2025-03-31, 21:20:49
Pages: 1 2 3 [4]
Author Topic: Companion wave generator  (Read 30328 times)
I will get them to make a video and post it. Sadly, it wasn't me, but unless I've been taken for a fool, it looked real enough on the scope. (via skype)
Sorry for the interruption, I'll see if I can get a video for you guys.
@bte, i also have a nmr video on youtube. Its on my our bench. I'll find it.
[youtube]http://www.youtube.com/watch?feature=player_embedded&v=tZf0yhe4B80#at=1577[/youtube]
The TPU had foam or cork as a dielectric layer with high voltage potential circuit. This explains why SM stated they are so simple and a new type of induction. The atomic alignment and subsequent spin occurred in the dielectric layer. The middle loop is the collector. The outer coil created a bias to feed the engine. This is starting to look like Keely and his explanation of atomic vortexes.
So the TPU is looking like a very large capacitor.
What is interesting about Stan Meyer is he created a capacitor and between the 2 plates used water as a free flowing plasma source. As it became light is was replaced with a denser medium, water. Interesting recycling loop or charge pump.
« Last Edit: 2013-07-13, 03:31:33 by giantkiller »
I never did see a definitive diagram for the flat SM TPU, do you have a drawing that shows the windings and connections that spherics described?
I have posted all I have from Spherics
« Last Edit: 2013-07-23, 04:12:15 by giantkiller »
http://www.overunityresearch.com/index.php?topic=1526.msg32947#msg32947
To cause precession, all you need is two orthogonal forces, and motion/translation of one of these forces.
« Last Edit: 2013-07-26, 19:50:45 by giantkiller »
Bench expanded. Configuration set up.
Its all about effecting a bias. Mechanically, chemically, radioactively, magnetically. Its all the same no matter what the time frame.
 I am still in tpu land. Look at patent 5568005 in 1996. Tpu inards. You'll see my lastest build has similiarites. 2 tesla coils, external excitation. Magnacoaster and Hutchison both did this also.
Sorry about the poor quality. I was just focused on getting the runtime operation captured and my setup takes up the whole 6 foot bench.
[youtube]http://www.youtube.com/watch?v=8s5eezGnSgg&feature=youtu.be[/youtube]
« Last Edit: 2013-09-05, 04:58:07 by giantkiller »
Thanks for the video and  your substantial  effort getting all this together. Maybe as a control, you could replace all the coils with equivalent impedance resistors, just to see if your coils might be interfering with the power supply. Those large meters on the EC-600 are plastic and radio waves can go right through and into the pc board behind them and wreak havoc with the control circuitry.
I have an EC 600 and a few others and note also that they are not designed for fast transient recovery like a standard bench supply. They definitely have a long time constant, which may contribute to the bouncing you are seeing.
Carry on the good fight!
I have another one. This was pointed out by Jason. In the video you can see the meters pulsating. They are pulsating in synchronization with the crickets or vice versa.
I assure that this is not a scam or setup. It is a true anomaly. I always wondered how crickets, even for miles up and down the Potomac river, could stay in synchronization. Could it be an ELF scalar wave, like a tide, moving to and fro?
[youtube]http://www.youtube.com/watch?feature=player_embedded&v=8s5eezGnSgg[/youtube]
Any old heads remember this? Transmission reflections...
 http://www.overunityresearch.com/index.php?topic=3658.msg69724#msg69724
My 2 cent and no domineering: http://www.overunityresearch.com/index.php?topic=834.0
I just tried to reproduce this with Jason's SSRB boards, my two signal generators and a new rigol ds1054. Should have worked.
Alas I could not and dont know why. Could be my ignorance. Been known to happen.
I did not use Jason's controller that I built and tested with him. But with reproduction of the input parameters using sig gennys should have been easy peasy. Twas not.
I said Hmmm. I didnt want to go down setting up such a large peripheral reproduction in installing more software on the next pc. I could still do that tho. The bucket list is a fast moving train gathering new cars every day and I am at the wrong station. I had to switch tracks again and shelved any further attempts.
I hope enough read this as this is the coup de grace moment:
That secondary additive pulse arrives from a reflection to a SWR returning to the source. My other latest attempts have spelled this out.
Clue: You have to get out of the way of the return. Check the parameters in the posted thread.
When that returning pulse is in phase with the next transmission we get additive power. And that is what you are seeing. Think power line reflections.
Now position that SWR at a particular point in a ring configuration and one gets a huge additive, reflective, resonant peak.
The tester will see the grand results in their tools. I added LEDS to the sinks on the outside edge of the resonant fields and they lit very brightly(I cant remember the guys name about the two counter LEDS on a radiant probe.) No more videos from me as the last tests have become very obvious. I blew LEDS in the resonant field. I had to stack LEDS like in the stun gun charge pump stage. Again I took the stun gun circuit and inserted large resonant loops in the charge pump stage. I was chasing the attempt to build this pump greater. Operation was at 9Mhz just to compensate for the loop size. SM told me not to do this by an airport. The output inductor primary field impacts the input inductor secondary creating an in air feedback loop. I state this because when the tester gets the SWR and resonant down pat then they will want to connect differing loads to the testing circuit. And play by moving the SWR peak around the loop.
I hope this fits in with what this thread is trying to achieve and Merry Christmas.
« Last Edit: 2018-09-17, 07:10:43 by giantkiller »
Thanks for reminding me about the "companion wave". I read about it some years ago then I forgot it. Even though the bases are very fragile, both theoretically (Bibhas De is considering only empty space with no charge sources, Rho = 0, J = 0) and experimentally (crossed field antennae do not support his theory, they are just shortened antennae radiating classically with only a bit better efficiency due to the radiation of both magnetic and electric fields from the near zone), his way of thinking is interesting. I'll take a look at it again.
F6FLT:
Have you completed your second look at this topic? Just wondering what your findings were.
F6FLT:
Hi Ion,
This was my last look:
The "companion wave" is a momentum wave. It can be detected only by the mechanical force exerted onto an antenna mounted on a piezoelectric sensor. There is no possibility of direct electric measurement of the source. See §4 http://www.bibhasde.com/veipaper.pdf
The paper dating 1993, I'm afraid the author failed in realizing himself the experiment.
In this paper, Bibhas De calculated a force of 0.1N on an antenna in the Earth's magnetic field subjected to an EM flux of 1W/m². This is a very strong force that cannot remain unnoticed when using KW and a stronger magnetic field. The effects of momentum of an electromagnetic wave have been investigated, particularly for space propulsion, and they are considerably smaller.
There is no convincing experiment to support his theory.
The companion wave is a micro reflection. Nothing new, just another way to achieve the echo.
https://www.youtube.com/watch?app=desktop&v=5E6QyAhTB3o
They are trying to explain the vertical transition of a square pulse. That speed is what they need so its not impossible.
The goal is to counterbalance the Q squared term charge. He mentioned hitting a stable magnetic field with a pulse to get the coulombs up.
Pais is explaining the destabilization of the toroid field but he thinks one needs high energy in a plasma field. It sounds like they are disregarding reflections.
Laviolette explains high power is not necessary with square waves because the edge harmonics are microwave and higher.
« Last Edit: 2022-11-14, 06:08:59 by giantkiller »
GK,
Thank you very much for this video link!  Anyone interested in FE should watch this interview with Pais!
Freecad has Finite Element Analysis. Flux fields can be analyzed.
https://wiki.freecadweb.org/FEM_EquationFlux
https://wiki.freecadweb.org/FEM_Workbench
The ECD is a magnifying transmitter for the companion wave.
Pages: 1 2 3 [4]
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-03-31, 21:20:49
