GiantKiller, the thing that cinched it for me was matching Eric Dollard's versor mathematics on parametric variation and transmission lines with your comment ' Transmission line reflections are the same as magnetic fields reconstructing after being broken.' I suddenly saw the entire Kunel patent inside a single length of wire.  To synthesize energy: Discharge a coil while its inductance is falling or a capacitor while its capacitance is falling. Energy seeks balance and both create a situation where V approaches infinity. Since EMF results from dV/dT, this can net a larger kick than what you had to put into it. It's like squeezing on a water balloon while water is shooting out.In-phase, this harmonic relationship is also equivalent to pushing someone on a swing since magnetic fields are additive and conserved. From a different perspective, it mimics what occurs in a regular combustion engine. First the medium is compressed (air), then injecting and catalyzing fuel creates an expanding wave of exhaust gasses. This reaction would be pitiful in open-air, but since it happens in a region of high compression the reaction goes critical and instantly combusts with a powerful force that slams at the piston. From another perspective, consider that things like gravity and magnetism are 'free' forces. There is no 'gravity generator' at the center of the earth making gravity work, and there is no internal generator keeping a permanent magnet magnetized. If you stick a magnet to the fridge, it will be putting 1lb of force against the fridge, effectively forever. 1lb constant force times eternity equals how much energy now? The only problem is gating and harnessing this source of energy. The Kunel patent provides a way to switch the density of objects influenced by this constant magnetic force up and down. This is a non-linear reaction and if the switching circuit and extraction circuits are efficient enough, it'll get the job done. Kunel patent, except that switching the field in air is much easier (and faster) than in the core. Flip it faster than the core can react and recycle everything you can. Consider the above while reading SM, Don Smith, Floyd 'Sparky' Sweet and Eric Dollard's writings and other posters here and maybe it will click for others too?  Of course, everything I'm posting is armchair theory as I haven't had a chance to properly test these ideas (except the Iron wire thing), so take my words with grains of salt. But the math and concepts are solid and consistent. PS: Ferromagnetic wire is amazing to work with but please shield yourself. Of course you'll probably figure this out on your own once you've wound your first headache generator.
