2025-04-01, 02:54:29
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29
Author Topic: Akula, Ruslan, Stalker, device discussion and replications.  (Read 71490 times)
Thanks Max,
so the hissing is more ionization, no oscillations.
This mediator yoke looks to me more like a choke preventing the HF from the kacher to get back into the PS.
Why some believe it enables interaction between pp and kacher quickly, seems far-fetched IMO.
Let me show you something you can try.  If you wound your yoke coil for mediator like this and connect it like in the pictogram, you would see that the voltage going to your kacher will be 50-110Volts when you switch on your  "PP".   At the time you connect your kacher by placing it input wire on the one going to kacher, you would see a dramatic increase in grenade output .  Am still investigating it.
Find attached , image of connection.
Thanks Max,
Yes please, when so intense it breaks into Corona. That's why you see the blueish flame around Slayer Tesla coil.
« Last Edit: 2023-07-04, 17:49:38 by Maxolous »
Does it have the same low-pass filtering function as this ?
Modulation by controlled Tesla
Modulation
Hmmm, interesting,  i can see why the 24VDC could be transformed up to 50-110VDC when the Push-Pull device is causing the 24VDC to be fluctuating that it becomes a pulsed DC / AC, but that would mean that the 50-110V is not DC anymore, but also pulsed DC / AC.
Feeding the Kacher with this 50-110V pulsed DC (26.2kHz) could explain the AM modulated like signal (26.2kHz) you showed earlier, right?
I dont know, i need to build one and measure it to see how it behaves.
What i can see is that it could act as a transformer, supplying pulsed DC to feed the kacher which would produce this AM modulated kacher signal shown by Max here:
https://www.overunityresearch.com/index.php?topic=4471.msg105536#msg105536
Max,
new confusion, as this not the simple kacher you were talking about up till now, this is as you mention a controlled kacher / Tesla, (not modulated, but interrupted IMO).
Which one (simple or controlled) do you use?
Max,
Am just showing  this, if you say interruption it's still okay. It's from a controlled Tesla.
Verpies is right. It's a low pass filter since the yoke as an inductor is in series , the inductive reactance becomes high and blocking high frequency signals. However, as Itsu had stressed ,it also a transformer when push-pull is switching. Hence the high voltage at the other limb of the winding..
By experiment, it is not the cause of modulation. Modulation  is brought about by precise matching of grenade high frequency and the frequency of Tesla.
In view of the above, it will be good to put diode in line with kacher input voltage.
« Last Edit: 2023-07-04, 22:40:46 by Maxolous »
I remember seeing Geofusion demonstrating this sometimes ago.
https://youtu.be/qEHKGSLy938
Verpies is right. It's a low pass filter since the yoke as an inductor is in series , the reactive inductance becomes high and blocking high frequency signals. However, as Itsu had stressed ,it also a transformer when push-pull is switching. Hence the high voltage at the other limb of the winding..
Thanks Max,
when you say: "Modulation is brought about by precise matching of grenade high frequency and the frequency of Tesla", with "Grenade High Frequency" you mean its 1/4 wave resonance point, right?
You earlier said:
Itsu.
Note.
I didn't bother about ¼wave res. I just worked with were my wound grenade resonated, please.
So you measured the Grenade 1/4 resonance point (how was this done?), then you tuned the Kacher to be resonating at that same frequency and with the mediator yoke in between the single 24V DC PS
you feed both the Push-pull circuit and the Kacher circuit causing the outside probe to pickup this AM modulated signal.
Max,
a quick test showed me that when feeding the kacher with pulsed DC (+5V / +10V @ 20% duty cycle at 26.2kHz) from my FG, i can get a similar kacher output (pick up probe 5cm away from Antenna) as you showed here:
This screenshot shows both the kacher signal in yellow (1729kHz) and the FG output signal feeding the kacher drive circuit (26.13kHz between the cursors):
So i am not really convinced that the "Modulation is brought about by precise matching of grenade high frequency and the frequency of Tesla", as it seems that feeding the kacher with a pulsed DC input voltage does the same.
@Itsu,
This is not the same thing. In my pictogram you saw two signals, one the envelope the other the message.
The envelope is the repeating rate caused by LC resonance while the other is Tesla signal
I got the modulated signal without mediator yoke anyway
Maxolous.
Doesn't the above mediator coil just drive the Tesla coil while the PP  one half
is active  that would explain why Geo's one mosfet gets hot when using the mediator
coil. It lookes like the Tesla coil need to be active the full half of each one half of the pp
time in that case.
time in that case.
AG,
I don't think so. It drives both the PP and TC the same . It doesn't have half circle and it couldn't be the reason why one of  Geo's MOSFETS was hot.
   That mediator coil bit was something that Geo tried out, at first. But, he never showed it to be getting any more out than in. Nor even to the output my device has shown. Nor did any one of his various versions.
   He connected his output to the 3 turn coil circuit, instead of the 28t / output grenade coil.
So, different effects were noticed. But still did not show over unity or self running. Just to be clear.
Any one know how to convert an (.MOD) video file to a mp4 or similar video file
on Win 7 with out wasting cash ?
The other thing is your Tesla coil HV gen O volts connected to any other part of the device
there is a warning that that will kill it and you cannot have AC from it like in your wave form.
@Itsu,
Maxolous.
Max,
does my screenshot not show the same; the repeating 26.2kHz envelope (amplitude peaks) and the constant 1729kHz kacher signal?
Anyway, good to know that the mediator is not needed to get the modulated signal, i will see if i can get there too.
Could you please also answer this question in one post earlier:
Max,
The shape is okay at 26.2KHZ
Which depicts the frequency of your Tesla and rep.  rate. One thing is not there, the wave processes inside the grenade. In my  case, I guess it is 4330KHZ.
Itsu  Oh master and great one
its the capacitor in the 3 turn winding from the yoke to the grenade that controls the resonance
and its the coincidence of the two resonances that have to be in phase.
It should look like this.
Sorry Max,
I am confused again, you say:  One thing is not there, the wave processes inside the grenade.
Is it visible in your screenshot?  If so, could you point me where to look?
Thanks,  Itsu
Sorry Max,
Thanks,  Itsu
Your confused because your ignoring flamings right hand rule. Sort that out first.
https://www.youtube.com/watch?v=c5iIQZLdVfU
Sorry Max,
Thanks,  Itsu
Rep. rate is 26.2kHZ
Filled in is the 1.310MHZ
I just indicated the high frequency.
If you want to precisely measure your ¼wave resonance in a manner that it doesn't stray, you need a current transformer, signal generator, your kacher antenna , your grenade, scope or static meter(Electrostatic explosive meter) and ground.
1. Disconnect your Gizmo(shinyaga) from your antenna.
2. Put your grenade in place
3. Slip your grenade terminal through your CT  and short your grenade
4. Connect shorted grenade terminal to ground.
5.  Feed your SG to antenna terminals set to Square wave @10V
6. Connect your scope to CT terminals
7. Sweep to detect frequency that gives maximum amplitude in scope or strong indication in static meter.
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-04-01, 02:54:29
