2025-04-01, 02:50:02
Pages: 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26
Author Topic: Kapanadze replication  (Read 104662 times)
Take a look at the attached paper. It describes a phenomenon that is similar to NMR but it affects ferromagnetic domains instead of the magnetic moments of the individual nuclei ...and its FWHM resonance bandwidth is much wider than in NMR.
One thing to note - when you have 2 resonant coils on same core placed on 90 degrees angle there is very narrow range where those two coils interact in a way where the output of oscillating magnetic flux is amplified and not cancelled. And it is not researched well so what exacly happening on ferromagnetic core is also not well known to conventional science. Which effect is really happenning there.. only to guess until now. This is an area for experimentation and for making theories only after having working prototype in your hands.
It might be a bit deviation from original topic here but... If I would had been in Kapanadze device demo, I would bring radiation detector, oscillating electric field detector and longditudal waves detector with me. Depending on what those measurements would show it would be more clear on what was going on there.
Every time we have "OU" there is something going on beyond what conventional measurements would indicate.
And to add to the list - if you ask any scientist simple question: where energy is coming from to keep magnets magnetized while they do work in generators against opposing magnetic fields from generators windiings, they will be just scratching their heads over last century.
Narrow range of what?  e.g.: winding angles, phases, frequencies, amplitudes...?
T-1000
It's an interesting concept and I was thinking about this today.
Suppose I had a few working FE devices and I wanted to introduce them to the world. The first objection might be "where did the energy come from?". I would then ask "what is energy" at which point most would have no idea how to respond. Understand 99% of the population cannot explain what energy is, where it is nor why it is. It is an enigma, an intellectual black hole and when I ask this simple question I see this look of fear and disbelief in most people. It's like asking if unicorns prefer pasta or rice and it's pretty obvious most have literally no comprehension of what it is were talking about.
Which begs the question, how could so many people be so completely ignorant to the concept of "energy" which literally dictates the action of everything in the universe?. I mean ignorant of one thing could be excusable but literally everything?. It must be a joke, some other explanation, it cannot be true in that sense could it?. Yet it is true and simply asking the question "what is energy" to the people around us proves they have literally no clue what it is nor how it works.
So this notion that everything is known is obviously complete bs and the question of what we know is debatable.
I love it, I can walk into any room, ask the question "what is energy" and everyone turns into god damn cowards heading for the doors. It's almost miraculous how consistent the effect is.
The frequency, phase and duty cycle. The two 90 degrees cols interact over same core to rotate magnetic domains inside 3D XYZ plane and control resulting magnetic flux of the core. For example, in STAAR device experiment it was copper foil and normal magnet wire over 90 degrees.
   Ok, well it looks like the energy from crystals thread is on hold. Too much information and opinions without proof, and no working device. Perhaps the best thing was to close that thread. As it looks like no OU, nor self running devices are going to be shown. The proof is in the pudding. In this case, just a wall of text, is all there is, from the wizard and his pal.
  We have also lost the research and tests on the Akula, Ruslan type of devices, as no one is doing any further tests on actual devices. Until that is reanimated, we are lost in space.
 So, let's work on getting something that actually works going...
And leave "silly" unproven speculations behind.
   Many of us are familiar with Tesla and his ideas, especially concerning free energy. As that is the point of this and other threads. But, some will read his ideas and not believe him, or think that that is all outdated now. But they are wrong about that. Conventional closed circuit mentality and greed, is to blame, instead.
« Last Edit: 2023-12-16, 13:29:46 by NickZ »
T-1000
Why do you keep beating your self up over energy it doesn't come from any where! it's every where, every thing is energy
even dark mater is energy all your doing is moving it around.  There was a Turkish university professor some while back showed a 30 watt device using a collection of FE devices all joined up  I haven't come across it lately knowing YouTube it will have been wasted. Taken down. some one should make an alternative system with less adverts and advert time, that allows folk to down load stuff, wouldn't that be great other wise the internet like every thing else will die off. if it's not already started.
   AG:
   Good point,   it doesn't come from anywhere, it is everywhere...
   We're just too dumb to know it. Or are we???
Some food for thought.
We have high frequency and low frequency as coil inputs. While going through old documents I remembered about old tape players and how sound recording was made - https://www.aes.org/aeshc/docs/3mtape/soundtalk/soundtalkv1n2.pdf In old tape players recording the high frequency was used for magnetization and low frequency for guiding magnetization polarity.
Now the task would be - how we can magnetize transformer core with much less current than plain input from single coil? The most likely answer would be, polarize magnetic domains with high frequency to the edges of BH curve and the low main frequency would flip magnetic domains polarity without much effort.
When looking back on Kapanadze style devices the high frequency would come from top load capacitor plate "antenna" with square nanosecond pulses and low frequency from the main inductor. Which also serve as another capacitor plate for the high frequency circuit. And high frequency activated on magnetic domains spin moments from one polarity to another.
With that that approach the bifilar cw/ccw output would be one of ways to have induction for output load without influencing inductor.
If anyone here still have Kapanadze generator setup in works, hopefully this theory could be checked on the bench. I would love to see results.
Cheers!
SR193 had the idea to relax domains.
Unfortunately, it was never possible to implement it, including him... :-\
And I made the oscillogram described in your link on the first posts of this topic.... https://dzen.ru/video/watch/650573800b441c1b59a91b7b
And if you do similar modulation like in old tape recorder , what result you would get on output and power consumption?
What is an interesting wire such ?   :o Wesley could have find the  novozenland's original in english.
The funny thing is, I didn’t remove it from a coil with a ferrite core. She was just passing - like a throttle.
Wondering what I might have missed.....
So the high frequency loosens, or even spins the domains while the low frequency guides the end result.
It must be about more than just exceeding the coercivity region of the BH curve to create an energy anomaly and several years ago I would call it bullshit, but after seeing the yoke device work with similar signals and the screeching sound, I must write - interesting line of thinking.
  The low frequency on the Ruslan device from the push pull output is about 15.KHz. Is that considered low frequency?
   And the HV, HF from the kacher us around 1.5MHz.
   I don't know what frequency TK had shown as low or high frequency. As he does not show a scope, and does not know how to use one, nor needed one, either.
15khz is 1/100th of 1.5mhz the problem is thats close to the audio sub sonic freq and dangerouse, and radiant doesn't realy start till 20khz
thats when energy floats on the wire surface any way 15khz and 2mhz are not in resonance  but 20kz would be any way to get any where you need to know the secrets on how to solve other things like getting FE how are you going to capture it with out distroying it, the dipole?.
« Last Edit: 2023-12-22, 20:56:00 by AlienGrey »
TK did use spark gap for hammer approach. And wires inside coil as capacitor plate.
It will vary depending on the coils. I would recommend to sweep square waves frequency range 5x-15x with <=30% duty cycle on your Tesla coil top load and see which frequency can do best pre-magnetization on 90 degrees from the coils. And see that familiar wave inside wave when mixing with low frequency (adjustable 15kHz in your case). As it is Tesla coil with blocking generator(katcher), adding grounded foil plate near Tesla coil and moving it around will influence that frequency.
Talking of which, there is someone you may know who also did play with that part - https://www.youtube.com/watch?v=VpHk6wYljtI
I would recommend to sweep square waves frequency range 5x-15x with <=30% duty cycle ...
Do you know why you always make this duty cycle recommendation ?
I have seen you follow your own advice, too.
I notice you mention magnetic waves at 90 deg, so why is all your windings in a line ? is that why Nelson commented on the tesla coil transmitting  and wasting energy into space ? C.C
  Double post deleted.
« Last Edit: 2023-12-26, 12:44:27 by NickZ »
Two coaxial helical windings can generate a small annulus of magnetic flux, which is perpendicular to the axis, if these windings generate bucking magnetic fields in the gap between them.
Are you sure T1000 wrote about magnetic waves?  Waves?
One of possibilities.
And your mention about cоaxial windings reminded me about 2012 Edward Lee device - https://www.youtube.com/watch?v=KR99TnupvOU https://www.liveinternet.ru/users/edward_lee/post235578744/  https://www.liveinternet.ru/users/edward_lee/post237839624/
In his implementation the nanosecond pulse generator was used on coiled coaxial cable which was shorted on the end - https://img1.liveinternet.ru/images/attach/c/6/91/471/91471963_large_GNSI.JPG
And from his posts on Russian forum about finding effect and on https://www.liveinternet.ru/users/edward_lee/post235235326/
Эффект был замечен случайно , когда настраивал Г.Н.С. в качестве оправки для намотки коаксиала использовал старую мини Теслу.
но на ней была намотана еще одна обмотка проводом 0,65 и я пытался на ней добиться хорошей искры, настраивал ГНС и как то подключил к ней емкость, и получил хороший удар током. Совсем не похожий на обжигающее прикосновение ВВ ВЧ. Тут дальше пошли эксперименты именно в этом направлении. Я не претендую, что моя конструкция является самой оптимальной, но самое важное я получил, и буду работать дальше оптимизируя и изучая данное явление и установку. Еще одна ВАЖНАЯ деталь- БЕЗ ХОРОШЕГО ЗАЗЕМЛЕНИЯ - НЕ РАБОТАЕТ
The effect was found randomly when I was tuning nanosecond pulse generator. For nanosecond pulses coaxial cable windings former I was using old mini-Tesla coil inside. But on that Tesla coil there was additional coil with 0,65mm diameter wire and I was trying to get best results with sparks on it. I was tuning nanosecond pulse generator and somehow connected capacitor to that coil. And it hit me with current discharge. Completely different from high frequency burning spark from the Tesla coil. And there started following experiments to that direction. I do not claim my device is most optimal but I did get most important effect and I will be optimizing it and will research the resulting effect in device. One more IMPORTANT detail - WITHOUT GOOD EARTH GROUNDING - DOES NOT WORK
« Last Edit: 2023-12-23, 04:26:47 by T-1000 »
I think it is good time to see if pulsing with nanosecond pulses or Tesla coil discharging to coaxial cable would influence coil with capacitor. And additional inductor winding from push-pull with ground connection in between. Just to verify if I can get same effect Dally found. Then take it from there.
And somehow I missed previously when Dally pointed to where he started.
Will start with 1mm diameter wire coil and capacitor inside of 0.34mm inductor coil then will wind coaxial cable on top when it will arrive. The mystery need to be solved.. :) And PCBs also need to be made (will use https://www.pcbtrain.co.uk/services/pcb-fabrication service since they are asking fair prices for low quantities)
Cheers!
Well what would you think if i said my back garden
was saturated in the wet with slugs,  Same sort of difference (snails) hmm!
;D ;D :D :D :D ;D ;D ;D
Ok, do you remember me asking you what electricity was ?
your the the scientist ! and could it be your looking too hard perhaps?
Try this one what is water ?
Still looking to hard. Well they are both two elements.
The two magnetic winding's your talking about is called a blotch wall, John B
« Last Edit: 2023-12-25, 01:47:34 by AlienGrey »
T-1000
Recreating lighthing bolt = electrostatic charging by induction You were damn close with Lithuania experiment. Very few elements are needed, just Avramenko plug , special Tesla coil, coaxial capacitor and low frrequency discharge device to load.
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-04-01, 02:50:02
