2025-05-13, 10:09:56
Author Topic: Beware the World (Affect) and you (Effect)  (Read 4231 times)
Everything is Cause & Effect.
Everything you are and do can be analyzed with a Physics perspective and methods.
What happens when you analyze this 'experiment' incorrectly?
In the blink of an eye, or a week after a huge earthquake hits the other half of the world, you could be 'realigned', demoted or unemployed.
I have been 'realigned' (not sure what that means).  I'm hoping nothing changes with my hobbies and side interests. I just don't know, right now.
Good Luck!
Sorry to hear that Wave hope it all works out OK for you. GOOD LUCK  O0
Could you elaborate a little as to what this 'realignment' was for you WW?
WW,
I hope you find time to finish the GWave project. If it turns out that it is possible to use the
data from this project to get a better understanding of earth quakes and maybe improve
the early warning time for earth quakes, then I think it is important to continue on this project.
If you feel that you can not continue on this project, then please mail me what you have
of source code right now and I will buy a compiler and continue with the research.
GL.
I am in a service field which attacks any problem where the customer, equipment supplier/designer and field specialists fail to find a solution. The areas covered range from small machinery to power plants. Solutions are found for single-point to system wide. We are not limited to a particular technology. The new limit is where highly specialized or exotic materials are in short supply.
This is the case now. Certain devices can't be produced from the single supplier in Japan. Immediate and sweeping cut-backs have been implemented. I am one of the few lucky ones. I still have a paycheck but am preparing for worse.
The GWave project is my highest priority for my free time. The change I'm faced with is dropping from R+D back to traveling problem solver.
Don't believe much of the news from Japan. US bases are being evacuated and US ships, unable to move under their own power, are being towed to Guam and Hawaii.
We expect to be utilized if the military throws in the towel. For now, the bottom line rules.
Sorry, it is yet another one of those moments where you must choose what to believe.
Good Luck!
It's happening to all of us.  You are one of the fortunate
ones to properly interpret the subtle (or not so subtle)
changes either internal or intimately external.
You are experiencing an "awareness conditioning" so
that you may "see" more clearly the path you should
follow.
Count yourself "lucky."  Do not be resentful.  Show
loving kindness to all, especially those who are difficult.
There is more to come...  We are all being "changed."
Dumped,
I know that is all true but I'm taking a more technical and and less philosophical approach  >:-)
Dumped,
For now that is fine.  You're being prepared for the
turmoil which is just ahead.
It's going to be a very bumpy ride.
WW
Trying times ,to say the least!
On another note,I suppose its all perspective?
"WE",[those of us with computers and internet] live in a completely different world than the other 5 billion or so.
Most of whom worry more about a roof over their head,a meal , clean water,etc............................
And if they could spend a day in our shoes...
They'd think they died and went to heaven.
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-05-13, 10:09:56
