2025-04-19, 18:40:37
Author Topic: W.K.Coombs Hitchhikers guide To Gravity And beyond...........  (Read 3335 times)
This Is for all my Friends Here [and I mean that]
http://www.overunity.com/index.php?topic=10661.msg283023#msg283023
Mr.Coombs has a working  running concept he will be sharing the "How its Done"!
Right here!!
No secrets Open Source
More to follow.
Mr.Coombs,
Quote:
iT'S GOING TO BE A RIDE
Ok where do we start.... I know as a kid .... now I think everybody in the world has spun a string with a weight on the end.... remember.
You would make a twirling motion to get it started then you would just move it back and forth and it would still spin, You would feel a tug at end of each movement on the shift back and forth, ?
centrifugal force correct ? But it keep spinning .........now we are going to apply that part in conjunction with gravity
Ah! gravity the force that wants whatever is not already backed up to a solid and wants to get there ...
Ah! now we take a pendulum  natures perfect way to have weight climb.....
from a gravity drop point ....But we all know that it diminishes on each swing RIGHT....they all say friction is the problem very few say centrifugal force ,,, remember that tug at the end of the string shift ?
OK so here is a list of materials you are going to need..
a base 2x4 will do maybe 12 inches long
a riser to attach a pendulum too
a pendulum
a weight attached to the pendulum
a way of limiting the movement of the base ( see dia )
a couple rollers for under the base
NOW LOOK AT THE DIAGRAM CAN YOU COME UP WITH THESE ITEMS
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-04-19, 18:40:37
