2025-05-30, 21:55:39
Pages: 1 2 3 4 5 6 7 8 9 10 [11]
Author Topic: HHO Tubular Browns Gas Build  (Read 26610 times)
10kWp gas genset to convert to HHO Gas from Tubular Water Fuel Cell Build
This 414 cc, 1 cylinder, OHV gas engine, with 10kWp generator,
- No sensors
- No OBDII port for Volo programmer
To do
- ignition adjustment
- waste spark removal
- HHO gas fuel adjustment
« Last Edit: 2022-03-21, 05:41:16 by vrand »
10kWp gas genset to convert to HHO Gas from Tubular HHO Water Fuel Cell Build
Removed carburator, gas tank and pull cord
« Last Edit: 2022-03-21, 05:41:37 by vrand »
Removed generator end cover, spark plug wiring
« Last Edit: 2022-03-21, 05:41:54 by vrand »
Will try 2 to 1 spur gearing reduction, and Hall sensor on wood stick,
similar to Anton 2010 build. see attached photos
- to adjust the timing and waste spark removal
« Last Edit: 2022-03-21, 05:42:16 by vrand »
Plasma Spark Mod by Aaron Murakami & Peter Lindemann (2 of 4)
https://www.youtube.com/watch?v=9oyrzLmyxeQ
Plasma Spark power density increased from 100ms to 5ms by adding the 12kV HV microwave diode
I will try this out on my 10kWp genset ignition modifications.
« Last Edit: 2022-03-23, 03:50:59 by vrand »
Hall Effect Sensor Ignition circuit for 10kWp genset conversion to HHO Water Gas fuel
Ignition circuit help
https://www.homemodelenginemachinist.com/threads/ignition-circuit-help.19673/
"The circuit you posted is a poor variation of the "old school" TIM circuit. A hall sensor in theory will activate it but the resistor values on the front end are pretty low value and depending on the sensor it might not be able to drive the circuit and/or may damage the sensor. The problem with all of the original TIM circuits is the output transistor breakdown voltage. In order for a coil to work properly you must not supress the kickback voltage generate on the primary side of the coil when the "points" open. When you use conventional points there is no problem since the points gap is quite large.
In the case of the TIM circuit the transistor breakdown voltage is perhaps (unchecked for the particular transistor) 150volts at most. This will limit the seconday Hi voltage to 150v x the turns ratio of the coil. Typical turns ratios are about 100:1 therefore the secondary will only get to 15kv. That's probably more than enough for a model engine but you can do better.
Try my circuit below. It has the following improvements:
1. The front end is designed for a Hall sensor.
2. The first stage does not sit around consuming a lot of power when the engine is not running. The circuit you presented consumes considerable power just sitting there doing nothing.
3. A big problem with all of the TIM circuits was that it was possible for the engine to stop with the ignition activated which could (usually did) burn out the coil and or transistor or both. This circuit will not do that.
4. Most important is, this circuit uses a proper IGBT transistor to drive the coil. One that is made specifically for this purpose for automotive ignition systems. It has a very high breakdown voltage.
5. A little extra benefit is the LED which blinks when the Hall sensor is activated so you can tell if there is activity.
6. The input circuit can be run on the same 12v as the rest of the circuit but need not be. Just be sure the ground is common to both supplies.
7. And the best part - the IGBT is a logic level input device so, if you are so inclined you can elminate the front end altogether and drive the IGBT base with a microprocessor or logic chips.
Note that the symbol for the IGBT transistor is not precise. It's drawn like it is to make if familiar to the original circuit. The IGBT is a TO220 device so you'll need to consult the spec sheet to get lead orientation.
With a little ingenuity you should be able to use your existing circuit board by leaving out components and perhaps cutting traces and adding jumpers.
[EDIT Feb. 22 2013]
Updated drawing. I had the wrong part number variant for the IGBT transistor. Sorry. All is correct now.
Sage
IGBT Transistorised Electronic Ignition using a 3144 Hall magnetic sensor
https://www.youtube.com/watch?v=gASPFWhvb_g
Aug 5, 2015
bootsowen
35.2K subscribers
This is a mock up circuit that I put together from a fairchild IGBT and a hall effect 3144 magnetic sensor. The plan is to try it out on one of my small engines as a replacement for  a lucas hovis type magneto that has points and capacitor type ignition.
 3144 hall sensor:
https://amzn.to/32hympI
HHO Gas regulation from 0.5 psi to 20 psi adjustment
Will try this with HHO Gas to 10kWp genset conversion
DIY Generator Conversion to Natural Gas for $10
https://www.youtube.com/watch?v=sDHGCzOZn_M
GasOne 2109-RED 4 ft High Pressure 0-20 PSI Adjustable Regulator with Red QCC-1 Type Hose-Works with Newer U.S. Propane Tanks
https://www.amazon.com/GasOne-2109-RED-Adjustable-Regulator-Hose-Works/dp/B096CRXM43/ref=sr_1_1?keywords=propane+regulator&qid=1648099540&sprefix=propane+regu%2Caps%2C186&sr=8-1
« Last Edit: 2022-03-27, 21:45:30 by vrand »
Adding Misting Water to Slow HHO Gas flame front in engine
+ Add tiny amount of Lithium Hydroxide ala Sam Leach 1970's Invention
Misting Nozzles: BETE PJ 8
https://www.youtube.com/watch?v=Ukri97-3GDM
850 psi - 0.0525 gpm
58.6 bar - 0.2 L/min
Misting nozzles produce the finest atomization
available for direct pressure nozzles. They are capable of spraying consistent patterns at very low flow rates. They have exceptional performance for humidification, coating, odor control, and scrubbing applications.
Design Features of PJ Misting Nozzles:
* High energy efficiency
* One-piece, compact construction
* No whirl vanes or internal parts
* 1/8" or 1/4" male connection
* 100-mesh screen, 10 micron paper filter or polypropylene filter optional
Spray Characteristics of PJ Misting Nozzles:
* Finest fog of any direct pressure nozzle
* Produces high percentage of droplets under 50 microns
PJ
IMPINGEMENT FOG AND MISTING SPRAY NOZZLE
https://bete.com/product/pj/
How To #10 - Build A Water Fuel Injection System + Test Drive
https://www.youtube.com/watch?v=8nwB3ajwp8A
and 100 psi Pump
FL3203 Single Wand Chemical Pump 100PSI
https://escapingoutdoors.com.au/fl3203-single-wand-chemical-pump-100psi-detail
Water Misting HHO Gas cont.
PJ - IMPINGEMENT FOG AND MISTING SPRAY NOZZLE
DESIGN FEATURES
Produces a high percentage of droplets under 50 microns
Includes 100-mesh screen in 316SS
Optional 20-micron paper filter or 70-micron polypropylene filter
HOW SPRAY PATTERN IS ACHIEVED
High pressure shears the liquid by forcing it through tiny openings. An impingement pin distributes the liquid as it leaves the nozzle, deflecting it on the chosen surface.
Amazon
One pc impingement nozzle fog nozzle Water mist spray nozzle 1/8 inch male thread High pressure mist fog for humidification - (Size: 0.2mm)
https://www.amazon.com/gp/product/B09D8SVFGC/ref=ox_sc_saved_title_2?smid=A1ADBD8EN75L67&th=1
 Product Description
Impingement mist nozzle
1.High energy efficiency
2.One-piece,compact instruction
3.No-whirl vanes or inner parts
  Impingement mist nozzle are used in humidification and scrubbing applications.  and also used in following:
– Air Conditioning
– Coating
– Concrete Curing
– Fire Protection: Halon Replacement
– Fire Protection: Special
– Fogging
– Humidification
– Misting
– Moistening
– Odor Control
– Scrubbing: Conditioning
Orifice diam:0.15MM 0.2MM 0.3MM 0.4MM 0.5MM 0.6MM 0.7MM 0.8MM 0.9MM 1.0MM
Performance data
Item specifics:
Connection: Male
Head code: Hexagon
Material: Stainless Steel
Shape: Equal
Model number: 1/8"
Technics: Forged
Type: Impingement nozzle
« Last Edit: 2022-03-27, 21:47:20 by vrand »
Water Misting Pump for HHO Gas cont.
Will first try out a 110 PSI water pump to feed to 0.2mm nozzle, G Ganen had good reviews on Amazon,
The PJ misting nozzle can take up to 850 psi as the video shows
G Ganen 12V DC Fresh Water Pump
https://www.amazon.com/gp/product/B07F35PTFR/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&th=1
with 2 Hose Clamps 12 Volt Diaphragm Pump
Self Priming Sprayer Pump
with Pressure Switch 4.5 L/Min
1.2 GPM 110 PSI Adjustable
for RV Camper Marine Boat Lawn
« Last Edit: 2022-03-27, 21:48:23 by vrand »
Hello vrand,
I try to follow along with your experiment but am getting lost in all of these posts.
There is a question I have about water fuel in general.
Other than keeping it warm, what can be done to prevent the water from freezing in the winter time that will not interfere with electrolysis?
Cadman
Hello vrand,
Cadman
Hi,
You can try electric heat blanket along with insulation.
Electric Water Pipe Heat Cable
https://www.homedepot.com/p/Frost-King-6-ft-Electric-Water-Pipe-Heat-Cable-HC6A/202262328
Could not post over at
Author Topic: Holcomb and other FE technology debate  (Read 643 times)
AC,
I have a little different perspective on this.  Holding a patent as an individual or small company means nothing.  I speak from experience.  If you for example have FE technology, trying to protect it from the powers that be is impossible via such means!
There is only one solution.  It must be given away.  Yes, given away freely.  Does the inventor stand to loose, absolutely.  Does mankind stand to benefit, absolutely.
So, one must decide what action to take if he/she posses such technology!
regards,
Agreed
Inventor with a Free Energy Device, that try's to get a US Patent, gets Classified as National Security, and is taken from the inventor here in USA.
Read it and weep...
Patent Secrecy Order
The Invention Secrecy Act of 1951 requires the government to impose "secrecy orders" on certain patent applications that contain sensitive information, thereby restricting disclosure of the invention and withholding the grant of a patent.
The U.S. Government’s Secret Inventions
Secrecy orders allow U.S. defense agencies to control patents, including those that are privately developed.
https://slate.com/technology/2018/05/the-thousands-of-secret-patents-that-the-u-s-government-refuses-to-make-public.html
But as of 2017, according to statistics reported by the U.S. Patent and Trademark Office and published by the Federation of American Scientists, there were 5,784 patents that you can’t see. They’re the U.S. government’s cache of inventions under “secrecy orders.” We don’t know what they’re for, but once-secret patents recently made public have included a laser-tracking system, a warhead-production method, an anti–radar-jamming apparatus, and a stronger net
« Last Edit: 2022-03-27, 21:56:09 by vrand »
The Tubular HHO Gas Processor/Storage Tank in the Tubes HHO fuel cell has to be above 35 psi for the "magic" of COP 50 to happen!
Conventional Flat Plate HHO units never go above 5 psi due to explosion hazard (wet cell) or rubber seals leaking (dry cell).
That is the major difference of why the Tubular HHO Cell is 1000x superior to Flat Plate HHO Cell design!
The Pressure of the HHO Gas Plasma to then cohere the ZPE, to then flow into the engine ala "Orgone Energy" or the "Joe Cell."
Use a Gas Regulator to input HHO Gas into Engine Fuel Rail Pressure of 0-50 psi, and keep Tubular HHO Gas Tank Pressure of >35 psi.
Yaetek Oxygen Regulator Large Tank Gauge Cutting Torch Regulator Outlet 0-200PSI Inlet 0-4000PSI CGA 540
https://www.amazon.com/Yaetek-Regulator-Cutting-0-200PSI-0-4000PSI/dp/B073P1C18S/ref=dp_prsubs_1?pd_rd_i=B073P1C18S&psc=1
How Electronic Fuel Injection Works
https://jalopnik.com/how-electronic-fuel-injection-works-499902815
"For a gasoline engine, fuel pressure is usually on the order of 35-50 psi. Fuel injectors connect to the rail, but their valves remain closed until the ECU decides to send fuel into the cylinders.
10kWp Genset HHO Gas Ignition Modification
Off-the-shelf assembled kit for $65+sh
Peripheral Interface Controller Transistorized Ignition Module
https://www.model-engine-ignition.com/model-engine-ignition/ignition-modules/pictim-deluxe-ignition-module
What's a PICTIM?  It's a Peripheral Interface Controller Transistorized Ignition Module - fancy words for a microprocessor controlled ignition module. This product is a collaborative effort between S/S Machine & Engineering LLC and Outpost Enterprises LTD - two of the largest providers of ignition modules for model engine enthusiast and builders.
Our goal was to create one 6-12 volt module that can "do it all".  Heck, it will even operate on a 9v smoke alarm battery! See this YouTube video --> https://youtu.be/yHBO0y3P4e4
At the heart of the unit is a microprocessor that allows these capabilities:
    Dual Mode Operation (Deluxe PICTIM)
    Swappable for multiple modes of operation (Basic PICTIM)
    Automatic safety shutoff
    Efficient operation - minimizes battery consumption
    Easy to setup (little to no "dwell" consideration)
    Programmable
Being programmable allows us to support multiple functionality by changing out the microchip (PIC),  or with an on-board jumper (Deluxe version).  Current PIC offerings are:
    SINGLE spark chip, provides one spark for every revolution of the crank or cam shaft
    BUZZ chip, provides a "shower" of sparks, ideal for hit & miss or low compression engines
    DUAL chip (included in Deluxe PICTIM) does both with an on-board jumper change
Download the PICTIM.pdf below for operation details of each mode (page 5).
Possible future PIC offerings:
    an ADVANCE chip, automatic ignition advance timing for higher performance engines
    a rev limiter, to prevent an engine from RPM red-lining
Download the PICTIM assembly, install and operation instructions PDF here ==> PICTIM.pdf
https://drive.google.com/file/d/1lfUPf6YfXAn6YGm0Isxxn5CS5CPfwNOe/view?usp=sharing
KHK DS1-40, Module 1, 40 Tooth, Injection Molded Spur Gears
https://www.khkgears.us/catalog/product/DS1-40
40 tooth to 80 tooth, Gear Sprockets
2 to 1 ratio
to get rid of the "Waste Spark" in the single cylinder, 18hp genset engine to convert to HHO gas.
This is the low cost solution, under $200.
The high cost version is the Haltech at $1850 with complete control for all the sensors in modern car engines.
It feels like a Jetsons version of reality time folks...
Spacely Space Sprockets, Inc.
« Last Edit: 2022-04-12, 05:20:09 by vrand »
We are getting close
The "The Matrix" "Feels Threaten"
Once everyone has "Free Energy,"  "the gig is up"
"Free Energy" allows more freedom of movement, in a "New Dimension" to travel in called UP, as in flying off this planet and to the Stars!
And no more bumpy/non-smooth roads to drive over, Think Hovercrafts!  :)
"This is for all the marbles"
A new world with "Free Energy" and a "The Jetsons" future dream world, with flying cars, flying saucers, hover crafts, "electric passenger drones,"
transmutation of any elements,
being able to create any materials needed,
to be able to create virtually anything from another "New Dimension" called
"counter space," ZPE, the Ether, Fusion Energy, Cold Fusion, where anything is possible like "building castles in the sky,"
"castles in the air"
Peace on Earth
10 Fascinating Facts About 'The Jetsons' On The Show's 60th Anniversary
Aly Weisman
Sep 24, 2012, 10:29 AM
https://www.businessinsider.com/10-fascinating-facts-about-the-jetsons-on-the-shows-50th-anniversary-2012-9
 -  The show premiered in 1962—at the height of theSpace Race—as the United States and the Soviet Union competed to make it to the moon first.
« Last Edit: 2022-05-26, 20:23:00 by vrand »
vrand
Interesting and I built the same thing with an Arduino a while back.
I used the engine points then later a hall effect sensor as an input/Arduino interrupt and all other ignition firing points were based off that. Since it is an interrupt we can also use the time between interrupts(one revolution) in millis to calculate RPM. As well, since the time between interrupts gives us RPM we can retard/advance the actual timing based on the difference between the interrupts. So we can build an efficient ignition module for around $20.
I wanted my own Arduino ignition module for an old B&G 8 HP engine so I could update the ignition to plasma, ie water spark plug circuit. I'm rebuilding my old CHP (combined heat and power) unit since the price of natural gas has doubled here. In the CHP setup the power generated pays for the fuel and we basically get all the waste heat for free, free heat is good.
It also opens up another interesting technology...
As it turns out all of us have been lied to and our plastics are not being recycled and all our garbage is simply being buried. Apparently the people in charge of this stuff are imbeciles and basically clueless. Which begs the question, why would I give them my garbage, plastics, used oil etc if there just going to bury it anyways?.
If I already have a CHP unit I can simply use part of the waste exhaust heat to convert all my garbage into extra fuel using pyrolysis. I basically throw all my garbage into an insulated and sealed 45 gallon drum. Then I route part of the hot exhaust gasses through the drum which slowly converts all the material into hydrocarbon gasses to be sucked into the intake as fuel. Were then left with a small amount of some metals, carbon and non-combustibles in the bottom of the drum as garbage.
I mean, if the authorities are too stupid to act responsibly then I'm not going to give them my garbage. It's my garbage and it has an inherent value as fuel to generate electricity and heat. I also have an interest in not letting these retards destroy the planet. So in my opinion it's a win win...
AllCanadian
You touch a hot topic ( of big interest lately)
Not wanting to take topic off theme ( well HHO is actually part of ….
TDF ….
Hey Chet
I thought it applied because we usually need a prime mover of some sort like an ICE to transform the HHO into electrical energy. It's important to understand a Combined Heat and Power unit like mine can run on any kind of fuel including HHO. Used oil, bacon fat, grass clippings, wood chips, plastics, used paint and basically any non-metal is fuel. I want to simplify the system so that adding any kind of fuel is as easy as taking out the trash.
I'm also working on my AC grid tie plug and play cheater system for my CHP/garbage pyrolysis machine.
Suppose we have a FE device or CHP system and want to power your house. It's problematic with smart meters, right wing people, nosy neighbors and utilities who get triggered by free/renewable energy. With my system I can plug any device into any circuit and it communicates with my panel ensuring I never export energy to the grid. To the grid and everyone else it looks like I'm simply using less power not generating any. Problem solved and everyone can mind there own business versus getting involved in mine.
vrand
Allcanadian
Interesting idea using  an Arduino, I will look into it! :)
Thank you for sharing :)
vrand
The Transcendental Object at the End of Time
"Free Energy," "flying saucers" are both a physical and non physical object, transcendental.
The Shockwave of Eschatology (Terence McKenna)
https://www.youtube.com/watch?v=vfGV_XwOync
"It feels like, we are near the final moment of the cosmic drama.
The birth of the soul, the transcendental conscious."
Sailing to Byzantium
By William Butler Yeats
 Once out of nature I shall never take
My bodily form from any natural thing,
But such a form as Grecian goldsmiths make
Of hammered gold and gold enamelling
To keep a drowsy Emperor awake;
Or set upon a golden bough to sing
To lords and ladies of Byzantium
Of what is past, or passing, or to come.
Peace on Earth
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-05-30, 21:55:39
