2025-04-01, 01:22:36
Pages: 1 ... 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 [35] 36 37 38
Author Topic: Don Smith Akula, Ruslan, Stalker, device discussion and replications.  (Read 68278 times)
COLLECTION OF STATEMENTS
OF GUNTIS/COSMOLVE
1) Tariel said that the device is very simple;
2) 220V comes in and 220V comes out; 50 Hz;
3) everything is in the coil settings - actually in the windings; This is a bifilar coil, but in a non-standard way, closed in itself;
4) all the magic happens between the coils; trigger coil - output power coil; Try to mentally return to those years; no semiconductors, no RadioShack - nothing, just wires and transformers;
5) the most important thing is to generate sharp impulses;
6) the device is not a transformer, but a choke, in which high voltage - no more than 2000 volts - produces ionization of light; What you need is a small high voltage to give birth to new electrons, and a lot of electrons produced around the wires, secondly, to activate those electrons;
7) a static field or ionization is also called a dead magnetic field, but we can transform this field to do work;
high voltage at a certain frequency creates a dead magnetic field; If we synchronize this high voltage with a half-wave of low voltage, then we can turn the core into an electric generator and it will work like an internal combustion engine;
9) high voltage - injector, low voltage - piston, magnetic field - combustion chamber;
10) when generating pulses, a magnetic field is created in the bifilar coil, so in total you have one source, but in fact you have a resonant magnetic generator with two fields;
11) it is not enough to loop electricity through the coils, you need to interact with the environment (make a bridge); But remember always and always that this is a manipulation of time;
12) ions are attracted by ionization, this high-voltage field is magnetized by vibrations and we get a very powerful magnetic field, and this field is an external force; energy enters the coil through a magnetic field, rather than an electric or electrostatic one;
13) this device is not a toy, it has a great ability to change our lives and this must be done wisely; We must think globally; If anyone releases schemes, the government will quickly take control of them, they will be immediately declared illegal; In fact, the effect in this device is a very specific magnetic field, the technology itself is similar to an atomic reaction, but without the radiation pollution; BUT... This magnetic field, if you make it stronger, can kill you in seconds, or if you make it stronger, it can cause an effect like an atomic bomb; You can't change the world or change the rules of our governments. With this device YES you can! Free energy is only one side of it, the other side is the most powerful weapon in human history after nuclear energy! By the way, nuclear power is far behind in comparison to this principle (free energy); it generates its own magnetic field, which is independent of the earth's fields, without grounding the device produces too much energy, but that's another story, which is not related to Free Energy, there are more things than just Free Energy...
Clean production. Noiseless
Like this  :o
Watch this.
No spark plug: https://www.youtube.com/watch?v=O3ueB9omW6E
https://www.youtube.com/watch?v=kK5pOSgyvaw
Interesting, the whole "kacher - gizmo - antenna" is replaced by a Flyback transformer (LOPT) with its output wire running through the Grenade coil center ending(?) at the opposite side.
Guys can we talk on skype please. Any one in group
perhaps we might then get some where.
Or if any one wants to set it up.     Sil
So we are seeing now.
The flyback provide for lower pumping freq. I once tried that and got good results.
Get to set up my Skype
Good  notice Itsu,
It looks like the grenade can be ionized or charged differently then from an antenna coil?
My question is, is it unipolair what is happening here and has that been the case always?
Adding milli joules with a kHz frequency will bring a lot of power into the mixing grenade coil.
oops sorry
« Last Edit: 2024-02-18, 15:32:47 by AlienGrey »
Good  notice Itsu,
Try feeding the output of the Tesla coil back trough the iside of the Tesla coil with the earth tube see if you get the same reults I did. Reality just disapeard.
Good  notice Itsu,
Well, we have seen other HV sources before, like a nano-pulser (unidirectional) and even some piezo igniters.
The modern LOPT (Line Output Transformer) has some integrated HV diodes which in combination with a CRT as capacitor creates a pulsed (sawtooth?) DC (https://en.wikipedia.org/wiki/Flyback_transformer).
What the output signal looks like without any additional capacitance attached, i don't know, but IMO its still pulsed DC (unidirectional).
« Last Edit: 2024-02-18, 20:47:09 by Itsu »
The LOPT through the middle of the grenade coil arrangement reminds me of the Don Smith tabletop device, where he has the NST charging a capacitor, then discharging into L1 (red wire) which is in the centre of L2.
Here another
Just for generic reference to Aliengrey’s attention .
From our host Peterae ( 2009 ?)
https://www.overunityresearch.com/index.php?topic=25.0
Note to AG
Please note 1st post in above link
How information is shared for reference ( specs)
This is very important to get others upto speed on progress !
Or to get them seeing same thing as you on their bench .
Typically extremely important and never enough Data ( no such thing as too much Data in a replication file/thread!
Here another
Note to AG
Did Peter just copy it like the original Don Smith info and expect it to work with all those caps and diodes attached ?
I think if it was me I would have tried a few experiments on that wound device and the drive coupling winding and that cap across the one winding. With a Signal Generator and a Dble Beam scope. Also The coil winding needs a space between it and the bench top with those kind of voltages expected and you need to find the sesonant frequency of the L3 primory drive coil and the 2 caps what is it ? and the same with the other 2 windings conected to the HV diodes as well what is it ?
Here another
Note to AG
AG,
It's all about how to pass info for others to visualize and follow. It's not about his built. @Itsu is good at that already.
Well let him get on with it then lets see how it goes.
« Last Edit: 2024-02-19, 12:28:46 by AlienGrey »
That is William Barbat
Long time researcher and experimenter ( early days of “modern day “ FE research.
Spoke many times …and some members also engaged him at this forum .
His last comments were about coatings ( ceramic and… Graphene  at 1 layer ( molecular ?) thickness oriented in specific ways ?)
I remember the day he got his patent in the mail ..he was very excited ( from China I think he said ??)
Not certain his device ever got built the way he wanted..( translation… it never worked the way he expected do to
Technical issues ( try laying one layer of graphene … and at a specific orientation 10- years ago ( or more)
Last time I spoke with his daughter..Bill was not doing as well ( got on in years..
PS
Yes Peter’s bench experiment shown above is how Benches are meant to look here ,
And obviously some do still look this way .
Too many years of mystery around this Kapanadze and all the battles with absolutely nothing to show
Except some monetized you tube guy’s dropping crumbs.
And yet it has dominated the forum here in last few years
Mostly fights ..
Hopefully that will change very soon .
Fights which are over “substance” ( things which can be tested)..have some tolerance until the experiments are done or shown to support a claim.
Fights over unsupported opinions… zero room for that here ( looped ongoing decade long fights)
Best to post nothing if it’s just a continuation of flame wars .
Nobody enjoys that ( except the participants with their various personal agendas)
Ego etc etc
And we definitely don’t need another closed forum do to a few who just fight or look for ways to bring conflict .
As mentioned trying to sort that ATM .
Might take a few weeks as coordinating through time zones and work schedules is not easy ..
And there are always things happening in FE world day to day .
IMO ( and others here)
There is no time to waste in this quest for open source FE !
Also, from Steven Marks:
Yes there is a rotating field which causes electrons to flow in copper wire and be used to provide useful work force. There are many wires perpendicular to the main collector. This is a necessary part of the device.
Sincerely,
SM.
This perpendicular thing comes up a lot...
I was wondering how the output signal of a LOPT would look like when not connected to anything (HV probe only).
So i switched a LOPT using its input coil using 3.5V dc??!! only via a MOSFET switch at 15kHz (Square wave 50% duty cycle) see this setup:
Even at this low input voltage (3.5V), there is a hugh flyback pulse on the drain of the MOSFET switching the LOPT, see screenshot:
Blue is MOSFET gate signal, yellow the drain signal.
The output signal of this LOPT (no other load attached then the HV probe) looks like this:
So we have a 2.5KV DC signal with some (sawtooth like) ripple on top of it.
It looks to be that there is only some HV DC (static) signal inside the Grenade coil, so no (unidirectional) pulsed DC
Does this means regarding our grenade combining Itsu's post that the electrons in a electri field can be sucked into the grenade wire?
As there will be a electrostatic field using the flyback pulses to start the ionisation?
Ah the elastic band of elusion one step forward and two steps back, as with an elastic band the more you stretch it the thinner the width same with your idea here.
Ape,
Read carefully Items 5,6 and 7 of my post above of some selected statements about Device.
I recall that Tesla once mentioned about using a polished conductor (US685957 - Apparatus for the utilization of radiant energy). The coating might have been acting as a semiconductor. He applied for this patent in 1901, which I guess was long before semiconductors were common knowledge.
My present application is based upon a discovery which I have made that when rays or radiations of the above kind are permitted to fall upon an insulated conducting-body connected to one of the terminals of a condenser while the other terminal of the same is made by independent means to receive or to carry away electricity a current flows into the con denser so long as the insulated body is exposed to the rays, and under the conditions hereinafter specified an indefinite accumu lation of electrical energy in the condenser takes place.
Furthermore, the surface should be clean and preferably highly polished or amalgamated.
Also, in the above patent that I referenced earlier (US20140159845A1), I saw the following:
Applicant has deduced that Leimer's energy mag nification most likely was due to low-mass electrons that were liberated and made conductive in the antenna by alpha radiation, which allowed these special electrons to be given a greater-than-normal acceleration by the received radio broadcast photons. Applicant has further deduced that such low-mass electrons must have originated in a thin-film coating of cupric oxide (CuO) on the antenna wire.
CuO is a dull-black, polycrystalline, semiconducting compound that develops in situ on copper and bronze wire in the course of annealing the wire in the presence of air. Such CuO coatings have been observed by Applicant on historical laboratory wire at the Science Museum at Oxford University, U.K., and on copper house wire of that era in the U.S., indicating that CuO coatings were commonplace. In later years, annealing has taken place under conditions that prevent most oxidation. This is followed by acid treatment to remove any remaining oxides, leaving shiny wire.
To the best of the Applicant’s knowledge, and as noted, none of the devices Summarized above ever was commercially accepted or exploited for any of various possible reasons. To the Applicants best knowledge, no person other than the Applicant has ever indicated that the presence of cupric oxide on their wires could have provided energy magnification.
Also by way of example, the energy magnifying coil can comprise a semiconductive element or compound that has been doped with a particular element or compound that makes it conductive of low-mass electrons without illumination by photon radiation other than by ambient photons.
It's possible that the 'receiving' coil has a semi-conducting coating allowing one way absorption of electrons from particles ionized from high voltage. The coil would be acting similar to how a solar photovoltaic cell works.
Ifarrand many thanks for your input, but unfortunately that isn't the case here, we are more interested in Quantum physics and entanglement or Scalar here, so would you care to move your hypothesis to a choice thread more suitable, many thanks gain as we don’t want to confuse our particular thread.
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-04-01, 01:22:36
