2025-03-31, 18:30:16
Author Topic: Control Of The Ether (Matter And Energy) During 1875-1899 By John W. Keely  (Read 1942 times)
Lots of old documents available, especially from SVP and Mr. Pond about Keely's physics/ freq  research.
Lots of old documents available, especially from SVP and Mr. Pond about Keely's physics/ frequency research and experiments.  He used array of tuning forks hooked to thermocouples and thermopiles of silver, gold, and Platinum wires. The nodes created upper inharmonics that can affect matter, especially if using thirds harmonics. Some of the best reprinted references are:-- Dashed Against The Rock, The Snell Manuscript, Keely And His Discoveries, Free Energy Pioneer, and others.  Mass to energy, water decomposed to 3 levels, self running brass machines, gravity nullification of heavy steel and brass masses with acoustic vibration frequency inharmonics, high lift water pump means, magnetism, rotation , 51 inches vacuum generation,  23,000 lbs pressure generation in 15 seconds as checked on warehouse weigh scales and negative leverage arm lift of hydraulic cylinder . Hydrogen gas also generated. Improved optical microscope built.  Over 100 devices built and tested in his machine shop in Philadelphia, Pa. 90% of investor's funds went into shop work. The keely Motor Company was about 5 Million dollars in the 1800's. The public literature has the case listed as fraud, however. His free energy brass machine with 50 lbs internal pressure from water hammer shock vibrations, turned the flywheel which would saw wood chunks upon demonstrations. The Patent application was refused because the investor's names were not on it.  Have you heard of Keely?
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-03-31, 18:30:16
