There was a good post in this thread about stressing components right up close to their maximum thresholds with reversed biases. Transistors as I recall.
You may be interested to know that Wilbert Smiths tool for measuring the background fields tension level, was an arm with a fishing line pulled to almost break on one side and a steel guitar string on the other side. The two were tensioned to balance the arm such that the tension on the fishing line was just below it's breaking point.
As Wilbert traveled to places where military jets had fallen apart during stressing them, he was able to measure a deflection in the arm, as the holding force or tension between atoms was reduced. He was able to correlate these effects with locations on the earth opposite were nukes had been tested. The "boys topside" had given him a way to show that nukes were a very bad idea for the planet. This was during his "Project Magnet" travels.
When you stress a component towards its breaking point of tension, it produces vibration responses at the molecular level. These vibration frequencies may or may not add energy to the EM wave if they are geometrically additive, that is if they land in quadrature to the E and M fields at correct frequencies.
One of my experiments with earth currents, I had a ground rod centered in an earth grid node, and using an RF diode was able to obtain a reversed bias positive charge across the diode. Blew my mind because the diode should not have been conducting in that direction or maintaining that voltage without shorting out in the other direction.
Anyway the earth grid puts out a vibration frequency of 135 khz but has a positive charge on it at the surface of the earths crust. All around the grid point will be negative charge. If the diode had charged up from RF, it would have been biased the other direction.
All fields that create a stress on a material will vibrate at frequencies we may not be able to identify with our EM gear. This is then leading directly into the scalar cancelling coils, and mass vibration systems, which manipulate the atoms at the nuclear level.
Using a heavy Bismuth core, the coils vibration can be felt, and a lot of these people of past times with little or no theoretical knowledge as we have today were creating systems of FE. What do you think they could feel to hit these points of mass vibration resonance?
"Tweakers" have been doing this for a long time and having success. Me included ...
Far as I know this had never been quantified before I started discovering ways to measure it.
"Space/Time" or "Quantum Field" discussions may seem to offer little, and as we see ones calling it mumbo jumbo. Until you begin to feel it, and tune it in, it could never make sense.
Space/Time was proven in the GPS systems of our planet several years back, and the calculations worked.
The fact that we can operate on the field density of space and change it's light velocity has never been fully investigated by conventional science.
When the Michaelson Morley apparatus was turned vertical, it began to work! It measured the gravity gradient. That is light velocity traveling parallel to the earth surface has one light velocity, but traveling vertical to the earth has a different or changing light velocity, and the apparatus was sensitive enough to measure that within only a few feet!
It is interesting how two people can discover something like this, showing a device that works, and no one of advanced learning has any interest in understanding it! It takes time for all the different branches of science to get on the same page, and so many now that find things are ignored.
Electronics people are never taught the physics of the atom. If they want to understand the next layer of matter down, they will have to dig, but it is all there in the other branches of science waiting to be used in practical ways. --------------------------------------------
Required is a change of the belief system from direct experiments that prove to one self the qualities of the Quantum Field Fabric first hand. The Tempic field that creates motion, is manipulated using mass resonance effects, and the Quadrature model of the three field forces. Motion always is found at 90 degrees to the Electric and Magnetic vectors of force. This is right out of the practical theory of motors.
When we apply that to opposing coils, scalar cancelling coils, we begin to get real answers. This is because the Quantum Field Fabric has the same design. We can raise up vibration fields from it that are geometrically perfect, and will then self power until we take them down.
Mass vibration is the key to FE, and whether tweakers can explain that as a working theory with calculation or not it works.
I spent a major portion of my life trying to explain to myself why my tweak worked, powering a 100 watt light bulb, when the AC cord was removed from the wall. At present I am about 1/2 way through the vibrational part of all this. No one was ever able to duplicate it, but for Floyd Sweet who did it first and left us a print with turns ratios and the statement that it took at least 100 watts to get it up and working.
I then became a believer in many of the things I had never been educated on, which I am now a lot more fluent with. The physics part.
Wilbert Smiths definition of the 3 field forces open the first door to understanding that we can in fact change the qualities of space using Tempic field modulations at very specific frequencies. ---------------------------------------------
Todays challenge - It is easier to get a sensitive person who can "feel" vibration resonance to open to measuring fractals of it's frequency and using a little science to calculate amplification, then to get a super educated person with all the intellect to start opening to "feel" something.
The greatest advance for me was when we got both of these expert kind of people together. The scientists began to feel, and the sensitives became interested in calculation. Now they can exchange frequencies they find, and share them. As this kind of technology is interactive with the body, it becomes an experience as much as a calculation of energy.
Dave L
