If anyone needs free generation of high voltage lights here is a very simple and basic design: Get some good quality coaxial cable of decent length make a good connection at one end with a dipole antenna to pick any signal available in your local environment. On opposite end loop high value resistor, the higher the better. Do not ground it ! As impedance will improve by grounding as for standing waves we need to mismatch impedance between antenna and load. Find nodes and antinodes for standing waves and tap your high voltage capacitor into them.
Now you have your hv free power source
You may want to add some negative resistance this circuit employing any method tunnelling diodes, ballast etc.
Edit: I would collect every single old neon tube ballast I could find or buy if I were you.
Enjoy 😉
I’ll be back later with some more details upon my availability as I’m a bit busy
