2025-03-31, 18:02:59
Author Topic: Our Body as a Water Cell.  (Read 937 times)
When attaching electrodes to a body of water, the rule is and is a must for anything to "work", FIRST attach the Negative Lead from the battery to the Cell. Then the Positive. When stopping the experiment, The Positive is disconnected First followed by the Negative.
Anytime, one is playing with any kind of electrodes and something with a battery connected for any kind of action, you dont want a bad opposite and equal reaction. Negative on first and Neg off last. This would include any 'healing' device like a Zapper, Rife or other such apparatus for effecting a Cell with a Battery.
This is a MUST for the JoeCells to work. Its about connecting to the Aether with 'Pressure' from the Negative to "Orientate the Wave" about to form.
We are a WaterCell. 100% Light Crystals in a multitude of Frequencies.
We consist as a conglomerate of Cells all acting in unison. They are all designed with concentric patterns.
There is a Right Way and a wrong way to connect a battery to your Battery.
Most know our Heads are North Poles.
Very Few know our hands are Battery Terminals.
Tesla Knew and they made lots of human Battery Chargers for Penny Arcades.
Well here's my 2 pennies worth.
This is probably the most important Intellectual Property you actually 'need' in these peril times.
One Car battery and a set of cheap jumper leads is all you need.  Try to avoid copper Alligator clips. Use Silver if you can.
Grab the Neg in the Right hand making all finger PRINTS touch the Metal.
Grab the Pos in the Left hand making sure all finger prints are touching.
Hold for no longer than 3 minutes.
Left off then right off.
Once Charged Up, we can then explore other points to activate on the body and a couple of them will make Joezone.
It has a similar sounding gaseous name, and every Cell in the Body will now 'produce' Joezone.
I do believe this is the ONLY therapy you can use on any Apes in our mist that have suffered under the recent Bio attack on 5 billion souls.
This is for experimental purposes only, Do trial it on dogs cats and horses (I have) and any biped in need. No medical advice here just experimental antidotes for the curious.
This was sent to Steve at Tesla Tech. Call to papers n all.
The Future of Electro-Biotics is in your hands
The Healer’s case of Energy Medicine. Consisting of a 4.5V power supply for Joe’s Silver Generator and the 7 Ringed Silver Elixir Generator. 4 small 12V batteries to supply energy for the Copper Neutral Module for Detox Baths anywhere anytime and the DC Source for Charging Up the Human Battery and JoeZone Production to revolutionize natural healing techniques.
With this Charge Up technique, Joe has demonstrated 12V (car) batteries supplying  Magnetic DC that can be applied to certain points on the body that are not known in other point activation techniques, that produce results or ‘actions’ of what could be described as an ozone effect from every Cell in one’s body. This is a natural ‘oxygen therapy’ similar to the oxidizing effect of white blood Cells and their ‘peroxide’ like action upon invading pathogens and similar to the oxidation ‘action’ of ‘penicillins’ upon pathogens. The use of ‘hydrogen peroxide’ also comes under the ‘oxygen therapies’. Here we activate the bodies natural ‘ozone’ production capabilities by Charging Up with a simple car battery and a set of Jumper leads. Joe uses batteries to apply Frequency upon ‘nodes’ or ‘usb ports’ on the body. (input and output ‘terminals’).  What one might ‘feel’ is tingling. What one might see is “The Light” and what one might taste is ‘Metallic’ like ozone. What it might do is become the next Level Up of natural healings. It is advisable to be trained and Certified in this Methodology of Electro-Biotic Joezone,  Electro-Biotic Charge Up and Electro-Biotic Gland Activations  in keeping with Physician First Do No Harm.
What makes this Joe Technique different is he Charges Up the Bio Electric Field to enhance the Bodies natural immune system rather than target any pathogen with a set ‘frequency’ of ‘electricity’ for a specific ‘action’. To Charge Up Life rather than the AntiBiotic effect of killing pathogens. Strengthening the Terrain rather Allopathic medicine.
Tesla Tech next Aug to learn this where I will be conducting Workshops for Training Purposes. I Hope.
Its taken 5 Years and many Brownie Points to get Joe to allow this to happen.
Some here have asked for this after reading it else where on the net.
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-03-31, 18:02:59
