"Now you will have a running average of the REAL power." This is very helpful indeed. I have downloaded the manual and started reading. Thank you.
If we can get the running average for the real INPUT power and OUTPUT power separately, I would think the next step will be to take the "running ratio" of these, Pout/Pin.
Will this not provide a reasonable COP value? Perhaps there is a better way... Seems this would require 4 channels on the Tek 3032... not sure how to do all this, but sounds feasible.
While having a running Po/Pi ratio (COP) would be ideal, it is not necessary, unless attaching the scope probes has a significant effect on the power levels. In such a case, then a 4-channel scope, or 2x 2-channel scopes would be preferable. "As I have stated a couple times now, integration is not necessary to obtain a COP value" -- OK, but can you specify what IS needed then to obtain a reasonable COP value using the Tek 3032? Does the method I suggest above do the job?
This is a very important discussion -- thanks again.
As mentioned, if the DPO3032 is a 2-channel scope, you will have to obtain another scope that performs multiplication, preferably the same model, or get a 4-channel scope. The DPO3032 (being a 2-channel scope) will only allow you to make one power measurement at a time. The absolutely ideal scenario is to have a 4-channel scope, 2 current probes, and 2 differential voltage probes. Here is what I suggest: Place the entire JT in a metal enclosure, and attach BNC (or something suitable) connectors to the enclosure so you can measure the required points in the circuit. This should minimize influence on the JT operation and allow for using a single 2-channel scope to make your measurements. Also, see if you can borrow a current and differential probe. I wouldn't be surprised if the electrical engineering department had them. .99
