of energy and not all the lower energy sources which combined to produced it. At which point the notion of an external action producing an equal and opposite external reaction becomes a mute point. The reaction is now internal and could take any number of forms. Ergo, many cold IR beams converging on a point dissipating and transforming the energy as heat.
The target make up, convergence, harmonics, direction, angle and power levels(equal or mismatched(importante!)) all play an important part in manipulating the target.
Somewhere deep, the specifications of the incoming parameters and the target molecular structure are documented.
We on the outside have to explore to find the parameters and material synchronization protocols.
The turtle wins the race.
Remember SM stated just off the mark. O0
If one is aiming for power from the start then that will blow up equipment. These are due to temporary excitation windows.
These are vectoring alignments without control.
This is what we are not told about the Hutchison effect.
« Last Edit: 2024-02-07, 21:38:42 by giantkiller »
Its to have an isolated power coupling for the becon lights on large antennas as to not have an electrical bond to other systems.
It's a high voltage (insulated) mains transformer with low capacitive coupling, for exactly what you said. Learning something new every day.
The RF energy is coupled to the tower/antenna in AM radio with a ring transformer. I call that spooky RF. I worked on an antenna once that was in a four tower directional array. We shut down all of the antennas except the main. At that point, we went circular instead of directional. As I was working on the tower, it would absorb the energy of the main tower and would burn me at peek amplitudes. Ouch !!
https://www.youtube.com/watch?v=wGDZK1Ifq50&t=2s
« Last Edit: 2024-03-10, 17:45:56 by giantkiller »
https://blog.teledynelecroy.com/2018/08/the-causes-of-ground-bounce-and-how-to.html
In reading this article I saw there are many references to particulars in the TPU build and operation.
Lamp wire creates the multiple pathway problem.
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-04-01, 01:08:10
