2025-05-02, 00:48:39
Pages: 1 2 3 4 5 6 [7] 8 9 10 11
Author Topic: HHO Tubular Browns Gas Build  (Read 26404 times)
50kWp Genset Trailer, V96M Design, cont.
More photos:
- Ingersoll Rand E-Series 5 kW Oil-Free Air Compressor
- HHO Gas Line Output to Genset background, and also showing close-ups on trailer:
  - 6" Dia. Outer tube of the V96M with Negative connection strapped to 4/0 Gauge 0000 AWG orange cable.
  - Alloy Products, 316L stainless steel 35 Gal. vertical. 18' diameter x 30" tall. pressure vessel top lid, of "Gas Separator" unit.
  - 5 Gal. Gas Bubbler stainless tank
Max Planck,
the unlikely founder of quantum physics, knew how to change his mind.
By Brandon R. Brown
June 01, 2015
https://slate.com/technology/2015/06/max-plancks-principle-physics-and-constant-he-knew-how-to-change-his-mind.html
In sociology of scientific knowledge, Planck's principle is the view that scientific change does not occur because individual scientists change their mind, but rather that successive generations of scientists have different views.
https://en.wikipedia.org/wiki/Planck%27s_principle
This was formulated by Max Planck:[1]
    A new scientific truth does not triumph by convincing its opponents and making them see the light, but rather because its opponents eventually die and a new generation grows up that is familiar with it. . . .
An important scientific innovation rarely makes its way by gradually winning over and converting its opponents: it rarely happens that Saul becomes Paul. What does happen is that its opponents gradually die out, and that the growing generation is familiarized with the ideas from the beginning: another instance of the fact that the future lies with the youth.
    — Max Planck, Scientific autobiography, 1950, p. 33, 97
The Hydrogen Economy, HHO Fuel Cells to Power Engines
Everyone talked about how great it would be due to run your economy on hydrogen gas, no pollution and it is renewable, like solar energy.
Some of the problems was how to make the hydrogen gas economically, efficiently and easy enough so that anyone could build one.
Well it looks like the tubular HHO Brown's Gas fuel cell is the answer and more.
As more tubular fuel cells get built, there will also be more understanding and development.
That is the goal of my postings here, to show that anyone can now build their own unit.
Flat plate HHO designs are all over the internet and youtube.
The time has arrived for Tubular HHO fuel cells, the Hydrogen Economy and Energy Independence
More photos from Freddy's "Quantum Fuels" webpage:
https://wellssportstore.com/quantum-fuels
- 50kWp Trailer parts labled
- V96M Fuel Cell - Top Hose Connections
V96M Fuel Cells for 50kWp and 1.5 MWp gensets
photos from 2016 video progress report:
- 2 sets of 8 foot long, 6" diameter to 1" diameter stainless steel tubes
« Last Edit: 2022-02-14, 12:59:51 by vrand »
V624 End Caps v6c
To increase water throughput into and out of the fuel cell more holes are needed for both the input and out end caps. see attached drawings.
Due to the 1/16" space clearance between the neutral tubes in this V624 design, water flow tests show a decrease of 25% throughput,
to 3.75 gal/min from 5 gal/min out of 1/2" dia. hose to 65psi water pump.
And then add +50A of HHO gas the output decreases some more.
Looks like Freddy also added holes in some of his neutral tubes to increase water/gas flow through his fuel cell. see above post photos.
3D print STL file attached
Larger Cell Spacing from 1/16" to 3/16"
Tubular HHO Unit
The next size up in cell spacing is 3/16" or 0.1875" from 0.0625"
On Topic
On February 15 Professor John J. Mearsheimer gave a talk (video) about the Ukraine crisis. He starts out (at 3min) by explaining who has caused it:
    The United States, mainly, and its allies are responsible for this crisis.
NO TO WAR IN UKRAINE
https://www.youtube.com/watch?v=Nbj1AR_aAcE
realpolitik
Its all about the oil, gas pipeline and energy as usual...
« Last Edit: 2022-03-01, 16:40:31 by vrand »
184 million USA Casualties; Nuke Map Simulation WWIII
https://nuclearwarmap.com/
"It's all about the energy" stupid
This is Russia's Cuban Missile Crisis
The Devastating Effects of Nuclear Weapons
https://thereader.mitpress.mit.edu/devastating-effects-of-nuclear-weapons-war/
Richard Wolfson and Ferenc Dalnoki-Veress reveal the most horrifying realities of nuclear war.
Image source: U.S. Department of Energy
By: Richard Wolfson and Ferenc Dalnoki-Veress
What can nuclear weapons do?
How do they achieve their destructive purpose? What would a nuclear war — and its aftermath — look like? In the article that follows, excerpted from Richard Wolfson and Ferenc Dalnoki-Veress’s book “Nuclear Choices for the Twenty-First Century,” the authors explore these and related questions that reveal the most horrifying realities of nuclear war.
A Bomb Explodes: Short-Term Effects
An exploding nuclear weapon instantly vaporizes itself. What was cold, solid material microseconds earlier becomes a gas hotter than the Sun’s 15-million-degree core. This hot gas radiates its energy in the form of X-rays, which heat the surrounding air. A fireball of superheated air forms and grows rapidly; 10 seconds after a 1-megaton explosion, the fireball is a mile in diameter. The fireball glows visibly from its own heat — so visibly that the early stages of a 1-megaton fireball are many times brighter than the Sun even at a distance of 50 miles. Besides light, the glowing fireball radiates heat.
This thermal flash lasts many seconds and accounts for more than one-third of the weapon’s explosive energy. The intense heat can ignite fires and cause severe burns on exposed flesh as far as 20 miles from a large thermonuclear explosion. Two-thirds of injured Hiroshima survivors showed evidence of such flash burns. You can think of the incendiary effect of thermal flash as analogous to starting a fire using a magnifying glass to concentrate the Sun’s rays. The difference is that rays from a nuclear explosion are so intense that they don’t need concentration to ignite flammable materials.
« Last Edit: 2022-03-03, 07:56:40 by vrand »
Off-Topic:
How to Start WWIII and
Drive oil to $200 per barrel
CIA: Undermining and Nazifying Ukraine Since 1953
https://www.voltairenet.org/article189895.html
https://www.strategic-culture.org/news/2016/01/08/cia-undermining-and-nazifying-ukraine-since-1953/
Wayne Madsen
January 8, 2016
The recent declassification of over 3800 documents by the Central Intelligence Agency provides detailed proof that since 1953 the CIA operated two major programs intent on not only destabilizing Ukraine but Nazifying it with followers of the World War II Ukrainian Nazi leader Stepan Bandera.
The CIA programs spanned some four decades. Starting as a paramilitary operation that provided funding and equipment for such anti-Soviet Ukrainian resistance groups as the Ukrainian Supreme Liberation Council (UHVR); its affiliates, the Organization of Ukrainian Nationalists (OUN) and Ukrainian Insurgent Army (UPA), all Nazi Banderists. The CIA also provided support to a relatively anti-Bandera faction of the UHVR, the ZP-UHVR, a foreign-based virtual branch of the CIA and British MI-6 intelligence services. The early CIA operation to destabilize Ukraine, using exile Ukrainian agents in the West who were infiltrated into Soviet Ukraine, was codenamed Project AERODYNAMIC
A formerly TOP SECRET CIA document dated July 13, 1953, (thats 52 years of TOP SECRET folks ed.) provides a description of AERODYNAMIC: «The purpose of Project AERODYNAMIC is to provide for the exploitation and expansion of the anti-Soviet Ukrainian resistance for cold war and hot war purposes. Such groups as the Ukrainian Supreme Council of Liberation (UHVR) and its Ukrainian Insurgent Army (OUN), the Foreign Representation of the Ukrainian Supreme Council of Liberation (ZPUHVR) in Western Europe and the United States, and other organizations such as the OUN/B will be utilized». The CIA admitted in a 1970 formerly SECRET document that it had been in contact with the ZPUHVR since 1950. (thats 20 years TOP SECRET guys)
The OUN-B was the Bandera faction of the OUN and its neo-Nazi sympathizers are today found embedded in the Ukrainian national government in Kiev and in regional and municipal governments throughout the country.
AERODYNAMIC
placed field agents inside Soviet Ukraine who, in turn, established contact with Ukrainian Resistance Movement, particularly SB (intelligence service) agents of the OUN who were already operating inside Ukraine. The CIA arranged for airdrops of communications equipment and other supplies, presumably including arms and ammunition, to the «secret» CIA army in Ukraine. Most of the CIA’s Ukrainian agents received training in West Germany from the US Army’s Foreign Intelligence Political and Psychological (FI-PP) branch. Communications between the CIA agents in Ukraine and their Western handlers were conducted by two-way walkie-talkie (WT), shortwave via international postal channels, and clandestine airborne and overland couriers.
Agents airdropped into Ukraine carried a kit that contained, among other items, a pen gun with tear gas, an arctic sleeping bag, a camp axe, a trenching tool, a pocket knife, a chocolate wafer, a Minox camera and a 35 mm Leica camera, film, a Soviet toiletry kit, a Soviet cap and jacket, a .22 caliber pistol and bullets, and rubber «contraceptives» for ‘waterproofing film’. Other agents were issued radio sets, hand generators, nickel-cadmium batteries, and homing beacons.
An affiliated project under AERODYNAMIC was codenamed CAPACHO.
 CIA documents show that AERODYNAMIC continued in operation through the Richard Nixon administration into 1970.
The program took on more of a psychological warfare operation veneer than a real-life facsimile of a John Le Carré «behind the Iron Curtain» spy novel. The CIA set up a propaganda company in Manhattan that catered to printing and publishing anti-Soviet ZPUHVR literature that would be smuggled into Ukraine. The new battleground would not be swampy retreats near Odessa and cold deserted warehouses in Kiev but at the center of the world of publishing and the broadcast media.
The CIA front company was Prolog Research and Publishing Associates, Inc., which later became known simply as Prolog. The CIA codename for Prolog was AETENURE. The group published the Ukrainian language «Prolog» magazine. The CIA referred to Prolog as a «non-profit, tax exempt cover company for the ZP/UHVR’s activities». The «legal entity» used by the CIA to fund Prolog remains classified information. However, the SECRET CIA document does state that the funds for Prolog were passed to the New York office «via Denver and Los Angeles and receipts are furnished Prolog showing fund origin to backstop questioning by New York fiscal authorities».
As for the Munich office of Prolog, the CIA document states that funding for it comes from an account separate from that of Prolog in New York from a cooperating bank, which also remains classified. In 1967, the CIA merged the activities of Prolog Munich and the Munich office of the Ukrainian exiled nationalist «Suchasnist» journal. The Munich office also supported the «Ukrainische Gesellschaft fur Auslandstudien». The CIA documents also indicate that US Federal Bureau of Investigation (FBI) agents may have interfered with AERODYNAMIC agents in New York. A 1967 CIA directive advised all ZPUHVR agents in the United States to either report their contacts with United Nations mission diplomats and UN employees from the USSR and the Ukrainian SSR to the FBI or their own CIA project case officer. CIA agents in charge of AERODYNAMIC in New York and Munich were codenamed AECASSOWARY agents. Apparently not all that taken with the brevity of MI-6’s famed agent «007», one CIA agent in Munich was codenamed AECASSOWARY/6 and the senior agent in New York was AECASSOWARY/2.
AECASSOWARY agents took part in and ran other AERODYNAMIC teams that infiltrated the Vienna World Youth Conference in 1959. The Vienna infiltration operation, where contact with made with young Ukrainians, was codenamed LCOUTBOUND by the CIA.
In 1968, the CIA ordered Prolog Research and Publishing Associates, Inc. terminated and replaced by Prolog Research Corporation, «a profit-making, commercial enterprise ostensibly serving contracts for unspecified users as private individuals and institutions».
The shakeup of Prolog was reported by the CIA to have arisen from operation MHDOWEL. There is not much known about MHDOWEL other than it involved the blowing of the CIA cover of a non-profit foundation. The following is from a memo to file, dated January 31, 1969, from CIA assistant general counsel John Greany, «Concerns a meeting of Greaney, counsel Lawrence Houston and Rocca about a ‘confrontation’ with NY FBI office on January 17, 1969. They discussed two individuals whose names were redacted. One was said to be a staff agent of the CIA since 8/28/61 who had been assigned in 1964 to write a monograph, which had been funded by a grant from a foundation whose cover was blown in MHDOWEL (I suspect that is code for US Press). One of the individuals [name redacted] had been requested for use with Project DTPILLAR in November 1953 to Feb. 1955 and later in March 1964 for WUBRINY. When the Domestic Operations Division advised Security that this person would not be used in WUBRINY, Rocca commented that ‘there are some rather ominous allegations against members of the firm of [redacted],’ indicating one member of that firm was a ‘card-carrying member of the Communist Party.’ The memo went on to say that Rocca was investigating the use of the individual in Project DTPILLAR concerning whether that person had mentioned activities in Geneva in March 1966 in connection with Herbert Itkin». Raymond Rocca was the deputy chief of the CIA’s Counterintelligence Division. Itkin was an undercover agent for the FBI and CIA who allegedly infiltrated the Mafia and was given a new identity in California as «Herbert Atkin» in 1972.
In 1969, AERODYNAMIC began advancing the cause of the Crimean Tatars. In 1959, owing to Canada’s large Ukrainian population, Canada’s intelligence service began a program similar to AERODYNAMIC codenamed «REDSKIN».
As international air travel increased, so did the number of visitors to the West from Soviet Ukraine. These travelers were of primary interest to AERODYNAMIC. Travelers were asked by CIA agents to clandestinely carry Prolog materials, all censored by the Soviet government, back to Ukraine for distribution. Later, AERODYNAMIC agents began approaching Ukrainian visitors to eastern European countries, particularly Soviet Ukrainian visitors to Czechoslovakia during the «Prague Spring» of 1968. The Ukrainian CIA agents had the same request to carry back subversive literature to Ukraine.
AERODYNAMIC continued into the 1980s as operation QRDYNAMIC, which was assigned to the CIA’s Political and Psychological Staff's Soviet East Europe Covert Action Program. Prolog saw its operations expanded from New York and Munich to London, Paris, and Tokyo. QRDYNAMIC began linking up with operations financed by hedge fund tycoon George Soros, particularly the Helsinki Watch Group’s operatives in Kiev and Moscow. Distribution of underground material expanded from journals and pamphlets to audio cassette tapes, self-inking stamps with anti-Soviet messages, stickers, and T-shirts.
QRDYNAMIC expanded its operations into China, obviously from the Tokyo office, and Czechoslovakia, Poland, Estonia, Lithuania, Latvia, Yugoslavia, Afghanistan, Soviet Central Asia, the Soviet Pacific Maritime region, and among Ukrainian-Canadians. QRDYNAMIC also paid journalist agents-of-influence for their articles. These journalists were located in Sweden, Switzerland, Australia, Israel, and Austria.
But at the outset of glasnost and perestroika in the mid-1980s, things began to look bleak for QRDYNAMIC. The high cost of rent in Manhattan had it looking for cheaper quarters in New Jersey.
Assistant Secretary of State for European/Eurasian Affairs Victoria Nuland, the baked goods-bearing «Maiden of Maidan,» told the US Congress that the United States spent $5 billion to wrest control of Ukraine from the Russian sphere since the collapse of the Soviet Union. With the recent disclosures from the CIA it appears that the price tag to the American tax payers of such foreign shenanigans was much higher.
The views of individual contributors do not necessarily represent those of the Strategic Culture Foundation.
Tags:
Canada
CIA
Nuland
Ukraine
United States
« Last Edit: 2022-03-08, 06:03:43 by vrand »
Wayne Madsen
Investigative journalist, author and syndicated columnist
His columns have appeared in a wide number of newspapers and journals.
Madsen is a regular contributor on Russia Today.
He has written The Handbook of Personal Data Protection (London: Macmillan, 1992);
Genocide and Covert Operations in Africa 1993-1999 (Edwin Mellen Press, 1999);
Jaded Tasks: Big Oil, Black Ops & Brass Plates and Overthrow a Fascist Regime on $15 a Day
and co-authored America’s Nightmare: The Presidency of George Bush II (Dandelion, 2003).
« Last Edit: 2022-03-08, 05:58:52 by vrand »
RT is the Kremlin Putin, false information press provider.
I will leave it at that.
Putin explains the military situation and why Ukraine might lose its future
Video from March 6th, 2022
https://www.youtube.com/watch?v=dT_W0Cs-wjs&t=105s
Extremely important statements by Putin (MUST SEE!)
http://thesaker.is/extremely-important-statements-by-putin-must-see/
As some of you know, Putin spoke at length with a group of Russian flight attendants. This is such an important statement that I asked one of our interpreters (thanks E.!) to subtitle the video.  I am also posting the transcript below.  In this exchange, Putin spells out in quite some details WHAT Russia is doing and WHY she is doing it.
Andrei
PS: please press “cc” to see the English language captions
Translated and subtitled by Eugenia
My question concerns the current situation in Ukraine. We all support your actions and the special operation that is underway there. Naturally, the most important question, which, one way or another, all of us have asked ourselves, is why this special operation has started. Could it not have been avoided? Rationally, we do understand and support your actions, but as women we cannot help but worry: for our family, relatives, for those who are in Ukraine. We know that the civilians are not impacted. But nevertheless, tell us, reassure us: what are we to expect at the end of this road? What will be the end result of the military operation in Ukraine?
I will be brief but still will have to start, as they say, from “the center of the field”. I said about this at the start of the operation and also spoke about this before this decision has been made, a hard decision, without a doubt.
What is this about? The fact of the matter is that after the anti-constitutional coup in Ukraine, which, unfortunately, was strongly supported by the Western countries – let us face it. They do not even hide the fact that they have spent $5 billion on it, not to mention cookies given away on Maidan, and so on. And after that, instead of bringing the situation back on track, even if it had spiraled out of control, even if it had been the act of the overzealous locals – there is such legal term, i.e. planned one thing, but the result turned out to be something else – they still could have, and should have, returned the situation back onto the political track.
Furthermore, shortly before the coup, the foreign ministers of the three countries came to Kiev in 2014 and signed an agreement with the Ukrainian government acting as guarantors of this agreement to ensure that the situation would be developing in the political sphere. But nothing like that occurred. They organized a coup d’état and supported the perpetrators. What followed were the well-known events related to the Crimea and the southeast of Ukraine, Donbass, where people refused to support the coup. As we know, the Crimea made a decision; people came to vote in a referendum to return to the Russian Federation. Naturally, yes, naturally, we cannot but support that decision, al the more so, since they felt they were in danger from the nationalists and neo-Nazis. There is strong evidence that they were absolutely right in that.
Later, or, rather, in parallel, the events in Donbass were taking place. What have these events led to? People resisting the results of the coup were persecuted. Eventually, the new Kiev authorities initiated a military operation on that territory. They have conducted two large-scale punitive operations using of heavy weapons and combat aviation. They directly attacked Donetsk destroying the city squares with aviation, using tanks and artillery. Both these military campaigns failed. The Ukrainian army suffered defeat. After that, so-called Minsk agreements, or the Package of Measures, to use the official term, have been concluded. The agreements offered a path for a peaceful settlement of the conflict.
We did everything we could to direct the events along this path, to restore the territorial integrity of Ukraine as well as to protects the interests of the people living in these territories. What did these people demand? Nothing but the basic things: the right to speak their mother tongue, i.e. the Russian, and maintain their traditions and culture. These were by no means extraordinary demands. But no. These territories were put under economic blockade; disconnected from the banking system; the supplies of food were stopped; the payments of the pensions and social assistance were suspended. Sometimes, some handouts were given, but in order to get those pensions and benefits a person had to cross the separation line.
Now listen. I will now say something that may sound rough but the situation compels me to say it. You know that occasionally in some regions packs of stray dogs attack people, injure or even kill them (this is a separate problem, and it is for the local authorities to deal with). But then these animals are poisoned or shot dead. But people of Donbass are not stray dogs. Approximately 13,000-14,000 people have been killed during these years. Over 500 children have been killed or injured. But what is particularly intolerable is that the so-called “civilized” West has preferred all these years to look the other way. All these years – 8 years! Eight years!
Moreover, lately the Kiev authorities started to say openly and publicly that they are not going to fulfill the Minsk agreements. They are saying this from the TV screens and online. They are saying this everywhere on the record: We don’t like them; we will not do it. And all this time, Russia has been accused of not fulfilling the agreements. This is simply nonsense; the theater of the absurd; white is called black and black is called white. Lately, things got even worse. Actually, the talk has started long ago, but intensified of late. More and more often we hear that Ukraine would be admitted into NATO. Do you understand what this could lead to? Or can lead to still?
If Ukraine is a NATO member, then according to the North Atlantic Treaty, all other members must support the country in case of a military conflict. No one besides us has recognized Crimea as a Russian territory. They are conducting military operations in Donbas but also could move onto Crimea, and in such case we would have to fight with the whole of NATO. What is that? Do you understand the consequences? I think everyone understands.
Now they (Ukraine) are talking about acquiring the nuclear status, i.e. developing nuclear weapons. We cannot possibly ignore such things, particularly considering that we know how the so-called West behaves with regard to Russia. First, Ukraine has some nuclear competence left from the Soviet time. As far as enrichment and nuclear material are concerned, they would be able to organize that work. They have missile abilities: suffice is to mention Yuzhmush. This company used to build intercontinental ballistic missile equipment for the Soviet Union. They could recover that ability and do it. And those from across the ocean would even help them do it. And after that would say: “Well, we do not recognize the nuclear status; they have done everything themselves”. And then they would put these complexes under control, and from that moment on, from that very second, the fate of Russia will be completely different. Because in that case, our strategic adversaries would not even need intercontinental ballistic missiles. They would keep us right here at the nuclear gunpoint, that is all. How could we disregard such a thing? These are absolutely real threats, not some far-fetched silly fantasy.
Our boys who are now fighting and risking their lives, they are fighting and giving their lives for our future, for the future of our children. This is something perfectly obvious. And the people who do not want to understand that, particularly those among today’s leaders (of Ukraine), have to understand that if they keep doing what the have been doing – I have spoken about this before – they put at risk the very future of the Ukrainian statehood. If this happens, that will be entirely their fault.
What is going on now? I have already mentioned our objectives in this operation. First, of course, is to protect the people living in Donbass. How? By demilitarizing and denazifying Ukraine as well as establishing its neutral status. Why? Because the neutral status means Ukraine will not be joining NATO. They have it written in the Constitution that the country will be joining NATO. You understand – they have included that into the Constitution!
Denazification
– what does this mean? I have spoken with my Western colleagues about this. They say:” What is the problem? You also have the radical nationalists”. Yes, we do. But we do not have them in the government, but everybody agrees that they (the Ukrainians) do. Perhaps, we have some idiots running around with swastika, but do we support that at the government level? Do thousands of people march with torches and swastikas on the streets of our capital or other cities in Russia, like it happened in 1930s in Nazi Germany? Is something like that happening in Russia? But it happens in Ukraine, and it is supported. Do we support those who killed the Russians, Jews, or the Poles during the war? Do we hail them as heroes? But in Ukraine, they do.
The current events are also very important. Look, the foreign citizens have been taken hostages in Sumy and Kharkov – over 6,000 young people, students. They have been driven together into a railway station and kept there for 3 days. Listen, they have been held there for the third day. We have told everybody about this and informed the current Ukrainian authorities. They said: “Yes, yes, of course, we will deal this this right now”. We have informed the leaders of the major European countries, I personally talked to them. “Yes, yes, we will put pressure on Ukraine right now”. We informed the UN Secretary-General: “Yes, yes, we will solve the problem right away”. Nobody is doing anything.
People who are considered the citizens of Ukraine are treated even worse. They are simply used as a human shield. Right now, in this very moment, this is happening in Mariupol. The Kiev government called our military: ”Provide humanitarian corridors so people could leave”. Naturally, our people instantly responded, even suspended the military activities, and were observing what was happening. But no one was allowed to leave. You understand, no one was allowed out. They do not anybody leave but instead use the people as a human shield. Who are they? The neo-Nazis, of course.
We already observe the presence of the militants from the Middle East and some European countries. We know about them; we can hear them speak on the radio. They are using so-called jihad-mobiles, i.e. cars stuffed with explosives, which they drive towards the Russian troops. But they do not achieve anything, and they will fail in the end. Who are they, then, if not neo-Nazis? By such actions, they are destroying their own country and their own statehood.
That is why one of our key demands is demilitarization. In other words, we are helping people of Donbass by working towards the neutral status of Ukraine and the demilitarization of the country. We have to know with certainty what weapons are there, where they are deployed, and who controls them. A number of options are on the table. We are discussing them now, including with the Kiev government representatives in our talks in Belarus. We are grateful to the President Lukashenko for organizing the meetings and helping us to conduct these negotiations. Our proposals are on the table for the groups of the negotiators from Kiev to study. We hope that Kiev will respond positively to our proposals. This is pretty much all I wanted to say.
Please, let us continue.
Schvidko, Yulia, the second pilot of the Aeroflot airline. Vladimir Vladimirovich, good afternoon. My question is about the current situation. Many rumors are circulating about possible introduction of the marshal law, drafting of volunteers and reservists, and that the draftees will be sent to Ukraine. Could you clarify whether the marshal law will be declared and whether the drafted soldiers will be deployed to Ukraine.
Many of what we now see and what is happening is undoubtedly a technique to fight against Russia. By the way, the sanctions imposed today are close to a declaration of a war. But fortunately, we are not there yet. I believe that our so-called “partners” still retain some understanding of what a war would mean and what danger it presents for everybody. That is despite that irresponsible statements, such as made by the British Foreign Minister, when she blurted that NATO could involve itself in the conflict. At that point, we had to immediately make a decision to put our strategic forces on high alert. They reacted by saying that they did not mean anything of the sort. However, nobody put the Minister in her place, and nobody disavowed her statement. No one said anything to us about that statement, like it was her personal opinion, do not pay attention, or something like that. Nothing. What are we supposed to think about that? That is why we reacted the way we did.
Now about your question. The marshal law is introduced by the order of the President supported by the Federation Council in the case of the external aggression, specifically in the regions where the military activity takes place. We are not in that situation now, and I hope will not be. This is first. The second point – there is also, in addition to the marshal law, a special status. This status is also declared by the Federation Council in case of a significant internal threat. The third regime is the state of emergency, which is usually declared in particular regions, although could also be adopted in the entire territory of the country. This regime is for technological and natural disasters. Thanks God, this is also not happening. We are not planning to declare any of these regimes on the territory of the Russian Federation. There is no need for that today.
We can see that attempts are being made to stir up trouble in our society, which is again a conformation of my words that we are dealing with not just the radicals but with the neo-Nazis. Here people are expressing their opinion about what they like or dislike in our action in Ukraine. But there, in Ukraine, people that express the opinions similar to those expressed by the so-called ‘liberal” part of our society, are being detained on the streets and shot – we do have confirmation of that. Our special services are now collecting this information and we will be presenting it soon. Our liberal intellectuals are protesting, whereas in Ukraine people that say anything in favor of Russia are been executed without trial.
I repeat, that the marshal law is declared in case of the external aggression, which I hope will not happen despite irresponsible statements of some officials. We hear that a no fly zone should be established over the Ukrainian territory. This is impossible to do in the territory of Ukraine itself; this is only possible to organize from the territories of the neighboring countries. However, we will consider any movement in this direction as active participation in the military conflict by a country, the territory of which is used to create danger for our servicemen. We will in a second consider them as a party to the military conflict. I hope this is also understood, and it will not come to that.
Only professional military personnel are taking part in this operation, officers and contract servicemen. Not a single drafted soldier is participating, and we are not planning to send them to Ukraine, and we will not. I repeat only men who have made a voluntary responsible decision in their lives – to defend their country – are in Ukraine, and they are doing their duty with honor. Why this is the case, why we have the right to say these words, I have just explained to you. This also applied to reserve personnel undergoing periodic military training – we are not planning to deploy them to Ukraine. They are summoned to the military training on the regular basis – this happens now and will be happening in the future – but we will not enlist these people for the active military service, and they will not participate in this conflict. We have sufficient resources to achieve our objectives employing only our professional army.
I would like to comment on the military operation itself. I know many rumors and stories are being circulating. I do not have much time to learn about this, but I have been informed that people talk a lot about what is happening and how the operation is proceeding. All analysts know what is going on, so I am not going to reveal any secrets here. We could have acted in many different ways. We could have helped the Donbass republics directly on the separation line, i.e. on the front, using our Russian army to support them. But in such case, considering the unconditional support by the West of the radical nationalists, the Ukrainian side would have received constant support by weapons, material, ammunition, and all.
That is why our General Staff and the Ministry of Defense decided on a different strategy. First that was done is the elimination of the military infrastructure. Not entirely, but largely. The weapon depots, ammunition depots, aviation, air defense systems. The destruction of the air defense systems requires certain time. You are civilians but you do work in aviation. You understand that these systems need to be uncovered and then destroyed; by now this work is largely done. That is what brings about the demands for a no fly zone. However, an attempt to put this into effect would lead to enormous and catastrophic consequences not only for Europe, but also for the entire world. I do believe that the people on the other side do understand that. That is why we have chosen this path, correctly, as it turned out. Our military is working responsibly doing everything possible to protect the civilians. Unfortunately, those neo-Nazi bandits do not have any consideration for the people. They even shoot their own servicemen who do not want to continue fighting – we do have evidence of that. Yes, those nationalists, neo-Nazis shoot their own servicemen. The nationalists are embedded in practically every Ukrainian military unit, several dozens of them in each, and they act in such a cruel way.
I repeat one more time: we will not deploy draftees or reservists to Ukraine to participate in this military operation. I am convinced that our army will achieve all our objectives. I do not doubt that for a second. This is evident from the way the operation is proceeding, which is strictly according to the plan, to the schedule; all is happening the way it had been planned by the General Staff. Oh, regarding volunteers, the young people who come to the recruiting stations – we are grateful to them for their patriotic sentiments, the desire to support their country and its army in this time. The very fact that they come is significant. However, their help is not required at this time. And I am convinced will not be needed. Now I am turning towards the camera. They will see me and hear what I am saying – thank you.
As some of you know, Putin spoke at length with a group of Russian flight attendants. This is such an important statement that I asked one of our interpreters (thanks E.!) to subtitle the video.  I am also posting the transcript below.  In this exchange, Putin spells ...
This is a new energy research forum. If you think you are dealing with people who would believe this crap then you have got us wrong. (I wonder what happened to mudped? Possibly his handlers took him off the case. Who knows?)
Fully with you Paul O0, seems there are other sleepers here too, I have been working them out slowly.
Sorry guys for the Off Topic - Got It
Imagine a world running on HHO Gas instead of Fossil Fuels!
That is where I am at, and this Tubular Browns Gas HHO Fuel Cell tech looks like a great way to acheive that Hydrogen Economy solution!
vs the current situation of using fossil fuels
US gas hits a record: $4.17 a gallon
Chris Isidore byline
By Chris Isidore, CNN Business
Issues Using HHO Fuel Gas in the Internal Combustion Engine (ICE)
- Timing of the ICE spark ignition
HHO ignites faster than fossil fuels, nanoseconds fast vs milliseconds fast with
2 Ways needed to slow it down the flame front of the HHO gas
1- Add a water Mister and inject into the ICE combustion chamber
2- Fire at TDC or after TDS
- Need to get rid of the Waste Spark
See video
Why Small Engine Spark Plugs Fire with Each Revolution
https://www.youtube.com/watch?v=Bchzjslk3-M
Any Motor Heads here? PM me Thx
Haltech Engine Management System
https://www.haltech.com/product/ht-150905-elite-1500/
ELITE 1500
PART NUMBER: HT-151900
FEATURES & APPLICATIONS
OVERVIEW
• Supports 1 to 12 Cylinder engines
• 2 Rotor engines
• Normally aspirated or forced induction
• Load sensing by Throttle Position (TPS), Manifold
Absolute Pressure (MAP) or Mass Air Flow (MAF)
• Staged, Sequential, semi sequential, batch or
multipoint injection patterns
• Distributor ignition systems, multi-coil systems, expand CDI
range or Haltech Multiplex CDI systems
• Connect to a wide range of display dashes and
expansion devices via CAN.
• Flexible tuning setup for Petrol (Gasoline), Methanol and
Ethanol allows you to simply select your fuel type
• Closed Loop 02 Control – Dual bank control for precise
tuning (With optional external CAN O2 Wideband
Controller Kit)
• Knock Control - Synchronised to engine position with high
speed digital filtering for accurate detection
• Variable cam control - Independently control up to 4
camshafts - Requires a minimum of 1 user defined input
& output per variable cam
• Closed Loop Idle Speed Control with learning for consistent
idle  stability.  Requires  1  or  2  user  defined  outputs  (BAC
type) or 4 user defined outputs (Stepper motor type)
• Long term learning (Auto tune) on fuel, ignition, cam, boost &
idle control maps (up to 4D)
« Last Edit: 2022-03-09, 15:22:19 by vrand »
20kWp Genset - Haltech 1500 ignition ECU Engine Control Unit
Photos of Freddy demo unit 4 cylinder Mitsubishi engine genset
fueled 100% by HHO
See videos
Monday running
Mar 1, 2019
https://www.youtube.com/watch?v=_Q44hFs_la8
fueled 100% by HHO
More photos and videos of gneset running on HHO gas
New demo
Mar 1, 2019
FastFreddy9111
85 subscribers
https://www.youtube.com/watch?v=QfV_aJsfmSg
Cost of Parts for HHO Gas Fuel Cell Build
The Haltech 1500 ECU at $1875 is another cost for "garage tinkers" in this HHO Gas research field.
ELITE 1500
OVERVIEW
Vrand,
A more economical and practical approach may be to pick a vehicle that is supported by say a company such as HP Tuners.  They make the interface that plugs into the OBDII interface on all newer computer controlled cars.  Then you only need to re-program the various parameters that are already set up for normal gasoline operation such as timing, fuel air ratio, etc.  To start with a blank CPU/ECM module and attempt to create all the various PIDs and parameters would be a monumental task even for the experienced programmer much less a novice.
I have done extensive programming on GM's LS engines over the years with HP Tuner's products and believe me when I say, the learning curve is very steep to make effective changes even if you are an electrical engineer .
Major Parts of the HHO Fuel Cell Build
- The tubular fuel cell tubes; stainless steel tubes 12" to 96" long from
      1/2" to 6" diameters, with 2 to 6 neutral tubes in-between
- Tube End Caps from epoxy/cement filled 3d printed hollow parts,
       to injection molded material to Teflon machined
- 50-400A 12-48VDC  power supply
- The steel storage HHO gas tanks 65 psi
- Water re-circulating pump, 65 psi, 10 gallons per minute, from fuel cell to gas separator
- HHO gas to water, separator tank
- HHO gas bubblier
- Engine control unit for ignition timing control to waste spark removal
- Water mister injection system
- Deep cycle 12 VDC batteries 24-48 volt DC
- ICE Engine to convert, vehicle or stationary
Stationary Applications
- Genset Electrical Generator to make electricity
- Heat exchanger to cool electrolyte and heat building space in co-generation config.
Vehicle Applications
- Cars
- Trucks
- Planes
- Ships
Hydrogen Economy Weekly Review
https://www.h2bulletin.com/hydrogen-economy-weekly-review-2/
« Last Edit: 2022-03-09, 19:07:21 by vrand »
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-05-02, 00:48:39
