2025-05-11, 04:29:44
Pages: 1 ... 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26]
Author Topic: Kapanadze replication  (Read 121806 times)
It was found today in my old computer, these pictures dated 2017.  I don't know were they here earlier.
Yes, this is probably a fragment of the Greek patent. I have it too.
Don't torture yourself, everything is more banal!
Correctly organize the supply of current from the Tesla transformer to the passing wires in a 50 Hz rhythm.
https://dzen.ru/video/watch/64dbe9c89910b52921cb132c
In fact, for experiments instead of Tesla transformers, resonances and sparks - a simple current source is needed, like my car battery. And also a voltage source in which we will amplify the current - a transformer.
It's time to remember Mr. Melnichenko, whom Kapanadze mentioned, he took only the magnetic field by making a distance between the cores. Well, put these puzzles together in your head)))
Learn how to amplify voltage with current - switch to a Tesla transformer!
First you block the magnetic field by limiting it and then with another stream you open it. Where is the FE here?
First, we need to add magnetic fields in a simple way! We change the current obtained from the Tesla transformer to a battery.
A transformer with two windings, the first can be up to 220 volts, the second 10-15 volts.
The phase detector is assembled on a diode bridge and an adjustable resistive divider.The task is to obtain high-frequency current packets in phase.
The most important thing is the magnetic adder. This is a Melnichenko transformer, in which the gap between the two cores and the windings between them is selected. Thus, only the magnetic field is transmitted, without inductive coupling. This is a narrow corridor that must be precisely adjusted by the gap between the cores.I think any experienced searcher can do this and set it up.
This device will allow you to understand how to sum the magnetic fields of two sources to create a CURRENT AMPLIFIER.
Has this been discussed already?
Does anyone by any chance have access to the forum: http://www.matri-x.ru/forum/?
I’m interested in a certain schematic that is used in this video: https://www.youtube.com/watch?v=AKdQbysXwng.
The author of the video posted this schematic in the subforum "Свободная энергия" (Free Energy), under the topic "Установка Тариеля Капанадзе" (Tariel Kapanadze Device).
I’m not able to register on that forum. Maybe one of you has an account on that forum.
It's very possible that the forum was closed because nothing happened there for a long time. The owner was collecting money for hosting.
If they had OU, they could have bought for hosting for a hundred years forward ...  :)
« Last Edit: 2025-05-03, 07:22:20 by chief kolbacict »
 :D ;D :D ;D
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-05-11, 04:29:44
