Poynty. We use probes on both our LeCroy and our Tektronix that are rated to operate at a given maximum frequency. We never exceed that maximum.
This issues being discussed have little to do with exceeding the frequency limit of the probes. I'm relatively certain that you won't find any references made by me in that regard. btw, in order to actually use these standard 500MHz probes near their frequency limit, requires extreme care regarding very short gnd leads (actually no lead at all, use the spring accessory as humbugger mentioned), and restricting the measurement to sine waves only. And at 500MHz, not only will the amplitude be down by 3 decibels, but the probe will have already shifted the phase of the signal by a substantial amount. THEN. We can get the circuit to resonate at frequencies as slow as 50Hz - and get the same recorded benefits albeit at a required higher applied voltage from our supply. At no point does the measurement accuracy become 'stressed' or 'suspect' due to high frequency.
Incorrect assumption again. If there are switching transients, and I am certain there are, then there are high frequency currents present in the circuitry, regardless of how low the switching and resonant frequency are. Your concerns regarding the accuracy of the probes is valid. What is not valid is to infer or imply that we're operating beyond it's rating and thereby getting inaccurate results. We do not.
Again, see my response above regarding switching transients and the presence of the resulting high frequencies. .99
