Thank you for posting the stl files vrand. The devil is always in the details.
I'm curious, do you intend to build a PWM controller for this project?
Cadman
Hi, At the moment no need to, doing "dual use" of what I have on hand. R&D gets you to make due with what you've got. Also burned up lessor PWM units along the way. ugh Currently having success with a Tig welder and using it as a CC, Constant Current, IGBT PWM, with high amperage outputs, up to 200A HITBOX TIG200P HITBOX TIG200P TESTING VIDEOhttps://www.youtube.com/watch?v=73sdMYhBMC4HITBOX Pulse TIG ARC Welder 200A 110/220V Dual Voltage Inverter IGBT Stick TIG ARC MMA Welding Machine with Digital Welding Torch HBT2000P https://www.amazon.com/Inverter-Digital-Welding-Machine-HITBOX/dp/B07JPZSL5JFreddy discovered its all about the current amperage you feed this fuel cell, the more amps the more HHO gas output. But a more important discovery was that you didn't need the high current all the time. Only needed it to reach the tank PSI pressure of 40 to 55 PSI Once you reached this critical PSI pressure, by inputting max. current, then you only needed to maintain that PSI (a fraction of the amperage) when the unit was running. That is how his units gets the COP of 50.That was a Breakthrough discovery, that I hope to recreate. the sky's the limit.This Tubular HHO Fuel Cell is scalable, like powering ocean liners, trains, planes, you name it. Freddy was using 3 phase forklift battery chargers on his twin 8 foot tall 6" diam. outer tube on his V96M tubular HHO fuel cell unit. They were powering that Onan V16 Cat. propane converted engine, to run on HHO.This Hitbox TIG welder inverter is pretty sophisticated as a welder, and also works great for powering this tubular HHO V624 fuel cell.My near term goal is to use the 3 units, V624 fuel cell, as a single unit to fuel a small propane genset. to run on the HHO gas output. It is a 16hp, 436cc dual fueled engine, DuroMax XP10000EH 18hp 10000 Watt Hybrid Dual Fuel Portable Gas Propane Generator - RV Standby
« Last Edit: 2022-01-30, 20:20:59 by vrand »
