Let's talk about the Kapanadze device and common sense... The energy of an electrical system follows rules similar to a hydroelectric system. Water power is based on water pressure and flow rate and electrical power as electrical pressure in volts and electron flow in amps. Hydroelectric systems use high pressure/low flow turbines like a Pelton because it's more efficient. The water nozzle concentrates the high pressure head into a small cross section in effect concentrating the energy flow. Where a low pressure high flow turbine would require a very large flow and a large cross section. When we talk about a transfer of electrical energy we can have X power as a high potential/pressure and a low flow current which can use small cross section wires. Or a low potential/pressure and a high flow current requiring a large cross section wire. Ergo, 12v needs big wires but 1000v can use smaller wires to transfer the same energy. Similar to hydroelectric systems, if we wanted to transfer large amounts of low voltage high current mains power the cross section of the power conversion system would need to be very large. One ground wire would never work because the voltage is too low and the current flow restricted by the small cross section of the wire. A low voltage high flow current has a very low energy density at any given point. In effect, it would be like sticking a small straw into a slow moving stream and expecting water to start gushing out of the straw, it's completely absurd. So anyone thinking a one wire ground connection is going to miraculously intercept kilowatts of mains power obviously understands nothing about power or energy. In fact Tesla described how these systems use a ground connection in the picture below. The Earth ground connection is used as a large reservoir to periodically store energy. We move a current into the ground and then out of the ground periodically which allows a current to flow through the rest of the system. In the picture below of Tesla's one wire system... https://teslauniverse.com/nikola-tesla/articles/true-wireless1)The alternator pulls an electron current from the ground pushing electrons into the capacity (sphere). 2)The alternator pushes an electron current into the ground pulling electrons from the capacity (sphere). 3)The ground and sphere are simply a means to periodically store electrical energy so the current flow can alternate back and forth in one wire through the load. As such, the fact that Kapanadze required a ground connection which pushed and pulled a current periodically from the ground implies that part of his system was based on Tesla's one wire concept seen below. You see, now were making progress... AC
