2025-04-05, 07:55:51
Pages: 1 2 3 [4]
Author Topic: Engines  (Read 11151 times)
At 4 minute 30 second mark of first vid in your reply above,
Seems a new term being used “FRM”Flameless Reaction - motor?
It is written above few screenshots in vid at that time stamp and spoken by presenter to explain how it works ( no combustion?)
Was very odd to me ,
A phase change would be flameless reaction..?
First time I have ever seen this term used in what appears to be an ICE ( the “C” being very relevant to success ..normally )
Got it.
They’re referring to the piston return mechanism. A combination of spring and air that’s computer controlled. Where in a normal multi cylinder crankshaft style engine the power stroke of one cylinder would provide the compression of another they’re using the rapid expansion to compress the springs to initiate the next compression cycle.
Cheers Grum
 O0
Thanks for reply,yes makes sense now ( except others like Aquarius?)
Play ping pong with one center piston ( 1 moving part no springs ,just linear generator to
Manage cycle return ( instead of springs) and generate power .
PS
For clarity ( mine)
These new design linear generators would be simplest design for water fuel Papp engine
Or any Papp chemistry which could be done by “Fred in the Shed”
Once concept is actually proven …
Pages: 1 2 3 [4]
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-04-05, 07:55:51
