From Stefan at OU
Hi all, I received this message from Isamel:
Hi, to all
My own technical view to open the free energy window;
1st. Low impedance load (To radiate enough Bemf or creating dominant freq or creating a carrier freq. to reach the Higher freq to attract surounding energy ) Using High resistance load will kill the effect. Most designer based from the advantage & convenience of High impedance design..like Bedini, Newman, Hector RV, & many more , but they forget Tesla always use very very low impedance & short it to the capacitor to create a very powerful vibration or oscillation.
2nd Circulating voltage inside the system minimum of 5 KV ( the more higher voltage the lesser grip of Lenz law )
3rd. Circulating freq. above 700Mhz ( If you gain 10watts at 1 Hz or one shorting pulse/sec, why not make it 1 million shorting per second ? using same input )
Shorting will be the main process to manipulate the above 3 basic requirement. The more shorting the more free energy you can get. Unlimited extraction of free energy. Totally depend on the budget. The more extraction of energy, the more overheating of parts, the more R & D cost required for parts development alone to withstand the saturation of destructive spikes. I considered Kone is the master of shorting in a low freq. process.
As per latest survey, based from Keelynet.com info. 20 trillion dollars burned just to extract free energy with substantial work , but so far no valid result, I think my technology will be excluding n the statistic survey. I am now very very near to the reality of real application , We hope everybody can benefit. Still a lot to do & more need funding for R & D.
A lot asking How about the Parallel flynn technology using P. magnet? For me It's a free energy, but limited up to 20 Hz only. Push beyond the 20hz the P. magnet power start to be depleted or no gain at all. The sterling engine & P. magnet with similarity. Hard to apply into real application. Like PM , Sterling was so slow to react to the require application to contineosly extract free energy.
Update : re : Government testing of my technology MIGHT be next week. using the same DC motor power by conventional power supply or battery & compare the output work power by my own technology. I requested this since last year DEC 2010, with a little help of push from some of friends in the Government & Media.
I will keep you update re: the testing,
BTw, As per the producer info I recieved yesterday, I think tomorrow or Tuesday my TV interview with Chn 7 ( biggest TV network in the Phill.) will be air including the footage meeting with technical evaluation council created by the Government specially for my energy.
Is
« Last Edit: 2011-02-21, 01:59:32 by ramset »
