2025-03-31, 17:58:13
Author Topic: Magnetic In-Line JoeCell as LENR  (Read 831 times)
In this thread we discuss the Free Energy of Magnets and one of the applications of this Free Energy.
It can applied to Magnetic Field Generation in Water, Air and for flight control.
The 'atomic theory' of this totally new way to use magnetic Fields is best explained with reference to the attached word doc.
Page 1 is about the COMBINING or adding of Magnetic Fields together.
1+1 =1 is where no matter how many magnets one joins together, the outcome of the Field Never changes. No increase in Gauss as one way to understand it.
Page 2 adds further to the understandings.
Page 3 shows 'another' way to combine magnetic Fields or the Magnets in the In-Line Magnetic JoeCell or the Aqua Chi Water Module as the only Device available on the planet that exhibits this 'effect'.
This totally changes "The Field" giving a New Field completely 'different' to the usual way we were 'taught' to play with magnets and their Fields. As in 1+1=2
the next page (not printed) in the pdf shows us that 1x1=2 but lets keep it simple for now.
In the Magnetic In-Line Cell as built by Joe, Joe combines 2 ring magnets by placing the SAME poles together.
All other Magnet water conditioners only just add magnets in the usual format that they 'stick' together.
On a side note, one guy from Melbourne actually glued 2 same poles together trying to reverse engineer Joe's Cell. He even posted them to Joe and asked "is this correct"? We wondered how he managed to do it and how explosive they'd be when they let go.
The Addition of a Neutral Plate or iron washer between the same poles with the right ratio Dimensions, sees them attract together quite easily and display a significant or about 5 fold increase of Gauss if you want to measure it. Its a MONO POLE DESIGN and is the IP of Joe as a Design Copy write. Remember this when trying to remember the magnet placement on the deleted samsung motor project.
And contrary to the definitions of Magnetic Fields.. https://byjus.com/physics/magnetic-field/
"Field lines is an alternative way to represent the information contained within a magnetic vector field. Magnetic field lines are imaginary lines."
These Lines of Force can be FOCUSED when used similarly by spinning them past a copper coil to make 'vibrational physics'. Or having Flowing water with a left hand spin flow through the focal point.
Not only can they be Focused to a POINT within the Field (zero point or Neutral centre or Equilibrium) They can be redistributed Along the pipe as a New Field Effect depending upon the Material construction of the Pipe.  Making the article about Magnetic Fields above now obsolete and Fake in my opinion like everything else about Marble science.
All this comes under Joe's IP of Neutral Plates to create magnetic Fields. Joe did this several years before this Pdf was written by another Inventor to reintroduce Magnetic Field Science as Unified Field Principles. This Same Pole IP is as Alien to modern Physics as it gets. Now make transformers with primary and secondary windings as SAME Poles for 'static Vibrationary' production by thinking outside the box.
In this demo, https://rumble.com/vhrdlh-magnetic-in-line-joecell-restructuring-ocean-sea-water-into-fresh..html
The IP of a Neutral Plate (like the un electrified tubes in a Joe TubeCell) is placed between two same poles on a ferrite ring magnets. This 3 component, dimension critical, 'array' of magnets, is then slid over a water pipe and in the video above there are 2 of these arrays in the Cell.
In the video above they are NN poles together. Joining 2 SS poles together, the water would turn into oil.
Yes you can build one. No it wont work for you because of your Y factor. All explained in the samsung motor deleted page where one uses the Mental universe to program the iron washer with Faith. (explained earlier) After sparking it with a car battery to remove residual Memory of Manufacture it can be re-programmed or given a new memory by a grey haired wizard. Like ridding a bicycle, it just takes practice.
Magnetic Water flowing in a pipe is like magnetic red blood cells flowing in the Circulatory pattern of a rotating magnetic Field creating the Bio Field Effect. One then merely wraps copper coils around the water pipe to Generate vibrational 'electricity' as the Magnetic Light Crystals have been Charged Up to create this Field Effect.
Does Not Matter the kind of "water" or Liquid flowing through the Magnetic Focal Point when using stainless steel, or a Field Effect if using mild steel pipe, it will exit as pure fresh water. Of the many 100's of people this has been demonstrated for, it ranks as the most sought after invention of Joe. Many tried to replicate this and failed. Basically because they thought more gauss or Neodymium was the way to go.
It takes a Nuke Power Plant to do what a 2 inch Cell can do in one day. Literally free oil or free Potable water from raw sewerage when Prince Kareem of Dubai visited for a demo with his black helicopter circulating overhead. One guy in Tasmania filled a bath tube with this water from this Cell construction and healed his cancer in just days. Takes a couple months with the Aqua Chi bath tube of water.
ALL these Patentable Ideas can be presented as Schematics for a Build. But without the Operating IP, the build will do something other than expected with a haphazard like design.
This Bench is for understanding New Science Builds based upon Field Science rather than particle science. Its not about schematics and working models.... although some will be presented.This is the Field Science 101 course in Magnetics. Most necessary for any real Over Unity Scalar Energy production of Radiant Non Hertzian energy just like Tesla ACHIEVED but memory holed for Smart Meters to charge you to connect to just a vibrating circuit
Here it is in Joe's own words.... The joining of Same Poles together and a Neutral Washer Watch him Join a broken magnet back together.
Peter Stevens, the bain of Joe's existence
Oscillating the pipe back and forth but it not touching (so zero friction) like demonstrated in the hard to push part, would generate 'electricity' if it had lathe marks on it, Making a piston engine a V8 Generator hybrid car. Its not electrons its Vibrations created with Magnets. There are more 'principles shown here that isn't even touched upon but is shown.
The problem here as I see it... we all were, I was very good at learning water is h20, the best minds in the world all agree the Periodic Table is the Best model we can come up with, its a flow of electrons, a diode is only a 'rectifier' and you cant go faster than Light. Some have hetrochromia and see things differently.
So everyone, in order to feel like a 'community' accepts certain "givens" as facts. Outside these parameters lies the fringe groups. Rarely but often enough, someone on the world stage shows his device and nothing ever comes from it, because no peer reviews. Many adherents to some fantastic claims sign up for the Quest. Many forums in the Age of Enlightenment sprang up to cater for those on a Quest for Truth.
Except they cant get past the childhood programming with 'facts'. So the Program is all most use as their tools for reverse engineering. Because few other words describe it.
Whats on 'offer' here is;
The a more correct view to See the way Tesla did as a finished product design in his head before he ever picked up a pen or spanner.
Mostly whats written about South Pole Positive Field Energy, is some what correct.
But nothing has been written about the North Pole Fields created to Yield Energy.
Its Taboo to the Community and will tarnish your career to even talk about it.
This is not a Community I want to work within. So I left Uni after 3 months. Telling me to read just their books to pass. I did that when I didnt know any better at school during the Programming. The Actual Program is Trust the books we give the Heart Tick of Approval too. Its very hard to break. Joe calls it Educated too far in the other direction. Because everything has an Opposite and equal.
With this new view of the other half of the Unified Field Equation, we might build and invent like the Egyptians. Its coming and here's where you get prepared for it. Better save a copy, the Lord works in mysterious ways.
I have been trying for the last hour to upload 3 videos but is the 25MB per file too much?
so here's a link where they can be watched.
https://metallicman.com/forum?view=topic&id=178
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-03-31, 17:58:13
