2024-11-26, 15:21:35
Author Topic: Inertia Propulsion  (Read 4582 times)
Inertia Propulsion
One of the experiments before we built the Tong Wheel was that of Inertia Propulsion.
With normal rocket type propulsion in outer space, we need to send gases out at high velocity to provide the propulsion force.  Thus a large amount of fuel is needed to accelerate, decelerate or to make turns.
The question is:
Is it possible to provide the propulsion force without ejecting any gas out?  If so, is it possible to greatly reduce the fuel required or even eliminate the use of fuel all together?
The answer is surprisingly simple – YES.  The proof of concept experiments was done with the help of Mr. Tong Po Chi in 2009.  Please read the English description as many of the explanations are in Chinese.
Flying Saucer Experiment 2 – horizontal
http://www.youtube.com/watch?v=-TfwKBdmRao
Flying Saucer Experiment 1 – vertical
http://www.youtube.com/watch?v=SA5ObshvNx0
Tong Po Chi Device with no top
http://www.youtube.com/watch?v=FafYVGbgULw
Experiment 1 – Generating unbalanced force from within
http://www.youtube.com/watch?v=JCHOkR-S800
Experiment 2a
http://www.youtube.com/watch?v=TRO_F7sVGcg
Experiment 2b
http://www.youtube.com/watch?v=Q5EmV4TSiYE
Experiment 2c
http://www.youtube.com/watch?v=JcOyMtylw_A
Experiment 3
http://www.youtube.com/watch?v=oSSSiEj_6S8
Experiment 4a
http://www.youtube.com/watch?v=EkaIaKzaQ48
Experiment 4b
http://www.youtube.com/watch?v=n_QXr0U_Xgg
Experiment 4c
http://www.youtube.com/watch?v=bGqx191RjQI
Experiment 5
http://www.youtube.com/watch?v=FCz1Byt7fVI
Experiment 6
http://www.youtube.com/watch?v=Lh0aL69Wu9g
Experiment 7
http://www.youtube.com/watch?v=UVghe2gWPfo
Experiment 8a
http://www.youtube.com/watch?v=EwmOPb38meQ
Experiment 8b
http://www.youtube.com/watch?v=U4bNDDP3d1k&NR=1
Experiment 8c
http://www.youtube.com/watch?v=jJ-e0OcGT_c
Experiment 9 – attraction
http://www.youtube.com/watch?v=BUiyE_p6BRQ
Experiment 9 – repulsion
http://www.youtube.com/watch?v=CrJXH-MFBTA
The secret behind the Flying Saucer
If we can lead-out or bring-in virtually inexhaustible energy in space and that we do not need to eject gases out to provide the propulsion force, does it mean that we can design the much controversial UFO or Flying Saucer?
The answer is YES.
The normal airplane uses aerodynamic forces to make turns and to provide lift.  It cannot function in outer space.
What happens if all maneuvering is done via engine power?  To make turns, a propulsion force at right angles to motion is applied.  This centripetal force will force a sharp turn.  Viewed from a distance, the Flying Saucer would appear to reverse direction (180 degree turn) without slowing down or stopping.
If the propulsion force is upwards against gravity, the Flying Saucer will appear to hover without ejecting any gases or using any rotors.
Such a Flying Saucer will wipe out all the best Warplanes built today.  It does not need to carry fuel.  It can fly to outer space.  It can do rapid turns and hover.  It does not need runways to land.
Is it a Dream or a Fantasy?  Or is it solid science?
Uhhh...I'd say it was a fantasty!
In 1988, I built some prototypes of "voice coil" based suspended-magnet tubes.  I still have two of them and I'll see if I can dig them out and show pictures here.  Each had a teflon or kraft paper tube.  A heavy stack of cylindrical magnets was placed in the tube with pushing-polarity single magnets at each end which forced the main stack to the center of the tube.  A magnetically-suspended mass, in other words.  The project was for a thrusting electric dildo.
A voice coil was wrapped around the center of the tube.  When pulsed, the whole affair would lurch (very quietly in my units because I wasn't banging the magnets against the ends) across the bedspread.
In 1994, I lived and worked on Maui and as a hobby, I built one with a pair of D-cells in the middle of the center magnet slug, so it could be self-contained.  It was built in a glass tube and the coils (now two) were part of the moving battery/magnet assembly.  You could see the inner workings, in other words.  It was quite strange to watch it travel along in jumps with very little sound and no external wire connections.
Then, one night, I got involved in a bar room brawl trying to protect a young lady from being bullied by a couple of locals.  I won the fight but landed in the hospital with 11 fractures in my facial bones and had two lengthy and very expensive surgeries at Maui General hospital to rebuild my face.
I had tucked my prototype into my bag when I went in for the second surgery because I was quite attached to it and was afraid it might get stolen if I left it at my home.  While I was in surgery, an orderly decided  to take a look in my bag and found the long tube with coils of wire and batteries inside.  She called security.  After the hospital was partially evacuated the US Army bomb squad was called and they took my little "inertial dildo motor" prototype out into a field and blew it up!
True story, I swear!  Okay...I lied when I said I won the fight...but the damsel did escape!
But as far as making UFOs with it, I'm afraid that's not in the cards.  It relies on friction between its low-mass outer body and whatever it's travelling across to get any net travel.  In space, it would wiggle but not travel.  Just like in the first videos; when it's laid down for "horizontal travel" you get net travel.  When it tries to go vertical, it has no friction against anything so it shows no net travel.
« Last Edit: 2011-01-19, 12:25:12 by humbugger »
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2024-11-26, 15:21:35
