Extract. June 2014 A method and apparatus, by which zero point energy is extracted, in order to increase electromagnetic field energy, which is translated in an increase in kinetic energy of the "free" electrons, which is brought by means of the counter-by-side to create the space 2 in oscillating electro-magnetic "fields", having the same frequency, but with a phase-difference, in-parallel electron conductors, which have a small distance relative to each other. Summary. It has been found, after ample research, that zero point-energy can be extracted from Space in several ways: by using permanent magnetic and / or electromagnetic fields, as well as "Time-Space " changes . That this is not known by the contemporary Physics , or don’t want to know, is the biggest scandal done to humanity. Since 1912, the year of the "failed " Michelson - Morley experiment, which failed because of the erroneous assumption that the Aether, if it would exist, would flow tangentially along the Earth's surface flow, is simply adopted by Physics that it did not exist / exists. The reason that Michelson-Morley had failed is that the equipment should have been set up 90° different. (The gravitational inflow is the main component of the Aether flow near and in the Earth) . Poincare suggested the nonsense that Nature itselve would hide the discovery of the existence of a carrier for electromagnetic and gravitational waves and currents. Einstein already in 1931 proposed serious objections against the direction which Physics has gone (Einstein , Podolsky , Rosen). However, to date, the theorists have kept the developments in Physics with respect to low- temperature fusion and zero point-energy to a stand, aided by the large-industries, for the enforcement of the status quo and little interested in energy technologies which make low costs, decentralization and independence for consumers possible. This invention concerns the “against each other in oscillation” of two electro- magnetic fields, wherein it has been observed that , depending on the frequency , more Electric energy can be taken away, then is provided. Use is being made of conducting wires, which are right next to each other. Possible ways are (a) "in the plane", (b) on a "cylinder”, (c) on a "toroid" If someone bother to read and try to understand what they read in patent NL1032750 of Arie Melis deGeus (NL1032759 on this forum), may find out how to make it work any device similar to Kapanadze. I would strongly suggest to download and save hard and digital copies. Just try to analyse many other ou/fe devices and find out that same principles are involved an been applied in different ways. Build 1 device with whatever you have at hand and cost almost nothing, play with it to understand, than scale it up for your needs. Wire length equal where wire length is half of wave length based on frequency, jion them in midlle with 2 series capacitors where 1 of them is half capacitance than the other (135 degrees phase, or equal capacitance 180 degrees), simple oscillator circuit. “Bellies” and nodes easy to understand if you look at standing waves when transformers are shorted. I don't think it could be easier and simpler than that ! Simple deny of aether existence from mainstream science has put in jeopardy most of replication attempt by many. In this patent we can see how mainstream science colluded with unscrupulous gov/military/ bussiness against every individual living on this planet and has lead to an enormous international malefic organisation. This is the reason why they killed inventors and scientists including Arie deGeus and Kapanadze or any other that were showing why or how it work ar attempt to mass production or sell such devices. Keep simple explanations and simple words to make it available for anyone understanding. I can see a lot of fancy devices that are meant to be used in such devices, but for ordinary people to get started on non taxable and not metered use of energy is not needed right now ! Please understand this ! Anyone in the world can have this in their houses with no need for enslaving power grids.
