2025-04-17, 01:22:08
Pages: 1 2 3 [4]
Author Topic: BTG Research (please only posts related to practical work)  (Read 9434 times)
Science is a consensus on knowledge. Research is not yet science but hypotheses, only its method is scientific.
Scientists who announce extraordinary things also exist, it is not reserved to the crackpots of the FE.
In 2011 we saw the scientists of the OPERA group announce that they had measured neutrinos faster than the speed of light. A year later, they announced that they were wrong, and that the speed of neutrinos was less than c. A study is insufficient to make science.
Then, even if it calls it into question, it is not for that reason that the equations of electromagnetism, relativity and all the well-established theories, which model our observations with relevance since ages, will become false overnight!
When will these conspiratorial FE trolls who don't understand the scientific method stop flooding us with links, just because it seems to contradict the academic science they hate and don't understand either. They are unable to explain any scientific paper they reference.
Here post 22889 today
https://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg573391/#new
Tickles the edges of a “criteria for gain mechanism “
I have personally never seen this type comment on forum ( formatted and translated..
  Is it?
   Or, it "seams" that you two have no idea what has been mentioned,  at all.
As there has been much discussions concerning the source of free energy, and what it takes to tap it. As well as that this type of device can be very location sensitive. Of course that is all very theoretical to some. As theories are all they have.
   See, I told you, it gets F6 all messed up trying to convince us. Poor guy. He sounds like a broken record, or a parrot, repeating the same thing day after day. If he does this for free, imagine what he would do for money.
Discussions on FE, there are. People like to talk about what they don't know and don't have. If NickZ knew what he was talking about, he would provide us with the diagram of a working machine, the one he would have made, rather than making a meaningless and nonsensical comment.
   Chet: Although it loses something in the translation, it does provide some idea as to what this type of device was based on, and it's mode of operations. As well as some history, videos and links, etc.
  Those with eyes for free energy will SEE, and those with other intensions, will not.
   Vasik has also presented tons of translated information, from the device inventors themselves.
  And there is much more information available for those actually interested in the topic, or it's replications.
Never mind F6, If your Katcher is at 1.2mhz and your Grenade is a 37.5meter device thats about
8mhz. But Vidura says the grenade has to be a divide by 3, doesn't that mean every ones katcher
is out of range ? wouldn't you need to re wind one of them or drive it with a lower frequency ?
PS ask Vidura for his opinion.
Chet, the general description for Kapa's early builds is  made correct there, and at least they try to find out the principles as it seems.
Regards Vidura.
To clarify this: The ideal relationship is 1/4 wave length for the transmitter, and 1/2 wave length for the receiver coil. I used the third harmonic due to lack of more wire. As you might know even harmonics also do couple to the fundamental frequency. But 1/2 wave performs better. Also the ground wire should be tuned to 1/2 wave ideally, so it composes a 3/4 wavelength resonator together with the TC. Of course these lengths ALL refers to the ELECTRICAL LENGTH of the wires. In the practical layout the VF(velocity factor) has to be taken in account, as well as dielectric influences near the voltage anti-nodes, and Inductance(also parasitic) near the current anti-nodes.
Regards Vidura.
What if longitudinal waves are used instead?
What of the spark gaps that were used?
Repetition frequency with a full quench would be below 1kHz, so probably NOT fully quenched.
Thus you get pulses on a DC bias, which is much more interesting.
This is about longitudinal waves, the propagation of a wave of potential or displacement IS longitudinal in a solid state conductor. Transverse waves can only occur on the boundaries of two different mediums.
The sparkgap is a switch only, the secondary will always resonate with a sinusoidal pattern, the physical principles would be the same.
Regards Vidura.
This is true for an electric wave, but let's not forget that a current, which is ultimately only the coulombic influence of electrons that propagates from near to near along the wire, much faster than the electrons themselves, is always accompanied by a magnetic field, oriented transversally around the conductor, and even inside the conductor (hall effect). The current and the accompanying magnetic field are one and the same physical reality, so we never have a pure longitudinal wave, a transverse wave accompanies it.
The origin of magnetism is all the more obvious with relativity. The contraction of lengths when a charge moves causes the coulomb field to strengthen transversely and reduce longitudinally. The transverse strengthening effect is what classical electromagnetism models by the magnetic field. These two ways of looking at things are perfectly coherent and compatible, especially through math.
Pages: 1 2 3 [4]
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-04-17, 01:22:08
