2025-05-11, 04:17:59
Author Topic: Simple Science Bench Tests  (Read 727 times)
Show how 2 strong magnets N+S can create free fuel hydrogen gas with vinegar water, from magnetic fields. Fields added to electrolysis cells also increases efficiency.  PVC Plastic 1/2" T, 2 steel bolts taped in each end. Pour in  solution in center around both end steels, narrow gap. Put magnet N + S on heads of magnets. See immediate bubbles. Pulsing DC current through transistor into cell from battery same time also.
Show how a 12v DC  electromagnet 20 turns with resistor, meter,and ground connection,  wound against output spark plug cable wire from fired ignition coil will increase voltage spark strength . Compare with + without magnetic field. Stress induced stretches out spark time and bigger spark.
How is that different from plain electrolysis ?
Why ‘free’?
Even if the magnetic field triggered a chemical reaction, there's nothing free about it unless we can demonstrate that the final energy state of the solution has not decreased.
If a permanent magnet is dissolved in acid, where does the energy spent on its magnetization went ?
Heat of the acid.
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-05-11, 04:17:59
