2025-05-17, 23:06:37
Pages: 1 2 [3]
Author Topic: Alberto Molina-Martinez principle (The Rotating Magnetic Field)  (Read 7148 times)
I understand nothing.
Yet you demonstrated the polyphase RMF using an old motor stator as I recall. It appeared that you knew what you were doing.
bi
could to  use this construct similarly devices with rotating virtual magnetic field ?
I will not name this person. :(
If I'll supply three phase to  coils with three rings.
At least it looks much more simple.
I'll try it tomorrow for sure.
Looks interesting. How will you detect a rotating magnetic field?
I'll wait for your test results.
bi
You should be able to induce a current but not generate a rotating magnetic field unless the chokes are out of phase.
In anyway our virtual magnetic field will be moving along the wire of the second coil. consequently it won't create EMF.  Magnetic field ought to across perpendicularly of wire.But how do that ?
Pages: 1 2 [3]
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-05-17, 23:06:37
