2025-04-17, 01:09:21
Author Topic: Nitrogen Hydroxide Fuel Aids Hydrogen Eneegy Content  (Read 371 times)
Generated with regular low efficiency electrolysis ,when neutral air is pumped under the ions solution of electrolyte. Used in the Outback by Australian solders returning from WW2. They brought the data back with them after finding the Germans were experimenting with vehicle engines in motor pools. With no power lines in the back lands, the engines powering the generators would self run on this increased energy content fuel gases. Check it out. Nitrogen Hydroxide as an aid for Hydrogen + Oxygen water cells.
Archie Blue, retired engineer of New Zealand factory for electroplating of scissors, had, in the past, US Patent on discs cell of porous aluminum electrodes electrolysis cell with air pumped in from bottom. Dual type fuel gases evolve with the other increased efficiency of "clean sweep". Some of the neutral air wipes the stuck ions clean off , so as the maximum efficiency is achieved. He converted 3 cars to self run on water.40 amps draw from battery, alternator recharges.
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-04-17, 01:09:21
