@Gyula - The "strips" are taken from trashed 36w LED panels
(got loads, free, for testing HV outputs)
Require about 20v (original smps drivers supply 41.6v)
RE the DMM - it's an old one I'm not so worried about frying and has survived everything so far lol
Still reads fine on most settings.
Not sure if the transistor burned up in previous Alexkor config .. been busy elsehow not had chance to reconfigure it.
I should imagine it's still OK - I have yet to "release the magic smoke" from a transistor in my experiments so far
They seem to deal with "radiant electricity" fairly well considering the "abruptness of discharge" is so destructive.
Still trying to find the best use for it, as LED/CFL driver, or as speed charger for a spare 55ah SLA I have lying around.
Then use it as a power bank (build a nice portable enclosure etc) and stick a solar panel on top as PM for the flyback.
Or something else entirely - it should be built according to use case scenario IMO hence the pause in progress..
Currently I think I want to construct it as simply and neatly as possible, with all emphasis on the loop to drive battery.
Load is irrelevant and the
most important takeaway is "
is it overunity" and if it self powers for even a few seconds then this is a good start IMO
(Edisons' trial and error is often the only truly effective way, it seems..
Despite the conciseness of Teslas' style of purported deliberation.)
It's unusual seeing a 4v battery run a mains LED baton but it's explainable by standard models.
However the possibility of HV transients or similar phenomenons "drawing in extra power" is yet to be disproved.
I plan to update the SATG thread soon as I am rebuilding it using an LFE cell as PM and an L2 as "choke" to direct pulses
Unless I am mistaken, member ions' blocking oscillator circuit is sorely underexplored
Has anyone ever shared a demonstration of the approach in mention, confirming OU in a device?
If so a reference to such here would be greatly appreciated
@ lfarrand Those are beeests! And very expensive
I'm a little way off from working with those ATM - budget is tight unfortunately
Although they are certainly a tidy bit of equipment.
Many thanks for the suggestions nonetheless.
Would it be a good idea to use this type of resistor as base/gate control for this sort of fine-tuning ?
https://www.ebay.co.uk/itm/333271223025?hash=item4d98834af1:g:p4AAAOSwTm1dnTf5&amdata=enc%3AAQAIAAAA8CIr1xo46Gzbi8V5A3p5uQk7gLpHCozNDi914zWo6Vnm1bgRw4EWDkJr6Gtnjv53m80RKA4E%2FG1gwEkeVOQHv%2FWakS%2FQDgJTSarZe2Mlb9Mfp7ZyVu7tLQfYnK3iGO%2BXz6SA62woZdDtqFGvKjxOgA%2FmPkRo%2FAko8Sz2g6UKPBSbozzdkkn9gKRoolohbw2pw5vvKFy16PHZ4Qlzos39QdawvMD9PYyK2FQImszouUQ%2FYyCdockrP%2FQw9KGIWD2716Vh5PyXnEV2FOK3PynELaqjJBWIv1wyvHCkYuZ3d7lbgk9dA6q7n%2B7u%2FY%2BFxpNGiA%3D%3D%7Ctkp%3ABFBMlI7en51iInstead of fixed resistors - Could they allow for more precise and efficient switching ?
IE read the individual devices' resistances between junctions and base the value off that accordingly
Or is this totally unnecessary and overkill? Hard saturation may be required but over saturation is a waste, surely?
