As current probes might be just as susceptible to "influence" by the experiment, I have yet another option for you to consider WW:
Make the induction loop, a second measurement loop. Or put another way, change from two resistors to one, and make it a 1k value. So we have a wire loop that goes 357º around the solenoid, and the loop is loaded with a single 1k resistor (which makes up the last 3º of rotation). This second measurement loop does the integration essentially around the entire solenoid, giving us a pretty accurate reading of the induced emf.
Now, after we note what the total induced emf is by this method, we introduce our two decoupled leads once again across any two random points on the loop and observe if the emf value measured by the "second measurement loop" as described above has changed any appreciable amount.
If there is little or no change, then can we say that the decoupled measurement method is valid, i.e. non-intrusive to the experiment?
