Here are a few pictures of the temporary lab I set up for testing Lawrence Tesung's Joule Thief circuit. Scope shots of the circuits to follow shortly.
Dear Poynt99, Have you received my components package via the Post Office Mail yet? It should be in a hard paper envelop. Please let me know as soon as you get it. The expected time was “within 7 – 10 days”. As I mentioned, you need to supply your own breadboard, the battery holder and the AA battery. Otherwise, the components should be ready to be assembled. I am not surprised that your LT-JT is way under unity. As I stated multiple times before, FLEET is a pseudo resonance device. It appears that your LT-JT is nothing near that condition. Please use the components I supplied to build your second LT-JT on a breadboard. It does not matter if the wires are too long. TK showed the change in waveform with long wires. In your case, you want to use the long wires as a tuning parameter to get the best COP value. With the breadboard, you can easily change the waveforms by changing the holes used. That is another important tuning parameter. You can remove the JT LED for testing easily. When you have two prototypes to compare, the fun begins. @PhysicsProf, glad to see that you are back. When you have your new DSO, please post some of your photos and screen shots. Use Mean Power Value for display. (You can optionally display the RMS for comparison purposes). You have an advantage over Poynt99 because you have a few prototypes with Tseung FLEET Comparison Index greater than 1 already. @All, Poynt99 showed clearly that NOT every build can show COP > 1. Most people who worked with JT thought that they achieved success when they see the lights on. The basic JT is a very tolerant circuit. It will light the LEDs with very wide range of values. FLEET is different. The COP > 1 results will require much tuning. The second build by Poynt99 using the components I supplied will be much closer to the required pseudo resonance condition. On the breadboard with long wires, some tuning can be done. Thank you for your postings and comments. There is much fun ahead.
