2024-11-28, 09:53:23
Author Topic: Baghdad Battery ancient super cap?  (Read 3802 times)
Article
https://news.mit.edu/2023/mit-engineers-create-supercapacitor-ancient-materials-0731
The paper by MIT professors Franz-Josef Ulm, Admir Masic, and Yang-Shao Horn, and four others at MIT and at the Wyss Institute for Biologically Inspired Engineering
https://www.pnas.org/doi/10.1073/pnas.2304318120
Which leads me to speculate
Could the Baghdad Battery have possibly been some kind of ancient super capacitor?
Some were found with 'electrodes' next to them.
No. It was Battery for Acupuncture like Healing and making flying carpets and Elixirs and transmuting the elements. Batteries were what the world was left with after the last earth changes destroyed civilization. Without a rudimentary battery one cant play with Magnetism/levitation/healing/or any kind of "magic".
When they begin to use an alloy of Silver, they will be able to make 'capacitor/batteries' the size of pin heads that out perform a car battery.
Thinking and inventing using "ions" is fake science and hinders the advancement of real science.
Maybe you could provide the maths.
https://www.lehigh.edu/~amb4/wbi/kwardlow/conductivity.htm#:~:text=Silver%20has%20the%20highest%20electrical,97%20and%20gold%20at%2076
https://www.quora.com/What-is-the-reason-that-golds-conductivity-is-less-than-silver-copper
"Silver has the highest electrical conductivity of all metals. In fact, silver defines conductivity - all other metals are compared against it. On a scale of 0 to 100, silver ranks 100, with copper at 97 and gold at 76. Because of this property, and because it doesn't spark easily, silver is commonly used in electrical circuits and contacts. Silver is also utilized in batteries where dependability is mandatory and weight restrictions apply, such as those for portable surgical tools, hearing aids, pacemakers and space travel."
D2
Better to provide the 'elements' one uses, for man to use his traditional ways of 'inventing' new products.
Lets take, as an example, the invention of the poison called 1080. After 1079 mixtures and many more 1000's of Lab rats, they got the mixture to act they way they wanted on the 1080th time. Certain 'elements' like Chlorine, Fluoride, aluminium etc are known 'killers' of Life. That is, their Vibrations or elemental frequencies damage Biological Life or plant life as in the case of herbicides. So they sit in their Lab mixing these chemicals to derive a safe mixture to handle but does the job that they are inventing for. No Maths about it. The same goes with Metallurgy, they mix in small amounts of trace elements to get an alloy with the properties they are looking for. I nearly bought a 'batch' smelting oven from a manufacturer in Virginia where they sold lots of mini furnaces the size of a large washing machines for such admix testing to Universities all over the world to 'Invent' new alloys.
Each 'metal' has unique properties. Silver for example is a good conductor of VIBRATIONS. Its Crystalline structure of Patterned Tetrahedrons allow for the vibrations to easily jostle each other all the way to the end of the wire. A 'battery' is the utilization of these Vibrations between two dissimilar Frequency sources. For one of the elemental metals to be silver, rather than iron or copper in the Baghdad battery, will have a 'better' battery 'effect' and then like everything else they 'discover' or invent, the quest for miniaturization begins.
Gold is a super conductor at very low temperatures. Aluminium is the metal for 'increasing' these vibrations passing along its length. Platinum is the Metal that vibrates in harmony with the Mind or Biological frequencies. To make Mind Controlled circuits, they will use a mixture of Silver and Platinum and any craft that is controlled by the mind will have up to 60% Platinum in its shell construction. Some may have read that the Roswell crafts 'skin' had Memory to return to its original shape when bent. Using ones Mind to Program the Metal when manufacturing this skin metal helps to achieve this effect. But humans are still debating whether water has Memory or not and using maths to prove black holes exist or electrons are real with a Mass no less.
Cadman
I replicated the Baghdad Battery and many other circuits from ancient Egypt. I believe it was just a battery however the way it was used is interesting.
All the electrical related artifacts seem to come from an area around the Dendera Temple complex in Egypt. The picture below is from the temple depicting the Dendara lights. Here's where it gets interesting, on the far right is a man on top of a box with a cable coming out of the bottom of the box to the left side of the light. The man on the box is one terminal and the cable to the other end of the light the other terminal the same as we hook up our lights.
We could assume the box is a battery but as many critics claimed a simple battery couldn't light a large vacuum bulb as depicted. However if we look at other older high definition pictures of the box it was colored with a pattern of hundreds of small red and blue squares. They also colored small vessels with cables like the Baghdad Battery red and blue. Put two and two together and it seems obvious the box used hundreds of individual batteries in series to produce high voltage DC. Coincidentally today we also color code our batteries with black(-) and red(+) terminals...
In fact, early experimenters like Volta, Faraday and Ampere did exactly the same thing connecting many voltaic piles in series to produce higher voltages. This was the only way to produce reliable HV DC from batteries before induction and transformers were invented. If you think about it the only reason induction/transformers could be discovered was by first inventing small insulated wire conductors.
As well, in the picture just to the left of the man on a box/battery is another obscure electrical device. It's depicted as a Djed or Djed tower often associated with "stability". From the top of the Djed tower we see two arms extending upwards on each outer side of the bulb. Now put two and two together, the main problem with a HV DC plasma discharge in a vacuum tube is limiting the current. The plasma current in the tube would need to be "stabilized" in some way. I won't go into how the Djed tower works but can say it's identical to a device currently used in HV/HF plasma technology.
I think the technology is pretty obvious, they had battery technology, there is evidence they used many batteries in series for many purposes including electroplating. Add enough batteries together in series like Volta and Faraday also deduced and we get HV. They also had glass factories and were blowing glass so a large tube is not out of the question.
Which begs the question, why would people want to hide and obscure the fact the ancient Egyptians had some pretty advanced technology?.
Also connecting batteries in Tesla switch energy usage is incredibly prolonged. Have a look at this test https://youtu.be/wEesPlaSzWI easy to replicate.
FWIW at this point, what sparked my first speculation after reading the article and paper was the black residue on the copper tube interior. The residue in some of the batteries was decayed plant material. ‘Scholars’ speculated the batteries were not batteries but rather storage jars for documents for this reason. Having researched further I disagree and think they may have been AGM, Absorbent ‘Grass’ Mat batteries.
The Dendra "light bulbs" are Not light bulbs and they are a 1000 miles from where the Baghdad Batteries were found and about 8000 years apart in time.
They are Aetheric Vacuum Tube "Batteries". The 2 intertwined snakes is the clue to their usage. Joe only applies these batteries to one's Head and Hands. Anything else it boots you across the room literally and you'll hit your head on the wall. These are SCALAR pure flat line DC energy 'generators'. One Vacuum tube is Positive and the other is Negative for the 2 snakes to join together in the Healing symbol.
Joe has built about a dozen of them. I have alluded to them in other writings about how to make Batteries from Materials of differing frequencies or elemental states of Matter. We are Not up to this level of Science yet. Most here are still into electrons as the universes sole particle for energy.... derived from Particle Science Theories. Nothing could be further from the Truth and is the main reason OUR is failing to get us to the Stars with Heavenly science much less power our homes or Cars on the Energy of this Water Based Universe.
The Ungodly forces invaded Iraq and Looted these batteries along with everything else ancient by those who would have you Trust Their Science of Global Boiling now it is. It would have been easy to Elementally test the Frequencies of the 'residue' to determine it was an 'electrolyte'. But not any more so it enters into mythology like everything else ancient. THEY do not want you to know real science.
MerLynn
It's well know these regions were trading goods with each other for tens of thousands of years. It's also known the Egyptians were electroplating objects using batteries. So the Egyptians obviously had batteries.
https://www.ancientpages.com/2018/08/01/ancient-sophisticated-technologies-mercury-based-gilding-that-we-still-cant-reach/
"Electroplated objects were also found in Egypt by the famous nineteenth-century French archaeologist Auguste Mariette. Excavating in the area of the Sphinx of Gizeh, Mariette came upon a number of artifacts at a depth of 60 feet.
That's wonderful but I can actually prove my theory and even a child could built it. It's just a HV series battery connected to a mercury vacuum tube with a current limiter.
MerLynn
By any chance that tube could be a fluorescent tube ?
Here's a clue...
https://arstechnica.com/science/2017/08/plumbing-discovery-reveals-the-rise-and-fall-of-the-roman-empire/
The Romans had indoor plumbing, hot and cold running water, central heating, advanced water works and were exceptional engineers. However when the Roman empire was destroyed by fascist barbarians most of there technology disappeared for a thousand years.
Here we could ask why this fact of how advanced the Romans actually were is still unknown to most people. I think it's because England/Europeans reinvented the same technology a thousand years later and wanted to take credit for it. It's well known the English were destroying or hiding technology they deemed to be not in there nations interest. In effect rewriting the history books.
It's common sense and ancient civilizations having advanced technology makes everyone look stupid.
Imagine all these countries and scientists patting themselves on the back for being so clever only to find someone else did it better a thousand years before them?. It's embarrassing and many of there supposed discoveries and Nobel's would have to be corrected and taken back.
For example, who invented the battery?.
https://en.wikipedia.org/wiki/History_of_the_battery
This is complete nonsense and the battery wasn't invented in the 18th century by Volta. The Baghdad Battery and Egyptians electroplating objects proves the battery was discovered thousands of years prior. I have also proven by experiment that the ancient Egyptians understood static electricity, built static generators and Leyden jars thousands of years before the Europeans.
It begs the question, why are so many people being dishonest about our real history?.
I could answer your question if you are able to tell me why we have so many patents for FE some of them backed with working devices, but nothing comes on the market, yet we have even here on this forum shameless people that favour all tech for FE and/or overunity should be kept away very well locked … can you tell me ?
Yet it isn’t very difficult to short transformers in a circuit to have negative resistance, creating a symphony of waves, yet nobody have been able to do it properly and still playing with their expensive useless toys and tools, while some people outside can make it work without having an academic degree (at least not a recognisable by academia) and using just an soldering iron, a pair of pliers and a huge hammer to smash to bits all their pride as they deserve.
Also have a look at figure 3 on this thread https://www.overunityresearch.com/index.php?topic=2505.0 and tell me if you can find any similarities with Egyptian battery.
Cadman
A black/organic residue in a battery makes perfect sense if we think like a builder.
So I'm in ancient Egypt and I want to build a battery, what do I need?. The obvious choice for a vessel would be clay or ceramic well known at the time. Copper and Iron were available from mines and forges of the time. Next we need a separator to keep the electrodes from touching and hemp, reeds or papyrus could be used. Then we need an acidic electrolyte and citrus juice would do the trick. All the materials for a battery were well known and available at the time.
Now we have a mild citrus acid slowly breaking down/oxidizing the metals and the organic/fiber separator which could easily form a black residue. Coincidentally, the oxides or iron are dark brown/red but copper oxide is black. Having built and tested countless kinds of batteries and electrolysers I thought the oxidization problem was common knowledge.
It would seem to me the supposed experts didn't understand basic battery materials and chemistry...
I found this was comical...
"Scholars’ speculated the batteries were not batteries but rather storage jars for documents for this reason"
Yes of course, because everyone always places copper/iron metals and acidic citrus juice in with there papyrus documents, lol. Where do people come up with this nonsense?. No intelligent person should ever believe anyone would ever place documents in with a slurry of metals and acid. The supposed Scholars are obviously imbeciles.
Does the picture below look like a document holder, lol?.
« Last Edit: 2023-08-10, 18:50:42 by Allcanadian »
No its just a Single Wet Cell Battery that is the physical manifestation of its Inventor who understood the Esoteric Occult or Hidden lessons of Life     https://www.magneticwaterscience.com/?page_id=14
There's a reasonable explanation for how an ancient civilization could easily have advanced technology like what is shown below.
In all cultures there is a hierarchy and only the best and brightest work on advanced technology. So the battery/light technology shown below was probably only known to the elite and scholars. 99.99% of the labor population would never have seen the Dendera temple complex or the technology depicted in it. Similar to Area 51 where the best and brightest are given resources to work on defense technology 99% of people know nothing about.
Most make the mistake of using the "same-same" fallacy. Supposing because 10,000 ordinary people cannot do something the same rules apply to an extraordinary person. Which is complete nonsense because we know extraordinary people are doing extraordinary things most cannot all the time.
I suspect the Dendera temple complex was probably a school for advanced learning. Like all civilizations the brightest in the population who can do extraordinary things are identified and sent to higher learning institutions. Of course, just like today most people associate advanced technology with gods/religion which may explain why a place for higher learning could be mistaken as a temple.
Here one could ask where is all the physical evidence of ancient technology?. Where was all the evidence from the Romans technology after the fascist barbarian hordes pillaged everything?. The barbarians destroyed everything in Rome and Egypt, killed it, smashed it, burned it, melted it down and sold it for scrap because this is what semi-primates do. They are not builders they are destroyers.
@ AC. I agree with Hancock in that we are a species with amnesia.
"ms" History is seemingly mostly His-Story..
There are so many different interpretations of Human history and all that has transpired that any logical individual should be highly discerning of what they take on board.
Consider how some assert that Caesar only burned Alexandria after having looted the good stuff prior, for storage, and thus reference, presumably by the select few you mention.
This only makes sense however it is not, as far as I can tell, the most popular notion provided ..
I arrive at mostly the same conclusion as you have here, albeit with the inclusion of my own suspicion : Hawass and others in lofty positions - (by perseverance, dumb luck or inheritance) - still hold knowledge today, of the pre dynastic occupation and their abilities, that we don't.
Practicable knowledge that we could immediately integrate into our flawed understandings.
LIDAR shows there is indeed a chamber beneath the left paw of the Sphinx ...
Perhaps revealed in the wrong way today could be mixing oil with water as some say.
Or it could be straight greed.. and would improve 8 Billion lives exponentially.
Excelsior ...
The mantle of "Thug" could also be given to the Dynastic Egyptians who took it upon themselves to deface their occupied wonders, seemingly in a childish manner, as if they couldn't recognize the utter precision and splendidness of what they had found..
There's no way the original sculptors of the Sphinx designed the head like that on purpose  ;D
Why else would they commit such a travesty - unless burdened by a mass inferiority complex ? ?
Suffice to say we have devolved as a species in a lot of ways, not irrevocably IMO as some will have you believe, but we had better wake up and act as individuals, fast, before it is too late and the parasitic individuals in WEF , etc , who seek total control of the available resources achieve such ..
I wish Alex Jones was wrong in what he's saying .. I really do .. You can't deny some of it though.
I think the Antikythera mechanism is a good example of how advanced some ancient civilizations were...
https://arstechnica.com/science/2021/03/scientists-solve-another-piece-of-the-puzzling-antikythera-mechanism/
The critics would to tell me primitive Roman laborers built this precision astronomical device around 150 BC?. As the article explains, this device qualifies as the first analog computer built around 150 BC. Not as the historians claim in 1872 by Lord kelvin over 2000 years later.
As well note the time period, the Baghdad battery was supposedly built around 2000 years before Alessandro Volta's claim. This puts the Baghdad battery and the Antikythera mechanism in roughly the same time period. Ergo, if ancient civilizations had the intelligence to build a complex astronomical analog computer then a simple battery should have been a walk in the park.
The facts we know would seen to suggest the critics of these technologies are either grossly incompetent or there being dishonest.
This sounds like Baghdad Batteries were used for electro acupuncture. According to Bob Beck traditional acupuncture is 50% efficient, electro is 80% efficient and induction stimulus acupuncture is said to be at 95%.
They were using aluminum fire starters, with a quarz crystal that discharged 14kV-20kV. Hook up a model T4 induction coil and a battery. People zapped with this impulse wave/high non-linear spark at 4 acupuncture points, walk away without pain they had for years.
There is anyone who have replicated these batteries ? I need some sizes for copper tube and iron rod, also is it just clay or terracotta, the recipient, need to be glazed inside as well ? I need a power source for my setups and i think this one would be quite nice.
Or should i make a zinc-mercury oxide battery and watch how is charging itself ?
Why we are looking to dead storage instead of something “alive” like an electric pile ?
I wonder if these Bagdad batteries were used in one wire transfer system when we see they have only 1 pole standing out, I mean the iron rod looks the single pole connection.
Also, i have seen many mentioning citrus juice as electrolyte … but every time when I thought about these batteries I had in my mind vinegar  ???
Given these batteries were stolen from the museum by Invaders from the Pentagoons, it was reported that a pair of electrodes or "needles" with wires attached were found with the batteries.
It would be very naive to think vinegar was the best electrolyte available. Such is the Dumbness of Academics. They wanna talk about 'electroplating gold' but no acid was invented to dissolve gold at this time in history. If the MAGI had batteries the Technology would have been given in the SAME WAY it comes to Joe.... Divinely Given. So the inventor would have no trouble sourcing whatever electrolyte he wanted. You cant reverse engineer Technology without knowing where it came from particularly when its OOPARTS
So you want specifically the Vibrations of Zinc and Mercury for just what exactly?
Thales also said that Life is in Everything as did Tesla and Aristotle. So in actual fact all batteries are ALIVE. The God Particle is the Light Crystal. Perhaps these Iron/copper batteries are self charging? Like the Spitfire Battery made from copper and salt water....
For those who understand the Universe is Mental, No schematics or IP is needed. You ask for Divine Guidance for what you have available to use. There have been replications of these by interested parties. Dr Google may help
For the car battery replacement  with ultracapacitors:
https://www.youtube.com/watch?v=XNmkXyhE4l8
https://interestingengineering.com/science/could-ultracapacitors-replace-batteries-in-future-electric-vehicles
and from science  point of view explanation is here:
https://www.tycorun.com/blogs/news/supercapacitor-battery-power-energy-storage-black-technology
Wesley
Nice thread derailment there for someone who hasnt a clue about how Intuitive inventors invent.
Anything "battery" for EV's is a cluster fuck. A retarded understanding of Energy, Frequency and Vibration as the parameters for understanding the Universe.
The Largest EV charging station in the world is powered by Diesel generators at the Tesla Conjob Station in California
Silver is the Metal to make super batteries from. The size of a pea will power a car. but youse all aint up to that yet. First we gotta solve the Magnet orientation for the samsung motor. Almost done with the theory and ready to post. Just gotta finish hay baling.
Joe has infinitely better Electro-stimulation.  Bob Beck has not the Esoteric Ability to use batteries to heal. He knows not the Polarity of the Human Body or the Polarity of the hands and feet to attach a battery to. His zappers BURN the Skin. Physician first do no harm.
wlw has a copy of the official Joe Charging Up instructional video. We have fixed thyroids, numb limbs, tinnitus, bi polar, blindness and can provide an Ozone therapy with several Polarities of Ozone. Never need a Dr again. Combined with the Aqua Chi Med Bath, never need a Dr again for ANYTHING. But will expand on that later too.
The lack of Pain MAYBE caused by just shorting out the bodies electrical system and thus the no pain. There is a right and wrong way to do this. Traditional Acupuncture can only be practiced by some one with esoteric abilities to see Auras or magnetic Fields and the Flash Points we call acupuncture points.... otherwise its a hit and miss from an UN-Qualified needlier and they have NO WAY to SEE the results of their actions.
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2024-11-28, 09:53:23
