2024-11-07, 02:42:18
Pages: 1 [2]
Author Topic: I beg for your help.  (Read 3246 times)
what about Newton first law ? I bet it is also important  O0
Yes,and I think  Lenz's law too.
So why is there no time gap between cause and effect ?
How then to distinguish them, where is the cause, where is the effect?
Or is there a gap?
"Newton's first law states that every object will remain at rest or in uniform motion in a straight line unless compelled to change its state by the action of an external force. This tendency to resist changes in a state of motion is inertia."
but what it means if opposite is true ? what if all forces acting on object is balanced ?
Or is there a gap?
You make a good point. What if newtons third law was not 'instantaneous'. In rigid bodies for example, we know it depends on the speed of sound through said material.
Perhaps the exploit to overunity is time dilation? Which is really a phase shift. Light entering a medium also undergoes a phase shift which gives it the illusion of 'slowing' down but really it's the material itself which is stretching and bending in a delayed matter because of its 'stiffness'. The stiffer the material the smaller the delay, hence why EM waves move much faster in metal lattices than in water. Or to put it more correctly, the wave energy is delayed much less in harder than in softer materials. And to break it down even more simply, this is because the wave that has a linear velocity suddenly gains a side ways velocity too because of how it bends the material, this side way velocity due to the interaction with the material is what gives rise to a 'delay' in the linear velocity or rather energy/momentum.
The question is what materials exhibit the most 'time' dilation if you want to build a more static or rigid demonstration. Well they should be 'soft' materials materials where the wave of energy (sound/EM/...) is 'delayed'. Rubber? Iron? Water? Anything with a hysteresis should be a good candidate as this can be seen as the materials 'time' delay factor. After which you start the injection of wave energy by 'hammering' the material which will ripple through the material with a certain speed but due to the time delay or phase shift the 'reaction' forces arrive and are balanced but in time they are 'unbalanced'. This creates a slight momentum advantage and the system appears to 'violate' newtons third law but it is only an illusion of a phase shift of the energy wave. The hammering can also be harmonic and voila you get resonance plus a continuous delayed reaction/'lenz' force and produce your 'anomalous' energy. Or as some perhaps would call it, a time machine that can extract energy lol. Pretty sure Tesla knew this but his scale and scope was too grandiose for his time. Key is to show this on a small scale before you go big.
So really, it's all about time or the illusion of it that occurs when you have multiple 'dimensions' rubbing against each other producing a energy/shock waves which produce a phase difference in said dimension with 'time' in between as a result. Newtons third law is a cardinal rule but it is not 'instant' and you must take into account the phase difference of the energy wave in all kinds of mediums/materials regardless where this energy wave came from. This is what causes the 'quantization' of momentum but really its just a travelling bundle of energy that is stretching and twisting in a corpuscular material made out of 'discrete' crystals which quantum physicists like to call the particle/wave duality. But hey everyone can have their fancy names right. But there is no end to it, it repeats on every level of this so called 'reality' perhaps even across the multiverse. There might be no height limit but there is an absolute bottom, the 0 Kelvin point. The immovable point, the 'super' singularity. That is the 'exploit' of the system, that is the only way one can 'produce' energy based on the 'illusion' of traveling and delaying energy waves to generate 'anomalous' unbalanced momentum in said 'crystals'.
So Dark Energy = phase shift of two massive crystals 'rubbing' against each other exchanging and releasing energy waves as a result? Who knows but if so, what kind of structure would it be, are there more like it, who or what put them there? Who knows and who cares really. It seems to repeat on every scale and there is seemingly infinite space to grow in. Perhaps we can stop the stupid fighting and wars, realize we are one big family, warm our cold butts and family homes with this 'anomalous' fire and enjoy the beautiful scenery outside that keeps restoring itself and evolving without our intervention in the form of trees, eco systems and life itself. I would like to see any Scientist, Prophet, Leader or 'God' explain the mechanism behind that to me. A mechanism that keeps making every generation more gentle, more harmonious, more empathic, more loving. All seemingly on its own. How do you imbued such an insanely complex system with love at such a low level and be self correcting and guiding at the same time? Sounds like God likes to build simple binary systems, with built-in error correction using a very simple software language: Love.
A simple system that repeats forever like a fractal and automatically evolves becoming more and more complex and which keeps self correcting towards one goal; 'Perfect' love. Whatever that might mean on the small and large scale. How would the universe look like when everyone strived to find the meaning of 'perfect' love? How would just our world look like if we all had one meaning in life, to work towards perfect love on every scale of time, dimensions and evolution. That is at least something I find personally worth working for, betting on and believing in.
« Last Edit: 2024-11-01, 07:53:22 by broli »
Buy me a drink
Pages: 1 [2]
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2024-11-07, 02:42:18
