Apparently, you watch this video
PW
In actual fact. I am the cameraman and they are my family. This was done the next day after Charlie Spiers had left. He saw it too.
So having seen this Implosion Demo of Compression energy or North Pole cold fusion energies, as a rough guess over a 100 times. Just never got around to making a video that is presentable with real people in the actual environment these discoveries were made.
The Cell used for this Implosion and the Opposite and equal Action of heat burn expansion, has been used many times as a Teaching Cell.
I did the course, my son did the course, and several others. Peter Stevens the man who made Joe Famous and started the ball rolling by borrowing the first cell and showing others, never saw or knew any of this. Peter feigned finding god after visiting the Walter Russell Science Centre.
This is the First Lesson of Operation. once you build it and want to put water into it the first time. literally hooking up the electrodes and .....
Now Joes does each of these steps and then its your turn. You repeat exactly what he does.
1. Each component as it's assembled is 'sparked' with a battery to remove Memory but we also need to wash it out under plain tap water or Liquid Electricity and Ones Bio Field Become One. You know that Y factor? Well here you can learn about it.
2. Fill it up from the tap. Understanding water source differences based upon Earth Charged Frequencies like those at the top of a mountain spring that have hydrologists scratching there heads in silence comes as Lesson 2. Primary Water. Definitely a pseudo science because if it was real it would be fake news.
3. return cell back to 'insulated cradle' or a bucket.
4. Make sure the battery is Charged and connect using an alligator clip the Negative Electrode from the Battery to the centre tube and then the positive to the outer Cylinder and WATCH. People have spent HOURS watching bubble this way. Some do it for WEEKS and MONTHS. Some see bubbles and some dont. My son didnt get bubbles. Then Joe gets bubbles and Son tries again and no bubbles. Then you ask the universe for help and it replies Ask and ye shall receive bubbles. It then Bubbles. I not only didnt get bubbles the first time but the Battery had ZERO spark when arcing the terminals. I, in an instant, flattened the battery. Im good. So Joe said fix it. The ole coil between the battery terminals trick. I had flattened one side of the battery. more here
https://www.overunityresearch.com/index.php?topic=4549.msg109595;topicseen#msg1095955. We repeat this changing places as many times as it takes for pico to get it.
Now Your Spirit has learned how to program a JoeCell in a Mental Universe said Hermes. A Water Dowser operates exactly the same way.
I believe you deny having critical thinking skills. But I could be wrong
