measurement error
Electricity comes from a coil "harvesting" the invisible Non Physical IRON FILINGS wave form that activates or the VIBRATIONS of the Crystalline Structure of the Copper Coil at 50 to 60 times a second. The Coil is vibrationaly EXCITED. Inventing a device or meter to calibrate these vibrations and call them electrons or a FLOW OF CURRENT is falsely claiming where the 'energy' is coming from. It is fraught with errors in understandings and thus the design principle of a multi meter is not to be trusted when using this SOUTH POLE POSITIVE Metering Device with the Production of the North Pole Negative half of the cycle or Hertz wave or when the energy is entirely Negative North Pole energy and without Hertz as there is no Pos component so just what does the multi meter read then?
These Vibrations travel the entire length of the Conductive Wires from the power station to your Kettle and Toaster at the speed of Light to where ANOTHER COIL is used to create heat by the 90 degree interaction of the Positive and Negative nature of the Wave form or vibration 'cycle' of the Pulsed Field we call AC.
A Coil in all its configurations is only a Frequency to Heat (energy) Con-In-verter. The vibrations make the toasters 'element' or COIL heat up A Tesla Coil takes this conversion and also splits the 'phases' with its 2 windings. One to power the spark plugs and the other is used as Waste Spark Management and this WSM aspect or phase of the 'electricity' will NOT fire an engine if used as the source for the spark plug. Electricity has an opposite and equal within itself. Man really only uses the South Pole Positive nature of Energy. The North Pole Negative aspect of 'energy' is IMPLOSION or Cold Fusion or Compression (Walter Russell) and this is what you seek but know it not.
Joe and I can make these 4 Phases of Electricity with just 2 car batteries. (I cant divulge this as its way to advanced in the Magnetic Science to understand at this point in time because everyone still thinks in particle terms, also it can be lethal if used in a medical apparatus) Youse all think its just Pos and Neg out of a car battery but there are 2 more 'inbetween' phases. These are present in any Neutral Centre device which the Lutec motor was once for a short while. Your measuring sticks are useless and down right destructive in real 'over unity'. If you cant USE the extra vibrations as a LOAD then why are you doing it? The LOAD or the motors and lights you power up are your METERS.
Think of the Sine Wave where the peaks and troughs are Pos and Neg. As the Wave form cycles through each cycle of Hertz, it passes the 'Line" where it "transitions" between the two, so there is a..... -- and -+ and ++ and a +- No matter how one rectifies or filters the AC, there is always the ripple of the the other phases we call noise because we dont understand the Non Physical Nature of Magnetic Fields Vibrating the 'atom'. The Atom is a Tetrahedron Crystal made with 6 structures of Light. Its ancient 'symbol' is an Inverted Triangle for a reason. Its indivisible as Democtris said. Its the Only 'atom' in existence making Everything Is Water said Thales and Aristotle.
A Multi Meter ADDS another frequency to the Circuit and measures the Difference between the 2 and this is displayed on the dial. What you call AMPS is just 'greater' frequency. (not to be confused with Hertz as this only represents the number of Disturbances per second to the Crystals in the copper.) To increase the Current in a circuit, make the Spinning iron filings wave form Magnet larger and the Coil larger. A lager magnet or a stronger magnet will have a Greater Disturbance in the Crystalline structure of the Copper creating Stronger Vibrations or more AMPS. If the coil isnt sufficiently large enough for the large magnet, the coil will overheat with the Massive Disturbance within the coil. The Coil is then not Tuned to the Magnet. Add more winding and make the wires bigger. All these Tesla Secrets of Electricity are NEEDED to KNOW to make Scalar, or NON Hertzian Energy from a motor that is clearly spinning and generating and assumed to have a Frequency like the Samsung motor or the Joe Modified Lutec1000 motor.
What we found is that, when an over unity aspect is added to the motor (the Lutec in this case) that conventional "Meters" cannot register the correct change in vibrations when an over riding Magnetic Field is added or another lot of vibrations emerge from the device.
Not only will a multi meter not read correctly, but NO scientific instrument can read what we do when we make one as a Water JoeCell Battery. It follows through to any 'Frequency Generator' or Battery creating a circuit including the Lutec. A Multi Meter will KEEP you ignorant of what you are GENERATING.
Think in terms of energy, frequency and vibrations. Look at it as a NON PHYSICAL Phenomena. There is no 'spin'. There are no 'charged' marbles to count or measure. These things were PURPOSELY invented to control science and thus inventions. Westinghouse and Morgan did this and Einstein gave it the death blow.
These multi meters are ADDING more vibrations to the circuit and not all circuits are created equal.
Again I caution to not ever use a multi meter when the Motor is running. Use it only to check for open circuits when assembling. A motor is a Tuning fork. A generator is a Tuning fork. A Coil is a tuning fork. The generator makes a Frequency that the Motor is Tuned to and it spins according to the Frequency of the Generator. This is most evident in taking a 120VAC motor and plugging it into 240VAC socket. Add another frequency to a Tuning Fork where one is trying to connect to the Aether and voila a mega stuff up. Joe doesnt own a multi meter. He can actually SEE the field as vibrations in the circuit and knows if its tuned right or not. We mere mortals have to build an apparatus to detect and then imagine what it is that we detect. And therein lies the MEASUREMENT ERROR.
after thought....
There is no 'electricity' used in a Motor. Vibrations activate the Coils to Rotate it only.
So if one was 'smart', one would take the Power from the Mains Meter box to a Single Motor and UNBRIDGE this motor and connect another motor to the Unbridged wires and run them to another motor and then another motor and so on, as the Vibrations are always present in the wires and not actually being "used". Probably best to trial this on the bench first. You might find the Meter only measures the first motors Load on the meter. If you think in terms of electrons, this concept will bypass your thoughts. This is all that we did in the samsung motor above. Activating the Motor and Generator in one, by giving the generating aspect of rotation or the vibrations a place to go and go and go etc.
Over Unity isnt what you think it is...... You need to think of the Non Physical Nature of Energy, Frequency and Vibrations to understand this Universe of Light Crystals. Its how Tesla envisaged the universe.
The above probably needs a little tweaking to be digested properly but I have a Plane to catch..... anyone in Vegas next week?
The Bottom line with the Lutec motor is that Joe took it from a type one over unity device to a type 2 where it became a Mini Tesla Scalar Motor/Generator until they reversed engineered it and stuffed it up.
