2025-07-26, 12:38:04
Pages: 1 [2] 3 4 5
Author Topic: Georgia Shop Technicians Ran Briggs Mower Engine ONLY Water In Carburetor 2008  (Read 28780 times)
I recently rebuilt the S1R9A9M9 triple coils assembly using a stronger copper #10 gauge wire, as the spiral frame that holds the 90 degree insulated windings. This electromagnet is an unusual hand wind, and was used in conjunction with the demonstration test of Briggs 18HP mower engine on mineral water only in 2008. (See also photo of the similar -S1R9A9M9 Megatran The magnetic field in the combustion chamber comes from  the bare wire having magnetic induction. The 6-7-10 amps comes from battery as start, then the alternator was actually running the show with bridge rectifier added. The set up must adhere to several purposes. Magnetic field to spark plug, retarded timing by means of magnetic field, battery current flows THROUGH spark plug, and  influence of 90 degrees wind that adds interference to the high voltage attempting to back up to the battery as safety hazard. (They didn't use at the time, a one way protection diodes bank.) I estimated hydrogen fuel spark plug electrolysis and water vapor pressure generated from 10 A + 4.5 Amp from the alternator maximum output of 14.5 amps full wave DC. No  voltage regulator for idle RPM. The electromagnet was to be always ON. The main power amps was no more than 34% duty cycle. This 2008 Youtube demonstration was the replacement for not using the non available obsolete dual coil relays and DC to AC inverter box.  Power circuit resistance is required to not have shorting, and after careful research, the same circuit was most likely included as - diode, coil, diode, coil, diode, parallel diode,  to spark plug. This allows for actual ohms as required and also possible Radiant Energy as in my prior notes. My design includes the same exact inductors values as was done in Georgia of 2005-2012 as 60 cycles resonant, as with the 60 cycles Inverter half wave DC used. I need a short reply, so as I know someone is also following this data.
I finally got around to test the spark plug that was used in Nathren's Briggs mower water engine demonstration from YouTube 2008. The 18 HP normally used a long reach 4000 ohm plug. I proved it was possible to send 10 amps through the replacement that was used back then. The electromagnet to ground had about 4.5 amps draw 100% duty cycle, while the spark plug firing of 0 degrees to neg late timing 34 degrees was about 34% on time of 10 amps draw. The engine was self running as after the battery was disconnected, the 12 MAGNETS powered alternator provided about 15 amps with bridge rectifier added at idle speed.
A quick bench test was done to test the old document regarding the S1R triple coils assembly. A neon bulb NE-2 was placed across the 2 end insulated wires to test for 100 volts coming from leakage induction from the bare copper wire under the S1R coils. The bulb did light up when the ignition was fired to spark plug. I had read way earlier that others had grasped the 2 wires and had gotten shocked.
 The old documents also said that about 100 volts and 6-7 amps WAS REQUIRED- through the spark plug for the mineral water conversion of an engine. The other document was called the "60 turns coil test".  60 turns insulated wire over plug cables used to assist the 6-7 amps to spark plugs. Not tested as yet. A bench test could be done without an engine first. 2 spark plugs bench mounted as 1st to fire with ignition only. This gets the required magnetic field for the Briggs mower engine timing change and the cylinder process. The 2nd plug gets the amps , the low voltage, and the needed minimum 100 volts. There are 8 methods to do this, but the one done in 2008 was not exact talked about. The plastic tub mounted on the side of the Briggs engine of the 2 Youtube videos, was to hold the majority of added parts. To get 15 amps or higher output, a bridge rectifier would have to be used with the alternator. That type of rectification is not pulsing DC as with one diode. Pulsing DC can run a hand wound step up voltage autotransformer.  Magnet wire wound on outside of the Magnetron could also generate the 100v as another secondary winding with diode. AN inductor 1.75 Millihenry was included and may have provided a back EMF of over 100v. This would be SUPERIMPOSED over the low 12-35volts DC. The same ground is used. The spark plug small electrodes IS THE WATER electrolysis cell. Untested as yet for bubbling action gases evolved.  Water vapor pressure also contributed to piston compression.
 For example, flashlight battery 1.5v turns on light of 1.5v bulb.  When 2nd battery 1.5v is added in series, the bulb is twice as bright because of the 3 volts total. Therefore, if the engine conversion power supply 12-36v DC is in series with the safety diode + insulated wires turns from the triple S1R9A9M9 coils, the total voltage to spark plug is approximately greater or equal to 140 volts DC.  DC is required to make hydrogen fuel from water. The tiny plug tips in combustion chamber need way higher voltage to get FASTER Hydrogen gas generated. The salt water droplets from eye dropper added to plug tips on bench test, forms ohms resistance electrical load electrolysis cell that reduces the first preset 6 amps on current gauge, down to .1amp. Therefore, much higher voltage is required to get the same 6-7 amps ,-----------JUST AS THEY SAID MANY TIMES IN THE WEB FORUM!!
Many years back, there were 2 other people confirming their wiring conversion DID operate their engine on water in carburetor at idle speed. The running engines on mineral water in carburetors was the successful 3 Georgia technicians' shop work done 2005-2012, and written up in the now closed web forum.
« Last Edit: 2024-02-24, 19:46:50 by russwr »
Multiple "lower volts" neon bulbs voltmeter, <1000v,  can be used for testing the cross leakage induction volts, that's transferred from S1R9A9M9 coils assembly, and in series with "power low volts" line going to spark plug. This was to add minimum 100 volts to the power supply, so that proper gases evolution is allowed for electrolysis and Hydrogen gases formed at those tiny electrodes. The 1st. photo is my current version of S1R9A9M9 triple coils assembly that provides several functions at the same time, as per the original one made by Nathren in Georgia from 2008. The 3rd photo IS this original, unusual, hand wound electromagnet - triple wires assembly. Steel core under 13 turns #14 as special wind, and 7 turns 90 degrees special wind #14 on 5 turns #12 plus 1 line, bare copper wire with no core. (See tap joint point with frayed wire ends, on coils , where wire connection was done to ground with resistor, so as electromagnet is always on, creating magnetic field that travels to spark plug tips.) The engine timing is adjustable during starter use, by adjusting the center core of inductance- one of my improvements. The two Youtube S1R9A9M9 videos of Briggs 18HP engine running - idling- on mineral water in carb, from 2008, is available for viewing and storing on computer.
« Last Edit: 2024-02-27, 04:21:40 by russwr »
The "Smack" video reference mentioned was about him draining out fluid from the Briggs engine. There was antifreeze mixed with oil + small amount of gasoline. Nathren did add all that that ahead of time when the Federal agents came to his property to investigate free energy claims. He didn't want to deal with them and get in trouble with national claims on You tube. They smelled the gas , and then were satisfied and left. The engine was then, left in his garage as is, until Smack showed up. He made several mistakes while he was there with the engine, that I noticed. - Not a qualified engine man or investigator.
There were, many years back, written statements I found as to 2 other people who had duplicated the S1R engine conversion, and their engines had idled on water in the carburetor. - (Hydrogen + water vapor pressure)  A wire inductor 1 millihenry was included in circuit. Another  statement I received back, did not give exacting details, but said,-- "YOU WILL BE PLEASANTLY SURPRISED" - which I took as another positive response!
The S1R9A9M9 triple coils assembly is an ELECTROMAGNET with extension coil . (Not transformer) The magnetic field is always on, 100% duty cycle, while the 7 turns coil waits for the high voltage pulse to fire spark plug. The included other inductor is charged, the following diode is ON, and then the high V. pulse hits the diode cathode shutting it off. The pulse reverts back ,and fires plug. The main 10 amps then goes through plug with ALSO the greater than 100 volts in addition to the battery volts. You see, the S1R coil also gives off cross leakage induction voltage that is in series with main power.  In a regular low efficiency electrolysis cell at low volts, it depends on large square inches of electrode area for amps allowed and amount of gases released. The spark plug tips are way smaller electrodes and require way higher voltage to get FASTER gases evolution. This is what the Georgia 3 technicians came up with during 2005-2012..
There are 7 methods to get higher volts to ADD to spark plug. Many parts were in the plastic tub hanging on side of Briggs engine. A small autotransformer same size as S1r coils would also fit in the tub. The web forum mentioned car engines paragraph about 60 turns over spark plug cables for induction into the amps line.The original sealed relay physical size, with 2 coils and diode that was used on all car engines,also fits in the tub. It is now assumed that the S1r coils formed the required magnetic field for spark plug and also at the same time provided the needed 100 volts. The 100 volts was mentioned many times in the web forum. They said the  cylinder "process" carries over to the next revolution of piston. The mineral water is conductive and is sustained.
.If you watch S1R9A9M9  video 1 again at low speed , you can see the 3 wires from engine top going down into plastic tub to the other parts. The white #12 gauge wire at bottom of tub takes the High V, the low V, and 100v , and 10 amps to spark plug. The ground connection for ELECTROMAGNET comes from the added extension cord connected to ground exactly at plug, and the other end of the " V" to the plastic tub. The cord male plug end is breached together.
Hydrogen fires extremely fast and requires late negative timing ATDC. The Electromagnet magnetic field formed , OVER PLUG WIRE BARE COPPER produces a continuous spark from 0 degrees to minus 34 degrees before shutting off . It was just easier for the 3 technicians to make a wire coil than do machining for aluminum curved bracket with curved slot for relocating BRIGGS ignition Magnetron for manual adjustment of timing , like on the old engines of movable distributors.  You got it now?
In the past, there has been controversy regarding whether or not the photograph of S1R triple coils assembly from 2008 was hokey- fake, because of the highly unusual winding of the wires. THERE MAY HAVE BEEN ANOTHER DIFFERENT ONE THAT WAS REALLY USED FOR THE FAMOUS 2 YOUTUBE VIDEOS OF 2008. Please refer to the photo of earlier messages.  I had made many versions of it over a considerable amount of time. Recently I looked at this in a different light. There are 3 reasons I believe that one SHOWN was the original , and was actually used during the two 2008 successful demonstrations of Briggs 18HP mower engine that ran on mineral water in carburetor.
Get this -- (1) First we were told that the coils had electromagnet that was on all the time. That means a wire had to hook to ground for completed circuit. There was an external extension cord that connected to ground, if the male plug was bridged together. The photo of coils actually shows a wire cut off with frayed ends. SEE The PHOTO FOR THE JOINT, it has 3 wires together with black electrical tape. The unit was removed from plastic tub on side of engine and taken into house for photo to put on Nathren's web forum. Nathren later said he was going to show another video of coils winding method, but showed one of take apart only. The unit placed on the table was the exact same one verified. He had previously removed the THIRD STUB WIRE and retaped up the joint, so as during the take apart video, no one would see the 3rd wire.  You can see the difference. He did not want people to know about the electromagnet connection to ground.
(2nd)  There were multiple statements regarding an extra 100 volts was necessary going to spark plug along with the 12v battery + 12 magnets powered alternator lower voltages. The bare wire under the insulated wire can cause cross leakage induction of 100 volts - not 6000 volts, due to the GREATLY LOWERED ignition volts from the self powered Magnetron. (The plug IS conductive across the tips)
(3rd)  - The end use was not spark plug firing in the air, or under compression with open electrodes of plug. Engine was running on conductive mineral water covering the spark plug tips in combustion chamber. The high volts fired from the Magnetron passes through the triple coils assembly using BARE COPPER #12 gauge wire. The outer wrappings were #14 gauge insulated wire. Normally, high volts from bare wire would jump- cross fire into the TAP JOINT and travel to the side ground , and bypass, not fire spark plug.  But now Magnetron sees about 20 ohms of low resistance of conductive mineral water! This greatly lowers the high volts. The lowered voltage now travels through spark plug . The other power wire now WITH THE ADDITIVE 100V IN SERIES, then fires 10 amps through spark plug forming Hydrogen gas electrolysis fuel and fires it. Also water vapor pressure is  generated that aids the piston pressure of engine. All this happens in an instant of time. I now believe the ORIGINAL SHOWN S1R coils was viable, and no other coils assembly was used.
[Thumbnail for SiR-coils-Assy.jpg]
Currently researching the S1R9A9M9 methods of adding additional higher voltage to the engine's lower voltage electrolysis spark plug end use. The extreme high resistance air gap at tips changes to electrical load of 22 ohms resistance or higher with conductive mineral waters as a tiny cell. The extra volts added then allows 6-7 amps to flow, rather than .1 amp,  creating sufficient Hydrogen and water vapor pressure to sustain all his previous engines converted with zero ohm spark plugs, and making use of "cross over leakage Inductance voltage" as superimposed and added in series with main DC power wire. We are assuming that's the way it was done, but there are 6 other methods to consider. This was Nathren's and his son Nathren's  and shop technician's invention during 2005-2012 Georgia. His wife's car 1978 V8 El Camino tooled around on 18MPG water before being locked up in security garage after 3000miles on water in gas tank. (EGR must be applied to smooth out engine running because of the Nitrogen compound being reused and piston compressed from the water.)  Later, when a substitute welded steel box replaced the car gas tank, some drippings from exhaust was reused and greatly increased MPG again. I won't say what was told about that, from the now shut down web forum. As for his last, Briggs mower engine conversion, there is sufficient room in the plastic tub hanging on the side of 18HP engine from YouTube videos , to hold a hand wound  step up autotransformer for => 100 volts to use, similar size,  and along with the S1R9A9M9 triple coils assembly. Got it?   Bench testing about 2013 by Daniel Donatelli -Issue,- "Explode salt water upon demand" pgs92-97, Document showed voltage applied to spark plug of mower engine of 100-240volts DC allowed the capacitor discharge to turn over engine with FORCE, with electrolyte water in combustion chamber. (Closing in on the relentless water engine - stage 5 of 6 stages.)
« Last Edit: 2024-03-05, 03:43:24 by russwr »
I did this awhile ago. I put 120v thru rectifier and isolated the coil with a diode string. Makes a huge spark. Never could get the timing right
What you have there is a hybrid of the Kapandze coil and Otto's one wire setup.
If you increase the DC field through the center you are creating a larger field for execution against instead of trying to get the secondary to ring on its own.
Right now you have to much iron in the center for the event to use the saturation as a bias.
The balance you need is the lower iron content to field ratio so the activity can bounce across the field instead of getting slogged down by hysteresis which then exudes as heat.
Get it?
GK
The balance you need is the lower iron content to field ratio so the activity can bounce across the field instead of getting slogged down by hysteresis which then exudes as heat. Get it?
Indeed, it's kind of strange to think an engine can run on water as a fuel, water is not a fuel but it can act as an energy carrier.
For example, suppose we see a strange circuit which powers an electrolyzer or fires a spark plug. This is an electrical effect and the engine and water has little if nothing to do with the energy gain which came from the circuit. The water and engine is simply an after effect, a means to utilize the energy gain.
There is also the issue of people seeing what they want to see versus what is actually present.
For example, if we hooked up a spark plug to the Kapanadze device should we say a spark plug and water produced an energy gain?. Well no that's silly and it should have been obvious the spark plug is just a spark gap, *light bulb comes on*. Thus what we would actually be observing is a means to utilize extra energy within a spark gap not a supposed "water engine". In fact many FE inventors like Moray, Gray and Tesla skipped the water/engine part altogether and simply extracted electrical energy directly from the spark gap circuit.
The electrical circuit for the water powered mower engine has several voltages involved that you have to be aware of.
(1) fully charged  battery voltage
(2) Inverter box secondary AC voltage
(3) AC voltage reducer box voltage output
(4) Full wave rectification DC block output power voltage
(5) Voltage drop loss adjustable power resistor
(6) Voltage drop loss 15KV series diode bank
(7) electrical load spark  plug conductive electrolysis cell voltage across
(8)Ground return line 1 ohm resistor voltage drop back to Inverter ground terminal
(9) In series "added" voltage from cross leakage induction volts from S1R triple coils assembly
(10) Briggs alternator ring output AC voltage
(11) Briggs alternator voltage regulator output DC charging voltage
(12) voltage drop loss from accessory in series spark gap with spark plug
(13) voltage drop loss from inductor 1.5-1.75 mh in power line
E/I=R,    E/R=I ,  I X R =E  Voltage drops in series add up to supply volts.
An electrical meter as multiple neon bulbs ,or digital readout voltmeter will only register the highest voltage at top of the spark plug. What's there, is about 35vDC, 100v added DC, and variable high ignition volts DC. What is also needed, is to measure separately and KNOW the crossover leakage volts that ALLOWS the spark plug cell to make sufficient hydrogen gas.  This voltage is adjustable by using the common spark tester with screw that adjusts ,as used by auto mechanics This is the accessory spark gap.and is in line with the 2nd inductor, and spark plug to ground. ( With the plug gap covered in conductive electrolyte such as baking soda water, salt, the plug gap greatly reduces the high voltage. The 1st spark gap can regulate the final gap, and also the needed induction crossover volts that pushes faster hydrogen gas.The S1R9A9M9 coils has the 2 red wire ends that receive the induced voltage. The number of red turns can also be adjusted as 7 or higher.  The GAP adjustment is done to get this induced voltage sufficiently high. Remember, the diodes bank must cover the highest volts ,so as no return damage to inverter or battery. The Briggs engine is called a 4 cycle and has what's called WASTE SPARK. During that spark period time of flywheel rotation, of no moisture plug gap,and  is an open air gap, the ignition voltage jumps up way higher. Now you see this is a more involved design for a bench set up. Temporarily, I use a small old style Harley motorcycle ignition coil can with push/release  points switch and condenser for immediate testing with high voltage.
On the old cars with high mileage, after dark, you lift the hood and see sparking going on with the ignition wires. They are worn out from overheating and needed replacing. The engine was running uneven because of crossover induction. The 1978Waterfuel web forum, that's now shut down, had page reference to car ignition thick insulation cable wire wrapped with 60 turns insulated hook up wire for purposely getting crossover leakage volts!
« Last Edit: 2024-03-16, 03:05:08 by russwr »
More data for those who may be following this S1R9A9M9 project.-
I just mounted a small Briggs engine to test compression "USES". Tests done way earlier by another researcher (on Internet), found out that a capacitor charged to 200v and 500uf and fired into salt water at spark plug would move lawnmower engine piston one revolution. The high volts didn't seem to matter to him, though. Notes gathered from the S1R website indicated that a crossover leakage inductance voltage , possibly capacitance effect, did transfer => 90 volts, as indicated by glowing neon bub. Other parts were indicated as used in the 2 SUCCESSFUL 2008 Youtube videos, but not told. I assumed it was diodes and an accessory spark gap. NOW I see a good reason for it. Spark gaps in air are as 3Kv /mm gap. 2mm plug in air is about 6Kv. Under engine compression that would be about 6 X 5 as ratio of a Briggs engine compression is 5.8 :1. Now, if an in line series gap is ADDED , the spark plug stays at the same voltage. (Plugs only fire at the least volts needed) The sum of 2 gap voltages equals the beginning ignition coil output.  If the total is INCREASED, then the crossover volts (of the S1R coils assembly) increases past 90volts, so as being in series with the amps current line through the spark plug also. 100-200volts can be realized with the low volts included. Nathren and other 2 shop technicians had said several times, about 100v and 6-10 amps is needed for the electrical circuit for creating sufficient hydrogen gas fuel from spark plug electrolysis. Salt water cell at plug TIPS is about 22 ohms resistance - not zero ohms, and requires higher volts than 12-18vDC to push 6 amps through the tiny electrodes. E / I = R,  I needed X R cell = required voltage.   E total high volts = E1 plus E2 spark gaps.
 Other statements regarding the earlier car engine water conversions in Georgia had told of a special test done with 60 TURNS insulated wire over a spark plug wire and getting crossover volts. This technique may have been used on all those car engines, along with EGR. (They had also talked about  interference reactance ohms from crossover leakage as a connected circuit of 12v and 20 amps, through amp gauge being reduced to 12 amps flow through load resistor when plug was fired.)! What do you think now? (Closing in on The 2008 Georgia Briggs 18HP engine that ran on water.)
 How To Increase High Volts Of Lawn Mower Ignition Coil?
Another method of increasing lawn mower high voltage is to add a series spark gap in line with the spark plug. The plug in air gap of 1mm is about 3KV. Under compression of Briggs engine , that would be multiplied by about 5 as 15KV. The compression ratio is 5.8 to 1, as squeezing more air into smaller space. The spark plug will not increase in volts after compression if the load stays the same. The 2 spark gap voltages will add together, making the ignition coil (Magnetron) raise up to a higher level !  This higher ignition volts can THEN  be used with the S1R9A9M9 triple coils assembly to be able to get a higher crossover leakage induction voltage that would be in series with the main amps line, with the low volts, going to spark plug. The electrolyte salt water at plug gap needs a higher volts  (100-200v) to be able to force 6-7 amps THROUGH the spark plug . The water solution at the spark plug gap is NOT zero ohms, and is about 22 ohms.   Formula E needed voltage = R X I.  ( Electrolysis of water at engine spark plug to get sufficient Hydrogen to run engine at idle speed at a lower power level.)  Nathren's earlier  web forum had various tech data that was gleaned before it shut down.
Since the spark plug electrolyte cell requires over 100 volts added on / superimposed in series to the low volts power supply to get the 6-7 amps through spark plug of about 22 ohms CELL, there is another method to do this without relying on the leakage voltage transfer from the S1R9A9M9 triple wires electromagnet assembly section. A purchased miniature power supply module as DC to DC converter, high frequency, 150W, with fast rectification, can be used with power resistor ON THE INPUT BATTERY side to limit the power/ current way down, and get mostly the higher voltage needed ON THE OUTPUT SIDE. It's called isolated- "150W dc12v to AC220v power inverter module. The small board also has  built in optional use, full wave rectification output .The selection jumper also allows for 110/220v,280v AC. This is the upgraded, now better unit on Ebay. The regular box Inverter to DC  use higher wattage power supply will send the amps + wattage, while the small P.S. board supplies the superimposed higher volts required (in series) to push the 6-7 amps through the ohms resistance of spark plug electrolysis electrolyte at those plug TIPS. Since the small board is basically an Inverter with no connection between primary side and secondary, it's called ISOLATED as per the grounds connection. The main unit P.S. would be also like that. Smaller inverter would have volts reducer resistor on input battery side and use the 280v setting to get about 90v output.  (Resistor cannot be on secondary side, as it would also limit the main other previously adjusted P.S. The LOAD cell is the resistance for BOTH.) Again, there is also what's called waste spark, which during that time of flywheel rotation, the intake valve of Briggs engine is closed and no significant water at plug.
 (Your flashlight has multiple DC volts batteries in series to raise up voltage for the bulb.)
« Last Edit: 2024-04-01, 18:33:09 by russwr »
This was a circuit from 2008 on a mower engine that purposely allowed crossover leakage induction volts from a 5 turn wire  onto an adjacent 7 turn wire, WITHOUT core, so as the in series volts is increased from 12 to over 100 volts. Was this brilliant, or just a cheap method of increasing a lower voltage. See photo of S1R9A9M9 triple wires assembly electromagnet on internet images. The LOWER only section of 13 turns had steel core. This was in reference to HIS (2) YouTube videos that can still be seen. . (On  old, worn out ignition cables, they spark across in the dark at night when you lift the hood on bad ignition cables.)  He put the inserted section with spark plug cable  to use for his project in 2008. Is this type  called capacitive voltage induction? My first test on this showed a neon bulb glowing with at least 90v, FROM ONLY THE 7 TURNS WIRING, not electrically connected to 5 turns.
The next step is to add accessory spark gap, which does not affect spark plug firing. As the input Ignition coil is then forced to INCREASE to compensate, the leakage crossover volts would also go higher. ( I believe NOW THIS IS THE SECRET how Nathren and the 2 technicians successfully ran the Briggs engine on hydrogen generated in combustion chamber electrolysis and fired for piston force. If this is so, then all their other car conversions done earlier had made use of stated 60 turns over EXISTING spark plug cables!! E higher volts needed = 6–7 amps X Resistance of tiny salt water cell at plug tips.- about 23 ohms. Briggs had 5 turns bare #12 wrapped with 7 turns insulated, and then for the other autos,- thick insulated ignition cable wrapped with 60 turns insulated #14 gauge wire coil! What do you think?
Where did they get their information from?      To answer your question, I am referred back to the thousands of messages on the now shut down web forum, used by Nathren and others. Nathren was a non-technical person - at all., little formal education, just hands on work knowledge. His son, also Nathren, WAS a technician and worked for an electrical company. They had a part time machine shop/garage, where the other 2 TECHNICIANS also worked in their spare time on alternate energy systems-solar,  and electrolysis for hydrogen. Therefore, all 4 of them tinkered in the garage/workshop in Georgia. So now you know who designed and built the electrical circuits for the different car conversions and the mower engine that ran on THE SAME type spark plug electrolysis for hydrogen and water vapor pressure.  On the Waterfuel1978 forum, Nathren signed in as S1R9A9M9, and son signed in as Nathren. You could tell the big difference by the technical quality of paragraphs written. ( The code S1R9A9M9 came from a metal machining job done by contract for small part used on a previous NASA mission to space. It is a reference to MARS 1999 spelled backwards. That's what he had used to start up the original web forum to tell the public about the TECHNICIAN"S work on alternate energy projects)
I need a circuit for using only a standard lawn mower Briggs magnetron to increase high voltage output to 24,000volts! The flywheel magnet instills 5-8v PULSE ONLY, trigger shorts the primary to ground, then back EMF creates negative -130 volts to run the secondary side for negative 12,000volts. The primary is very low .2 ohm resistance. The metal core end connects to ground for secondary side and trigger side, + the trigger connects primary to ground. The open tab terminal is accessible for primary wiring . Can this be attached to 12 volts DC to superimpose on the 5-8volts, to get a higher secondary output? How? Mower ignition is called autotransformer with 3 terminals only. The aftermarket solid state trigger module called Stens operates when the voltage is indicated going into primary from the North pole magnet. The internal transistor switches on temporarily to ground. This connection maybe could be used for another transistor to instill 12v DC superimposed onto the magnet voltage. This would then instill a higher back EMF that runs secondary side for higher, high voltage. Also, a different burst oscillator mode, for single pulse desired, could be used and then shut down by the trigger. Maybe the 12v DC has to be triggered in, so that it doesn't short the primary winding to burn out. That's the problem. Ideas??? I have magnetic hall switches to operate a transistor to switch in the 12 volts. ( A voltage doubler circuit requires only AC input) The small unit being sold for autos is a high frequency oscillator that raises also up to 16 volts pulse to the ignition, - was called firestorm for as $8 to $75. A man in England on YouTube was adding parallel capacitor to TV fly back primary to raise up high voltage as the resonant frequency of wire and ferrite core is way higher, and run from high frequency oscillator.
I already tried increasing magnetic field by adding neodymium multiple magnets on top of North pole magnet with no volts increase. ((After 1982, The Briggs ignition coil had built in solid state transistor and trigger coil under the epoxy, and then all are called MAGNETRONS. - Uses same name as the glass tube oscillator in a microwave oven.)) The other model ignition Magnetron, with 2 ignition cables, has secondary side not connected to primary side. That dual cylinders Briggs engine fired one side negative high volts while the other spark plug fired positive high volts. The system is still single pulsed based,- NOT AC.
The way earlier pre-1982 Briggs ignitions were called MAGNETO with points + condenser, that used plain autotransformer without any solid state. I had earlier contemplated to add a south pole magnet next to North pole one, to get AC to run the Primary of a MAGNETO transformer, and use double universal triggers with blocking diodes to get it to run. Only then, can the common AC voltage multiplier be used to increase the high voltage on the secondary side. That is also still a primary+ secondary auto transformer system. If that was used , the secondary side has reduced high voltage, as the metal core has to be mounted upside down to get positive high volts. - The primary is not then part of the secondary when fired. Any ideas?
« Last Edit: 2024-04-18, 03:24:32 by russwr »
Another possible method to increase mower engine high voltage is to add a Hall effect sensor  circuit that senses the North pole field of the flywheel rotating magnet near the magnetron, and use the output pulse to turn on Mosfet for 12 volts dc to go to the tab terminal on the engine coil. That terminal is connected to primary, and is normally used to shut off the mower engine by the ground connection. Insertion of FAST12 volts superimposed on the 5-8v from magnet would increase the back EMF generated, higher than -130v,  so that the secondary side gets higher, high volts output.  A unipolar Hall, 3 pins, on the small board would have the leads bent u shaped so that the hall head faces backwards. This would allow the North pole to turn on the switch. After magnet passes by, the circuit shuts off. Mosfet power switch is way faster than a small relay to allow battery volts on to the Primary coil. A 3 ohm resistor would be put in series with the .2 ohm primary coil, so as about 4 amps flows, higher than the usual 3 amps.of primary ignition on a Briggs lawnmower engine.
 It was assumed that 24000 volts is required for the engine conversion, along with the equal or greater than 100volts cross leakage induction volts to push 6 amps through the spark plug water cell of about 23ohms, to get the hydrogen fuel and water vapor pressure at retarded timing -34degrees.
Here is the circuit we used when I was experimenting with this back in 2008.
Edit: This DID run the engine on water. But the timing needs to be adjusted.
Edit 2: Use a 100watt bulb in series with the AC to limit the current. It also lets you know that the plug is firing and if there are any shorts and etc...
Edit 3: This spark will be HUGE, use a big cap 500uF for the capacitor to store the charge. Rectify the AC to DC so the diodes work properly.
Sir’s
“Running on water”
Such a big spark …could it be a phase ( steam) change or was there some real power.. similar to a combustion event?
There has been mention of a super heated steam in years past ..
This itch just won’t go away…( and then there is the Sam Leach discovery with lithium nitrate at 20 ppm in water at 500 psi
Sir’s
“Running on water”
It's related the electro hydraulic metal forming. High current through water mist violently repels water
Still tinkering with the S1R circuits in relation to the small mower engine. I copied all the tech data from Nathren's web forum of thousands of messages, before it shut down 2019 . It was the 3 technicians that made the circuits for the cars + mower engine to run on water in the carbs, not him. His son, also Nathren, who was a technician, worked with the 2 tech people in their garage/machine shop in Georgia. .Lots of data in the forum but not all. I believe you call it proprietary company information. Nathren was a non-technical person with little educational background, just hands on learning. The techs worked as commercial electricians , and then in the shop spare time on alternate energy projects.
A spark plug as zero ohms, and carrying 6 amps adjusted with variable resistor and jumped with screwdriver holds the current steady. With salt water at the plug tips, there is only 1 tenth amp flow. This is why it was mentioned in the forum several times that  =  >  100 volts was necessary to pass 6-7 amps though the plug.. The 2008 Briggs engine ran on 10 amps.in the 2 videos, but wasn't necessary.  All the earlier S1R car conversions used 6-7 amps with retarded timing about -34 degrees.  4 cyl tractor, 6cyl car, and two  8cyl Chevy V8 engines. I'm on stage 5 of 6 with my long-running project. The ignition has to be inductive type , not CDI. The spark time has to be in milliseconds, not microseconds.  The factory timing on Briggs 1 cyl is at TDC. It was too much trouble for them to fabricate a curved aluminum plate with curved slot to make the Magnetron adjustable for late timing. They made an "electromagnet" to form a field over the plug wire to force extend timing from zero and on to about minus 34 degrees. The compression of spark plug greatly raises up the high voltage. An accessory in series spark gap forces an increase in Magnetron voltage also. This is necessary because of the required "extra volts" needed to push the amps through plug. That's why the S1R9A9M9 triple coils assembly had that weird winding method and bare copper #12. The crossover leakage induction volts into the red wire from bare wire ignition is in series with the low voltage and is sufficient . I amps required times R resistance of load  =  voltage required to push the amps through the electrolyte. The S1R coils is inserted, spliced in, and has several purposes at the same time. (Of course there are other ways of doing things) I purchased a low voltage variable meter with resistors and neon bulbs to measure this special voltage. First test says 90-110v. I am trying to get it higher. The low volts would also add to this in series when connected. According to the Waterfuel1978 web forum, all the engines ran on hydrogen gas generated at spark plugs along with some water vapor pressure that contributed to piston pressure. All the cars had a specialized relay PER CYLINDER. It wasn't until years later they found out what the box of 15 relays were originally made for. Utility pole electrical boxes in Georgia for switching the green/red 6v bulbs.of traffic signal lights. Extremely high efficiently made, with Bakelite housings , exterior screws and UNDER VACUUM.  Diode---coil L 1.75mh---diode--- coil L1.75 mh  ---diode---. to spark plug.  The high volts came in exactly at cathode of second diode.radiant energy release.  The technicians called them the MAGIC RELAYS. On a per cylinder basis, they were only used for the series of parts,- NOT AT ALL AS A RELAY. Hand made units fabricated by them did not work as well, so the engine conversions were dropped, since replacements are not available. In 3 months I  made up a duplicate unit in an electrical Carlon box under vacuum with the parts inside and gauge and terminals on the top. The secrets of Nathren's tech people was in the use of relays and the additional crossover voltage that made the engines run on water back at that time 2005-2008. .
The several car engines converted in Georgia also had the spark plugs changed so as zero ohms. The Champion brand ones come apart to remove resistor and replace with copper segment. The "Extra" volts (over 100) required to push the 6-7 amps through spark plugs also came from crossover inductance leakage volts. The text messages forum had a paragraph that was called "The 60 turn coils". The engine spark plug wires had 60 turns insulated #14 gauge wires over the thick insulated spark plug cables. When the plug fires, there is an induction volts into the coil that adds in series to the half-wave DC volts from the rectified DC output of the  DC to 110v AC 400W Inverter box, about 35v, DC Unfiltered. All this data must be the information that was missing years back, and not noticed.  When untrained people got hurt trying to duplicate the systems, Nathen and others changed the data on the forum, so some of it was now wrong, so as any further attempts would not work.
The S1R9A9M9 You tube videos from 2008, of the ORIGINAL Briggs 18 HP engine running on water can still be seen and heard!.
Just use the simple diode circuit we used above. The plasma from the spark switches the 120 over the plug, making a huge spark that drives the water down into the piston.
                                         S1R9A9M9 Discrepancies And Lies, And Corrections From 2008
This section is a grouping of data collected from the YouTube videos and original web forum called Waterfuel1978, regarding mostly the  TRUE AND SUCCESSFUL 18 HP Briggs mower engine demonstrations that ran on water during summer 2008 Georgia. Those who are following this particular hydrogen gas conversion need to know these things I found out over a long period of time.
Nathren + son also Nathren, gave data as the shop work progressed through various adjustments on cars and mower engine. Majority of thousands of messages tech data is true. Once a viable system is first completed, general information is given to public, but controlled to an extent. Priority confidential parts hook ups are kept out of released info. These changes and misrepresented parts have been verified by very diligent observations of all data found over time. Here is what you missed or didn't know --- Nathren (father) was uneducated as people can see from his writings on web forum. The son WAS a technician who worked in the Georgia shop with the two technicians on projects. The  father Nathren gave impression in web forum messages that he was responsible for these conversions and gave directions to the tech people. Not so. He did not know specially how sections worked as he was not the brains behind these engine conversions. His sentences had to be gone over several times, just to figure what he had really meant. Yes, it was that bad.
The conversion parts during 2008 summer demonstration were contained in a plastic deli tub, on side of engine,  spray painted gray to keep eyes out of needed information on the Briggs 18HP engine conversion to hydrogen gas and water vapor pressure. There were several other parts in tub not talked about. ( figured as accessory spark gap, diodes, wire connectors. After considerable amount of my  comparisons done on this special wind of S1R9A9M9 triple wires assembly, It has been found out that the picture shown in color, of the coils is really the original one used in the YouTube videos , (basic frame) but modified before being shown to public on that graph paper photo. The wiring directions have also been changed,- not only of the coil itself, but also the wire ends function and hook up.  The original unit used had a BENT  steel nail as core. See photo, as original. Others are copies with straight nail. When unit was removed from engine after the 2 videos, the wires JOINT extra wire with the red and gray, was snipped off leaving a stub wire with frayed copper sticking out . You can actually see that on enlarged photo on the graph paper. This was a separate connection used on engine. An actual ground connection, because this whole thing was originally a step down autotransformer type to increase current TO spark plug with ratio step up of 7 to 20 current from  3.5 to 10 amps. The alternator without modifications was pulsing DC 3.5amps maximum. The exterior extension cord has a Y with one end hooked to ground under plug, while other end goes to the tub. The main cord plug is breached with jumper so as this becomes one very LONG wire to ground for the transformer tap point. Now the high voltage bare wire of coils assembly, hooks both to ignition and to white #12 wire to plug. This 2nd joint actually had 3 wires- white 12 gauge + bare #12 wire + red #14 gauge together.  The main other joint also had 3 sections. Power comes in on the one gray wire from both battery and alternator.  Battery start was necessary to get alternator up to idling RPM for useable current output, to get the pulsing DC from the one diode to actually run a transformer. Either AC or pulsing on + off DC will run a transformer. The red wire and High Volts go to spark plug. NOW******The original S1R9A9M9 coils unit used ( NEVER SHOWN)  had to have had 7 turns parallel wound TOGETHER with the 5 turns ignition side. That makes the whole unit a transformer with steel core under both primary and secondary. With this particular step down voltage autotransformer, the 2 coils 13T and 7T together is the full Primary. 20:7  as 20 turns to 7 turns ratio. 1 to 2.8 as step up current ratio as 3.5 amps primary side from idling alternator before transformer effect to 10amps. An autotransformer type, has 3 terminals only. Nathren had taken the original from engine and loosened- removed the RED coil from the 5 turns high V as being in parallel, and changed it to 90 degrees wind , so as there would be no core for the red wire, and then no transformer to use.  This then, does not disturb the main joint that still has the stub wire. They did not want proprietary information let out, on how their system actual worked. He then said he would later show video on how to wind one of these. What he did though, on video was a "take apart" only. It was noticed that when comparing the so called original photo,  he had removed the STUB FRAYED wire  and retaped up the joint just before the take apart. You can see this in start of video with coils setting on table. (stub removed and retaped up differently. He did not want people seeing this 3rd wire piece falling out during video. (That was the ground wire tap for an autotransformer!)
In the 1st of the (5 ) S1R9A9M9 You tube videos, you can see the power wire coming down from engine upper plastic cowl going down into the plastic tub with the high volts ignition wire. Run video at lowest speed and see open spot where the black electrical tape had pulled down exposing the 2-3 wires. The heat of summer, engine heat, and the weight of tub of parts had loosened the glue , allowing the tape to slide down. By playing video back and forth , you can see the wires actually moving around. This power source was the FIRST proof of Nathren's real video! The old battery in video 1, was poor, so he hooked up a battery charger to add volts to run the starter motor. The water hose from bottle was placed in carb top chute. The hose was pinched slightly to get proper flow of water. Engine ran best during the later part of Video number 2.  (That's the part that will make you smile!)
The purpose of the (2) 2008 videos was to show an engine running on water only, using battery for start only, then battery completely removed, with engine self running as OVERUNITY, running on formed hydrogen gas and water vapor pressure. The on board ring dual alternators under flywheel powered by the normal 12 magnets provided the lower 3.5 amps that was subsequently increased to 10 amps. All the earlier technicians car engine conversions had 6-7 amps through spark plugs. The 10 was not really needed. My own triple coils made, has slightly more turns, as it will use 6 amps , but using the same level magnetic field generated, by increasing the number of turns on both sides by the same increase ratio of current 7:20. The required timing change is based on this same level strength of MAGNETIC FIELD  to time extend the spark in milliseconds to about negative late 34 degrees. The tap to ground  runs primary as the higher turns section , with the lower turns section being the increased current side. This is what Nathren didn't want you to know. It fooled me for a long time until I figured it out.
The related "Smack" videos, relating to the same 2 demonstrations, show the NON original, modified type unit as it has a STRAIGHT  nail, and the joint is removed. It's the one that has the 90 degree winding. (non transformer).  Smack came 1000 miles to Nathren's property to see an engine that ran on water, but was disappointed. Nathren never intended to show how it worked. The fool Smack never even tested engine to see if it would at that time even run on gasoline. The engine had sat in garage for long time before he got there, and it had seized up valves, no compression, from not being cleaned before storage with salt water from the original 2 demonstrations. He wasn't as smart as he thought he was , just like other young guys who think they know it all.
Nathren's  other porch video was coils unit connected to engine improperly as 'in induction mode", which would never work. In the 2 original S1R9A9M9 You tube videos, the green 400watt Inverter box was NOT connected as any power. That was there, in background to mislead people watching. That box was only used on only all the car conversions using special dual coils relay per cylinder, as parts use-, not for relay type use.
I had way earlier asked him for the engine model number. (For more data for me to collect.) He did NOT comply and wanted to know WHY I wanted that. I was concerned about what type alternator was on his engine. He replied that engine did NOT have an alternator and the flywheel had no magnets to run it. More lies. (Everybody knows that all riding lawnmowers have a working alternator to recharge the battery.) He also said he purchased the engine new just for the videos. Upon closer checking of engine surface, it was dirty, and it was a used engine removed from a riding mower chassis. With the battery disconnected during both videos,-there was no way to power the engine conversion circuit. It would not work without an alternator. The salt water as electrolyte at spark plug tips, allows more current to flow  with common electrolysis at spark plug tips. During piston downward thrust, the water becomes "VOLITILE" and changes to pressure vapor and expands also for more piston pressure. This all happens during about negative 34 degrees late timing, caused by the magnetic field over the inserted bare spark plug wire part of the coils assembly. Some of the field travels down to plug tips also. Exactly at the time of You tube videos release during 2008, Nathren was truthful and properly answering questions. Abruptly he changed stories and had redesigned coil, photos,  and hook ups so as repeat performance of an engine on water would never happen again.
They said back then, the initial car V8 conversion of 1978 El Camino was on 18 miles per gallon water only, road tested for 3000 miles, using required EGR to get the Nitrogen from exhaust to improve engine performance. Engines will start and idle on water, with way lowered power output,  but no power acceleration mode unless carburetor  jet is increased/redrilled about 33% larger hole for more carburetor water to engine. With an appreciable amount of RESISTANCE OHMS  in the electrolyte being there at plug tips, (10-22 ohms) a higher volts is needed to push the 6-7-10 amps through the spark plug.  I X R = E volts needed. That's what the UNUSUAL bare #12 wire was for in the S1R9A9M9 TRIPLE COILS ASSEMBLY. It's called -----crossover leakage induction voltage , and in series with the low volts to raise it up so as full current can be realized. Nathren said several times in the forum to use 10 amps and 100 volts, but neglected to say how it was done. The several previous car conversions done there in Georgia, with zero ohms spark plugs with saltwater/ baking soda also needed a much higher volts to push 6-7 amps. The web forum had only one paragraph saying 60 turns #14 gauge insulated wire over spark plug thick insulated cable as a test for "show". I believed that was a HINT on how it was done on all those other earlier engines. (4 cyl tractor, 4 cyl car, 6 cyl car, 1978 V8 cylinder car, and the V8 engine on engine stand self powering their full electric for the workshop with large generator attached, and just  the water line. Engine ran 24 hours all the time, never shut off. Engines must have EGR with adjustable valve added . Questions?
« Last Edit: 2024-04-24, 18:38:53 by russwr »
What's different with this set up by S1R9A9M9? How is this not like other set-ups for spark plug firing water that were tried?
The three technicians in Georgia 2005-2013 and Nathren, who was MOSTLY observing, decided to operate engines on water to hydrogen gas and water vapor pressure, without a separate built electrolysis cell.
1. The water has to be an electrolyte, - such as salt water or baking soda, not plain water.
2. The injection of current has to be limited to 6-7 amps DC. (Fast visual only done with an oscilloscope for pulses) or analog meter with needle. Higher current burns away electrodes.
3. Resistor such as 1 ohm used on ground side of spark plug tested with probes across resistor, so as scope not damaged. I = voltage read divided by resistance across one resistor in series.
4. The circuit must be in milliseconds, not microseconds.
5. Capacitor discharges through spark plug are in microseconds.
6. A circuit with plug that has low voltage 6 amps flow with amp gauge and series variable resistor pre set for 6A ,will show 6 on meter when plug is shorted to ground with screwdriver for a full connection.  But when plug gap changed to electrolyte, the gauge drops to 1 tenth amp flow.  A regular electrolysis cell needs sufficient square inches surface area metal at a low voltage. The spark plug tips are tiny and require much higher volts to push the same current. The electrical load has increased to 10-22 ohms. Therefore, a higher voltage 100v and higher is necessary to  push 6 amps through spark plug. The triple wire coils assembly of S1R9A9M9 has a 5 turns Ignition bare wire that induces into #14 gauge insulated wire a  greater voltage from crossover leakage induction volts. The unit was called Electromagnet and Booster coil.  This was to replace the dual L coils  of the specialized relays per cylinder that were used on all the previous car engine conversions along with the main Inverter box 110v AC to half wave DC.
7. The high voltage line requires inductor L of about 1.75millihenry to help with the reduction of spark speed. ( wire on insulated plastic bobbin holder only) (60 cycles coil at .6 ohm  reactance of L, as 1.75Millihenry, - coil of original relay)
8. The timing of engine for smoother running requires late timing , ATDC of about 34 degrees negative.
9. The factory Briggs engine was preset at TDC, so as the Electromagnet allowed the spark time to extend onward from zero to about 34 degrees late.
10. The timing point at lower piston travel allows water as volatile by the suction effect to be acted upon to expand to vapor pressure for additional pressure for piston.
11.  The magnetic field effect follows wires and increases efficiency,  and is at spark plug tips . Magnetic field reduces spark plug speed also as it is wrapped over plug wire.
12. The ignition voltage wire enters in exactly at the point of the cathode of diode/diodes protection bank.
13. Electricity always wants to follow direction of the least resistance.  DC Ignition attempts abruptly to pass through the ON DIODE backwards, as it senses a ground that way. The diode fast closes off, and ignition compresses , then releases back to do the EFFORT of JUMPING spark plug gap. This diode/ignition event  releases RADIANT ENERGY that follows to spark plug tips.
14. Ignition DC volts on previous cars were about 24,000 volts. Lawn mower engine Magnetron volts is lower, but can be adjusted upward with an in series, accessory, adjustable spark gap The car engines converted all had 2-3 spark gaps in series,- distributor rotor gap, relay contacts gap, and spark plug gap. .The compression effect on spark plug also causes Ignition coils to increase output volts.
15. Ignition polarity is to match the polarity of the current added to the circuit.
16. MANY fast recovery type diodes required for wiring circuit FR607.
17. Placement of parts in certain order for higher volts of crossover, as Ignition coil to diode blocks, to S1R coils, to accessory spark gap, to insertion point last cathode, to inductor, to diode to spark plug. (the 2 spark gaps in series have voltage drops)  Higher volts wanted on the crossover point .
18. Nathren said that other wiring design coils would work too. I assumed he meant the 5 turn bare wire #12, to be wound in parallel instead, together, wound, with 5-7 turns #14 insulated type for higher crossover volts.   (The 90 degrees regular S1R type wind would stifle some of the transfer volts). This then, would have core steel long screw
underneath for better magnetic induction effect.
19. The engine selected should have EGR  valve or EGR added with adjustable valve to obtain the embedded Nitrogen from exhaust which allows smoother running engine.
20.  Spark plug changed to one with same reach length, mm size, and with no internal resistor as an "R". A comparable R type as a Champion brand, can be put in vise with torch heated top screw cap removed , so as resistor is removed and replaced with copper wire segment #12. Now as zero ohms spark plug/ racing plug. This now allows current to pass through.
21. Briggs Brand used riding mower engine, 8-20HP can have alternator ring removed and changed for higher amps output, such as dual yellow wires type or dual black wires type, and also changed flywheel so as the underneath magnets are large instead of the small type. See photos EBay. Start engine with power supply, then recharge battery with ring alternator,or underneath car alternator added on.  Nathren and the Georgia shop technicians ran mower engine on just alternator without battery connected. Battery was used for circuit initial power only and the starter motor,  then completely removed. The Briggs 18hp  was self running on Briggs alternator only at a lower RPM.
See again the S1R9A9M9  (2) YouTube videos by Nathren and son
« Last Edit: 2024-04-27, 05:18:50 by russwr »
Pages: 1 [2] 3 4 5
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-07-26, 12:38:04
