2025-03-31, 19:30:35
Author Topic: Capacitor Discharge Ignition For Sparking Water  (Read 768 times)
Yes, I am familiar with that video of water sparks .
 The engineer has US Patent on that method. For OLDER type vehicles that can have the existing common inductive type ignition removed, and changed over to CDI, then the other change can be made. During the capacitive discharge ignition module charges 1uf capacitor that discharges into primary of step up autotransformer. The 250volts fast induces into winding that then allows secondary to fire in microseconds, not milliseconds as normal. What exactly happens is this, what they didn't tell you in video, the capacitor does not fully discharge. The remnant voltage left is about 50 volts. The high volts diode is added , facing the high volts output. Diode is in ON condition. When high volts COMES OUT INITIALLY, it presses against diode , diode shuts off. High volts reverses and along with Radiant Energy escaping, the balance of 50v energy of cap follows the high volts to spark plug. The blast noise is the too fast resultant energy release into zero ohms spark plug to ground. Good for gasoline fuel.
Group: Mad Scientist
Tesla igniter for gas engines.
https://m.youtube.com/watch?v=WkdIDbiCxTM
mags
the old points system, with a good condenser was actually a multi spark.  condenser across the open points goes into resonance with the coil primary, all the way through the ignition wire to the battery, through the battery back and forth a bit, probably desulphating the battery also.   thats just how they were wired back then.
points with condenser.
https://m.youtube.com/watch?v=bgDbBsA15C4
tesla igniter pat circuit
https://m.youtube.com/watch?v=IafARcXrTs4
with the large inductor in the tesla design, was calculated at less than 1w. typical points setup about 70w. and the coil runs cool with the tesla circuit.   basically capacitive discharge done simply.
mags
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-03-31, 19:30:35
