... I have to solder / desolder those 1 turns coaxes several times like to test around the core, then calibrate, then again around the core to measure.
Yes, but without it the results will not be maximally accurate. So i guess it's indeed type 43 material.
Perhaps not. Your ferrite transformer appears to transfer signals up to 100MHz without distortions. Notice that your S21 plot is quite flat up to 100MHz and squiggles begin only at ~140MHz. So if you make a 1:1 Balun from it, then it will work well up to 100MHz for sure. Take a look at the "1:1 Balun (Choke)" column in the table published by this supplier :  You can notice that according to it, the type 43 material would not be able to transfer 100MHz signals and there is only one ferrite material type on that list, which is suitable for 1:1 Baluns up to 100MHz. That, combined with the 713 relative permeability at 100kHz, suggests that it is a different material, yet.
« Last Edit: 2023-10-08, 23:08:43 by verpies »
