Inventor of the Neutral Plates in HHO Units was from a Bulgarian Inventor named:Yul BROWNThe Bulgarian Inventor That Made Fire from Water by Daniel Montiglio https://www.foreigner.bg/the-bulgarian-inventor-that-made-fire-from-water/Brown's Gas Neutralization of Radioactivity Rex Researchhttp://www.rexresearch.com/brown-haley/brown-haley.htmClean Energy Review ...We now proceed to the experimental results obtained by advanced transmutation which have direct bearing on the problem of disposal of nuclear waste fuel. Interaction with ionic hydrogen and ionic oxygenBrown's Gas has been developed by a Bulgarian-born Australian national, Prof. Yull Brown. In his process, water is separated into its two constituents, hydrogen and oxygen in a way that allows them to be mixed under pressure and burn simultaneously and safely in a 2:1 proportion. The proprietary process results in a gas containing ionic hydrogen and oxygen in proper mixes which is generated economically and safely and which may be compressed up to 100 psi. Brown's Gas is a "cornerstone of a technological edifice" with many commercial and industrial applications. At this time, Brown's Gas generators are mass produced in the Bautou, a major research city in the People's Republic of China by the huge NORINCO factory which also manufacturers locomotives and ordinances -- and services the nation's nuclear industry complex. Most of these generators (producing up to 4,000 litres/hour/2.4 water at 0.45 MPa with power requirements ranging from 0.66 kW up to 13.2 kW) are marketed for their superior welding and brazing qualities, costing between $ 2,000 and $ 17,000. Some units have been used for the decontamination of radioactive materials since 1991. In general, Brown's Gas generators produce between 300 and 340 litres of Brown's Gas per 1 kW energy DC current approximately and one litre of water produces 1.866.6 approximately litres of gas. A generator which produces 10,000 litres per hour has been built specifically for the reduction of nuclear waste. On August 24, 1991, Baotou's Nuclear Institute # 202 released a report, The results of experiments to dispose of radiation materials by Brown's Gas which establishes that experimentation on Cobalt 60 radiation source decreased radiation by about 50% or half-life of radiation -- but sometimes more radiation is decreased which needs investigation of possibilities for decreasing more of the radiation in single treatments of exposure to Brown's Gas flame, lasting only a few minutes, in the samples as described in the table below. First Experiment Second Experiment Source Intensity 580 millirads/hour 115 - 120 millirads/hour After Treatment 220 - 240 millirads/hour 42 millirads/hour De-radioactivation of Cobalt 60 by exposure to Brown's Gas flame for less than 10 minutes. 1991 experiments conducted by Baotou Nuclear Institute # 220, People's Republic of China.
« Last Edit: 2022-01-29, 06:45:41 by vrand »
