So your going to use some copper brake fluid tube
Yes. I did not buy it yet. as and aerial
No, as a shield. spiral around the grenade
No I presume your going to use some inner coax installed in the tube
Yes and connect it to the far end of the tube like a hairpin?
No I presume you do know how the device is supposed to work or do you ?
We will see have you noticed Ruslen doesn't build his like that,
Yes. I do not work in monkey-see-monkey-do manner. Instead, I make an educated guess about the operating principle and let it guide the build. If it doesn't test as expected, I make up another plausible operating principle and repeat the whole process. This experiment is only to better understand the behavior of coils wound with coaxial cables. I already wrote about that and you should know it, if you read Ape's and my words in this thread.
« Last Edit: 2023-10-08, 21:24:51 by verpies »
