A new search engine using AI that they say could take over #1 spot from Google (which I'm finding is more and more censored and focused on advertising than real answers).
https://www.perplexity.ai/An interesting answer from a question I threw at it about generating energy -- complete with steps to build and diagrams:
How to create a device to generate energy from only rotating magnetic fields with no physical device rotation
Sources
https://hackaday.com/2020/11/12/rotating-magnetic-fields-explained/ favicon
https://youtube.com/watch?v=VUS0HmY1yXs favicon
View 2 more
Answer
To create a device that generates energy from only rotating magnetic fields without physical device rotation, you can consider the following steps based on the available information:
Components: You will need a 3V - 5V DC motor, a portable power bank (external battery), and a neodymium sphere magnet (26 mm diameter)
1
Assembly:
Fix the neodymium sphere on the screw pot metal case in a specific position between the magnetic poles.
Connect the USB cable to the DC motor through the power switch.
Choose the rotation to the right of the sphere (+ and - polarity connection)
1
Testing: You can test the device on a coil connected to a 230V AC bulb and a magnetic compass to observe its power-generating capabilities
1
The concept of generating energy from rotating magnetic fields is also used in various scientific and engineering applications, such as in nuclear energy research for plasma confinement and fusion purposes
2
. Additionally, there are studies on new methods to generate a rotating magnetic field using a closed magnetic circuit with ferrite elements
3
The idea of using rotating magnetic fields to generate energy is based on fundamental principles of electromagnetism and is commonly employed in electric motors and generators. The rotation of a magnetic field induces an electric current in nearby conductors, as explained by the concept of electromagnetic induction
4
For a more detailed understanding of rotating magnetic fields, you can refer to educational resources and videos that explain the basic principles of this phenomenon
5
If you need specific technical details or further guidance on constructing such a device, it would be advisable to consult with experts in the field of electrical engineering and magnetism.
Related
