2024-11-26, 06:39:41
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29
Author Topic: Akula, Ruslan, Stalker, device discussion and replications.  (Read 54820 times)
Please, ignore the cursor reading at top left.
https://youtube.com/shorts/lVoS1g_2hnU?feature=share
Here's the carrier (envelope) and the intelligent signal.
Max,
thanks, i see your time base is at 10us/div., so the peaks are at 25kHz (40us) is that your push-pull (carrier) frequency?
I have never seen such a screenshot before, so could you further explain where your probes are at?
Max,
This particular grenade res at 1.310MHZ
The the LC resonance is 26.2KHZ.
Since it is broadcasting, the probe should be outside to pick the out going signal.
I do hope we are getting the form now
« Last Edit: 2023-07-03, 03:58:30 by Maxolous »
Max,
So this is your 1/4 wave resonance of the Grenade?
The the LC resonance is 26.2kHZ.
So this is your push-pull resonance frequency?
So the probe is laying say 5cm away from the Grenade?
What about the Kacher / Antenna resonance frequency? Is it this same 1.310MHz?
If so, would the probe not pick up that signal first?
As i do not have the push-pull (yoke) running i will not be getting this form anytime soon
Sorry for all these questions,   Itsu
« Last Edit: 2023-07-03, 09:48:50 by Itsu »
Max,
Yes
I guess you mean kHz?
Yes, 26.2KHZ .
I will modify that.
About 10cm, I guess.
Yes
This is the result of all signals.
Please, do and don't delay.
Not bordered.
Maxolous.
Thanks Max,
OK, I understand, but would / should the kacher / Antenna signal not be a multitude times stronger than the "broadcasting" Grenade and thus obscuring its signal?
Anyway, do you think this AM modulated signal is essential for a self runner?
Thanks Max,
No, it's a modulated signal so , they are all now one and attain power
Achieve this , next maximize Tesla power to get what you want . Also, it depends on how you arrange your cct.
Maxolous.
Do you mean you are modulating the kacher?
If so, how do you do that?
Yes
Yes, 26.2KHZ .
I will modify that.
Yes
Not bordered.
Maxolous.
Err do you mean not bothered by any chance ?
Geo showed you how to do that in one of his last vids but thats not rthe real problem.
Err Itsu  why do you want to modulate it, your already transmitting it of into
space re right hand rule !
« Last Edit: 2023-07-03, 13:51:29 by AlienGrey »
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #277 on: 2023-07-01, 20:06:29 »
At this point your Corona will cease from being blue to become whitish.
Yes, thanks for the correction. Keypad suggestion error
Max,
So, your Grenade 1/4 wave length resonance is 1310kHz.
You have a continuously running Kacher / antenna at 1310kHz
The push-pull / Inductor LC circuit is running at 26.2kHz resonance, thus the Grenade also gets pulsed at 26.2kHz
26.2kHz is 1/50 of 1310, so the 50th subharmonic is stimulating the Grenade to run at its 1/4 wave resonance.
These combined signals seem to create that AM modulated HF signal (1310kHz carrier with a 26.2kHz modulation).
The modulation depth is not 100%, but roughly 25%.
Are your Kacher power supply and the Push-pull power supply one and the same?
If so, there might be some interaction / feedback between the Push-pull circuit back to the kacher circuit and/or vice versa.
Do you hear any hissing sounds and / or Radio Moscow (squealing sound) which points to some form of oscillations?
« Last Edit: 2023-07-03, 20:00:32 by Itsu »
So in that case you have just told me no one in this group is doing any thing by the book
or your just doing your own thing great! don't let me stop you carry on. >:-)
Max,
This build is a simple kacher. Top Ruslan 2014 modified. No interruption.
I have also showed that of controlled Tesla.
In simple kacher power source for both are same except you're putting mediator yoke coil which in this case ,no.
There must be hissing sound otherwise no interaction.
The modulation can not be 100% because it's a continuous running system.
Maxolous.
Itsu.
Note.
I didn't bother about ¼wave res. I just worked with were my wound grenade resonated, please.
There is no information about this device you shall look for that has not already been given especially in OU.com and here. only know what you're looking for.
Yes it's all in the two threads some where but it's putting it all about assembling the
jigsaw together correct part in the correct hole unlike some have.
Have you noticed Itsu and Nick ignore me  that's because some people get things wrong and things get messed up:D :D :D say no more   :-X
   Well, you could say that I try to ignore you AG,  but you are pretty persistent with your distractions, up to now.
  I am allowing Max his say. He seams to think that he has this down. Even though I don't buy any of it.
   Each to his own...
« Last Edit: 2023-07-04, 02:32:57 by NickZ »
AG,
I don't think so, probably for now what you're saying don't catch their interest. Nickz had been mute till you just mentioned him. Probably keeping cool for a while. Let sleeping dog lie.
We are making progress.
   Perhaps you'd like to show us, that "progress". Ánd how your simple kacher or controlable TC, can produce a higher output than unity.
I would be most interested. As you seam to state things as if you know.   Said the sleeping dog...
Maxolous.
Max,
it seems we have a slight language barrier here, as some of your answers are confusing to me.
I asked: "Are your Kacher power supply and the Push-pull power supply one and the same?"
your answer: "In simple kacher power source for both are same except you're putting mediator yoke coil which in this case ,no."
The first part makes me think that's a yes, but the rest confuses me like the "no", what do you mean by that?  Also, what is a mediator yoke?
I asked: "Do you hear any hissing sounds and / or Radio Moscow (squealing sound)"
your answer: "There must be hissing sound otherwise no interaction."
Does that mean you do have this hissing sound, or that you like to have that?
I think any hissing sounds and / or squealing sound points to oscillations in the circuits, which is good when building an oscillator, but IMO bad news if you are building an amplifier which we basically do.
But thanks anyway, i will put up my push-pull yoke to see how that interacts with the rest.
Max,
The answer is yes.
Am using the same power supply.
The second question is yes, but not too strong hissing at least you will hear sound of the ionisation of the immediate surrounding around the antenna.
Mediator yoke is a yoke coil put between supply and kacher . Some believe it enables interaction between pp and kacher quickly.
Thanks Max,
so the hissing is more ionization, no oscillations.
This mediator yoke looks to me more like a choke preventing the HF from the kacher to get back into the PS.
Why some believe it enables interaction between pp and kacher quickly, seems far-fetched IMO.
    Max:
    Sorry for asking about your progress. I should have known better. Won't happen again.
   But, I had thought that you mentioned "progress". Must be another slight language barrier, here.
   All:
   I have been keeping quiet lately to give you all a chance to build up something, hopefully that works.
 And also to openly discuss what does not work, as well.
  As I believe that I already know what will happen when you try to match up those frequencies as you are doing.
And you are already finding that out yourselves, which takes some time.
But, unless you build a complete device, you will not know what works, or what doesn't.
  And that also takes some time, money, and a bit of work. For those interested, if any.
  Max: You are continuing to insult the moderator here, me. I can do without your insults. Last warning...
« Last Edit: 2023-07-04, 20:05:24 by NickZ »
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2024-11-26, 06:39:41
