2025-03-14, 14:34:27
Author Topic: Over Unity Hover Craft  (Read 640 times)
The now late science man Mr. Baumgartner had built a small plywood hover craft, way back in time, that would lift any weight. Not using brute force air pressure method, but by the secret way that nature works. The 2 full pages with photos was amazing new science. Open up a top loading washing machine and take a photo to study. The turbine design was redone on computer programming for angles and using nature's spiral. You see, he tapped into the Energy of the Ether , the way Nature always does it. The galaxies, growing vines, pine cones, twister, tornado, hurricane, dust devil, all use the angle of the spiral to draw upon the unlimited energy available from the Ether. "Ether Physics". You probably never heard of it. John Keely of late 1800's worked with it too! He used a kid's train locomotive as electric motor. It was taken apart so as the windings of armature and fields were changed from parallel to series. He wanted speed instead of power for the turbine blades. Parts Mounted in tin opened can in center of circle plywood, over small hole. Power cord hooked up and the instant lifting effect happened with him on it.. Any weight was lifted. They later took it to town and lifted the front end of city bus with it. See also WW2 data on Shawberger German flying saucer design turbine. Be careful as certain factions may not want you to know this information. As the old Mission Impossible movie said, -- good luck, this tape will self destruct in 10 seconds.
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-03-14, 14:34:27
