2025-04-01, 01:22:36
Pages: 1 ... 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32 33 34 35 36 37 38
Author Topic: Don Smith Akula, Ruslan, Stalker, device discussion and replications.  (Read 68278 times)
img  Itsu
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #544 on: 2023-08-30, 14:36:08 »
Partzman, that's what i expected, so i tied the CLR pin to ground, but the chip does not function then (nor with the CLR pin tied to +5V).
Also, when putting several square wave frequencies on this CLR pin it does not seem to function, so i must conclude that this chip is dead (both of them as i have 2!!) or the pinout i use (from the datasheet) is wrong.
I will leave this setup for what it is and use the AG 50:1 divider setup using the 2 CD4017's.
Thanks,   Itsu
img  AlienGrey
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #545 on: 2023-08-31, 00:12:46 »
Itsu could it be the chips are ex equipment as a lot of the 74 LS have become obsolete there is the 74HC390 they work
but you need to add interface level change circuitry. I can't find a stockist of the 74ls56 or any +by 50 chips.
img  AlienGrey
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #546 on: 2023-08-31, 12:58:49 »
Here is the 74HC390 circuit it is also divide by 50 it's cheap and has 2 off + 5 stages and 2 + by 2 stages
that can be arranged in any format.
img  Maxolous
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #547 on: 2023-08-31, 17:33:26 »
AG,
Thanks for bringing out some facts.
Guys 74HC390 ie a versatile chip.
This is how it works;
1.  Divide by 2.
Signal in pin 1
Signal out in pin 3
Ground 2,4,8,12,14,15
Divide by 4
In 1
Out 13
Gnd 2,4,8,12,14
3. Divide by 5
In 4
Out 7
Gnd 1,2,8,12,14,15
4.  Divide by 10
In 1
Out 7
Tie 3-4
Gnd 2,8,12,14,15
5. Divide by 20
In 1
Out 13
Tie 3-4
Gnd 1,2,8,14,15
6. Divide by 50
Signal in 12
Signal out 7
Tie 1-9, 3-4
Ground 2,8,14,15
7.  Divideby 100
In 12
Out 3
Tie 9-13, 1-2, 4-13
Gnd 2,4,8
img  Maxolous
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #548 on: 2023-08-31, 17:54:18 »
It is a double ripple counter. That's two stages of divide by 2 and two of divide by 5.
2,2   5,5
By strapping output into input you can achieve divide by 100
freq/(2*2*5*5) =freq/100
« Last Edit: 2023-09-01, 11:27:18 by Maxolous »
img  AlienGrey
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #549 on: 2023-08-31, 19:24:36 »
yeah but you need one of the divide by 2 out puts on the output, to get a stable square wave on the output.
Also if you just want divide by 100 a CD4518 can do that or 50 but it's not a square wave. look at it on a
scope it's not stable
img  NickZ
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #575 on: 2023-09-21, 16:10:32 »
   Verpies:
   I don't need to continue on with this. Or prove anything because you say so.
Nor, do I need to be told what to do, in your opinion. You can however make suggestions, instead.
Look for yourself, if you don't believe me.
   Air cores... on all Akula, Ruslan, Stalker devices, which use a Kacher, Yoke/Grenade system. My statement stands.
   Or ask Itsu about that, as you don't seam to trust what I've mentioned. I'll leave you in good hands with him, as well.
img  verpies
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #576 on: 2023-09-21, 17:14:35 »
Quote from: NickZ on 2023-09-21, 16:10:32
So stop making unsupported assertions like: "all grenade former tubes are empty".
I would debate this. For starters I was absent from this forum for the last year and
In my absence, I could not mislead anyone yet you have not made any progress towards a working device, nor have you developed a plausible principle of operation.
You can however make suggestions, instead. Look for yourself, if you don't believe me.
Yes, I can and I do make suggestions to improve certain parameters of the device, but I do not make unsupported blanket assertions like you do: "all grenade former tubes are empty" ...or vice versa.
Show me.
Or ask Itsu about that.
Itsu is open to try all possibilities - you however, appear to squash any attempt at experimentation that does not support your cherished narrative, as you have just demonstrated with you reply #570 after Itsu put a slotted aluminum pipe in his grenade former tube.
img  NickZ
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #577 on: 2023-09-21, 17:19:02 »
   Verpies:
   Fine, I'll be waiting for the results.
For those guys that have been following up on what has and has not been done, won't need the "show me" attitude.
As they already know that what I mentioned is true. You obviously don't. So look for yourself, as I said, if interested.
 Not my job...to show you. You are not asking, you are demanding. So, good luck with that. Show yourself...
img  verpies
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #578 on: 2023-09-21, 17:48:48 »
Quote from: NickZ on 2023-09-21, 17:19:02
What guys ?  Anyone cares to speak up ?
Are you speaking for the silent majority ?  Is it an argumentum ad numerum ?
It is your job because, you made an unsupported blanket statement and I challenged its veracity.
So what? Authors of unsupported blanket statements deserve that, especially when challenged.
You do not have the right not to be offended.
img  NickZ
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #579 on: 2023-09-21, 18:09:09 »
   Verpies:
   If I were you, I would not come to my thread with your demands.
You may find that that will not work with me, and you may also find your posts "deserve" to be deleted, by me.
Understand???
So, don't push your luck, buddy.
img  verpies
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #580 on: 2023-09-21, 18:27:42 »
Quote from: NickZ on 2023-09-21, 18:09:09
You may find that that will not work with me, and you may find your posts deleted. Understand???
But if you delete my posts, I will just repost them so why not ban me altogether ?
Then you will have one less guy to challenge your beliefs.  You will be able to go around critiquing experiments that do not agree with your theory of operation. ...but wait, you don't have one, do you?
img  NickZ
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #581 on: 2023-09-21, 18:36:43 »
   Verpies:
    I hope that you have lots of time, but, I don't. So go for it, if you really want to be like this!!?
Ok, then. Bring it on...
   Those that bring shit to the table, will know what's for dinner.
   The only reason that I don't ban you altogether, is still unknown. Hoping that your attitude may improve, I guess.
I'm not your enemy. Tough guy...but, don't tell me what to do or any more of your insults. Prove me wrong...if you can.
 Or cut the personal crap...  that is not permitted here, or do you really want me to ban you altogether? It has taken some effort even to get you here, remember? I do want you here, so please stop this personal BS.
img  Classic
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #582 on: 2023-09-21, 20:52:11 »
@Nickz, I am sorry to bother you, but if you and others already have explored all ways, what would be your approach to go further ?
I wonder if you can imagine your setup (as you build it) as a cascade of self resonant transformers which just amplify standing waves and if wire length used is equal to 1/2 or multiple of wave length, corresponding frequency that you have at output of signal generator.
If everything is correct you just need to disconnect 1 wire to have standing waves in your primary. Have a look at Arie deGeus and you will understand what I am speaking about.
img  AlienGrey
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #583 on: 2023-09-21, 21:16:31 »
Quote from: Classic on 2023-09-21, 20:52:11
have you got a link ?  any way how can Nick have tried any thing if he and others don't have a clue about any thing to do with what they are looking for  :D
img  NickZ
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #584 on: 2023-09-21, 21:29:06 »
   Thanks AG:
    Good thing that you know how to build a self runner.
Perhaps you  would like to show us how well it works.
And perhaps you can also cut the personal shit, so I don't have more of your posts to have to delete.
  What a peanut gallery we have here... All I'm concerned about is tests and research towards a self runner.
Not this soap opera.
img  NickZ
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #585 on: 2023-09-21, 21:48:42 »
Quote from: AlienGrey on 2023-09-21, 21:16:31
  I am here to test and research this type of device. It is not easy pickings nor cheap fun.
But, there seams to be guys here that are into other aspects of this project. And keep bringing personal opinions as to my and others work, to disprove everything mentioned. As Verpies is trying to do, now. Not appreciated.
img  verpies
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #586 on: 2023-09-21, 22:28:58 »
Quote from: NickZ on 2023-09-21, 21:48:42
No it is you who is against any line of experimentation that does not align with you ephemeral preconceived notions about the operating principle of this device....such as the reactions in that slotted metal tube.
Why does it bother you so much that Itsu is trying something different than that which you've been trying unsuccessfully for years?
img  AlienGrey
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #587 on: 2023-09-21, 22:35:43 »
Quote from: NickZ on 2023-09-21, 21:29:06
   Thanks AG:
thanks for the encouragement but I'm not that stupid
img  NickZ
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #588 on: 2023-09-21, 23:37:16 »
   Verpies:
  Nothing that Itsu does bothers me. And, I understand his reasonings.
I wish that you would relax and get off my back though. Or are you getting off on this, sir??? You are being pretty rude.
And I would really like to get back to what I'm here for, without any further interruptions, or insults from you.
img  Maxolous
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #589 on: 2023-09-21, 23:59:31 »
Quote from: NickZ on 2023-09-21, 23:37:16
What is professor Nick here for?
img  NickZ
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #590 on: 2023-09-22, 00:08:17 »
  Keep guessing Max. Maybe some day you'll get it. But, I'll give you a clue, it's not fish waves, modulated waves,  split copper tubes, or shaking electrons loose, with HV, as you may think.
    What are you here for???  All you've mentioned and had itsu help you with has resulted in nothing, at all.
I am not blaming any one, but some are blaming me. For what???
   You want to play with split tubes now, well go for it. Don't mind me.
   Maybe Verpies will finally make something that will surprise us all, with his free energy ideas, after all these years.
    That was what I was hoping for, and was the reason I helped him get onto this thread. My mistake.
« Last Edit: 2023-09-22, 03:11:06 by NickZ »
img  Classic
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #591 on: 2023-09-22, 07:07:01 »
I will just ignore your mean comment. Please see attached screenshots.
A lot of people are afraid to use standing wave as mainstream science and education systems teach that we need to avoid them as they are dangerous and will destroy our devices or circuitry (which is true, if not correct use in a proper manner).
So, standing wave will double the voltage and adding more capacity to the capacitor next to unconnected end will double the frequency, facilitating more electricity extraction increasing efficiency.
We need to understand that there is no magic solution where something will just pour energy in our systems and we need to create more or stronger disturbance in order to let environment to match and balance, while we not going to let balance happening by harvesting what is added by environment … to get a continuous supply for as long as we maintain excitation/disturbance.
I hope this is add some clearance and help.
Later edit: this little trick is so easy to hide in Don Smith, Kapanadze etc were a fake connection is shown.
    img  verpies
    Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #592 on: 2023-09-22, 10:07:46 »
    Quote from: NickZ on 2023-09-22, 00:08:17
    You asked for it, so there you go:
    I am blaming you for your reply #570 which contained unsupported assertions designed to dissuade Itsu  (and others) from experimenting with a different component set than that which you have been experimenting unsuccessfully for years.
    I am also blaming you for promoting builds that are not guided by some operating principle and for promoting replication-by-imitation from info-deficient videos without M.O., instead.
    I am blaming you for not spelling out a concrete logical operating principle to guide your builds (however contrived), while outright rejecting operating principles and details proposed by others WITH PREDJUDICE, such as:
    fish waveforms,
    modulated waveforms,
    nanosecond pulses
    picosecond pulses
    static magnetic fields
    standing waves,
    split metal tubes,
    McFreey's M.O.
    accelerating electrons or ions with HV
    etc...
    ...especially when these rejections are based on your feelings and without logical analysis and supporting evidence.
« Last Edit: 2023-09-23, 03:49:25 by verpies »
img  Classic
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #593 on: 2023-09-22, 10:16:50 »
Quote from: verpies on 2023-09-22, 10:07:46
0
I am blaming you for your reply #570 which contained unsupported assertions designed to dissuade Itsu  (and others) from experimenting with a different component set than that which have been experimenting unsuccessfully for years.
I am also blaming you for promoting builds that are not guided by some operating principle and for promoting replication-by- imitation from info-deficient videos without M.O., instead.
I am blaming you for not spelling out a concrete logical operating principle to guide your builds, while rejecting  WITH PREDJUDICE operating principles proposed by others such as:
Ladies and gentlemen, please stop this silly blame of each other. Try to understand that sometimes we are unable to describe a method that only exist in our mind, i know there is a lot of frustration especially when no goal achievement but would be a destructive to start blaming each other for something that those involved in a project do not understand. I think a flexible approach is desired and patience as nobody can splash the cash with unsatisfactory results.
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-04-01, 01:22:36
