2025-04-01, 01:22:29
Pages: 1 ... 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 34 35 36 37 38
Author Topic: Don Smith Akula, Ruslan, Stalker, device discussion and replications.  (Read 68278 times)
img  NickZ
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #508 on: 2023-08-17, 14:15:05 »
     AG:
    You have your own  Don Smith thread, so please compare Don Smiths ideas, there.
  Ape has not shown anything new and working.  So, I think that he has nothing to show.
« Last Edit: 2023-08-18, 15:23:51 by NickZ »
img  NickZ
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #509 on: 2023-08-18, 15:21:10 »
   AG:
   If you don't like the way that I run this thread, then don't post here.
   If you keep up your insults and distractions you will be moderated. Got it!
Same with Max.
  EDIT: today Fri Aug 18
   Thanks Grum, the same thing that happened with you, now happened to me. Sorry about that...
I removed a POST, and do not know how to even remove a thread. The system may have done the rest.
    And no AG, I did NOT ever ask the admin to remove the thread, either.
   Thanks again Grum
   Cheers,
« Last Edit: 2023-08-18, 16:52:03 by NickZ »
img  Grumage
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #510 on: 2023-08-18, 16:36:10 »
No problem Nick…. O0
However I don’t think you’d have been asleep at 6PM. The forum clock is running @ GMT or UTC and at this moment I’m ahead of it by 1 hour as we’re currently running in BST ( British summer time ) I believe that you’re 6 hours behind me.
img  NickZ
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #511 on: 2023-08-18, 16:46:37 »
   Yes, Grum I was awake at 6 Pm. And did remove a post, not the entire thread, as far as I know.
In any case I'll take care of watching out for that in the future. Now that I can see that I have somehow removed the entire thread, without knowing it. My apologies to all.
  Still learning how this forum works...
« Last Edit: 2023-08-19, 23:22:43 by NickZ »
img  Grumage
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #512 on: 2023-08-20, 19:57:28 »
Sorry Nick that’s outside of my moderation access. Verpies will have to get in touch with admin.
Nanny state ? Left at the gate !!
img  Chet K
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #513 on: 2023-08-20, 20:22:52 »
Sorry I just noticed comment
Peter will look into this tomorrow after work
Verpies should also send a note
img  NickZ
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #514 on: 2023-08-20, 21:01:43 »
    Ok, guys,  thanks for the help.
img  NickZ
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #515 on: Today at 17:23:37 »
   Guys, let me know if you can post now.  Verpies,  and anyone else.
I have unlocked this thread now, so it should be working.
  I don't know what is going on, so please excuse any confusion.
img  verpies
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #516 on: Today at 17:57:23 »
Quote from: NickZ on Today at 17:23:37
Note from  Verpies, I can post now
« Last Edit: 2023-09-02, 11:41:12 by AlienGrey »
img  AlienGrey
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #517 on: Today at 18:37:59 »
Quote from: forest on 2023-07-17, 20:37:42
I didn't mean to disturb but had a flash of idea looking at this patent : what if our Akula, Ruslan, Stalker or similar device is just an antenna capable of retrieving electrostatic energy from air at high rate, what if there is no necessity to go up in elevation like Tesla once said but to construct proper antenna with proper electronic switch ?
Note from Sil
What if it's not ?
« Last Edit: 2023-08-22, 14:56:23 by AlienGrey »
Note Nick has since deleated all his posts and thread this last week.
If any one has any deleted posts they can repost please do so here, Regards Sil
I have managed to recover some posts and repost here please check.
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #505 on: 2023-08-15, 17:46:17 »
  AG:
  How can you tell if the driver is used "correctly"?
  Does he show it self running, while connected to a scope? Or the results at the output?
img  AlienGrey
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #506 on: 2023-08-15, 18:30:58 »
Quote from: NickZ on 2023-08-15, 17:46:17
  AG:
the scope shot can be seen that the data window is in phase with the data window width timing width slot
and the VFO katcher drive frequency.
You might notice the null part makes use of one of the 494 phase output FET drivers unlike the PLL Itsu is showing.
In witch his 494 is run in a slave mode and phase correction might well be rewired due to internal device delays.
That's what it does and it's doing it in that scope shot.
Re asking Igorik for demonstration he is in the spirit world, Or ask Vasik041 for details or a pointer to the original
img  NickZ
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #507 on: 2023-08-15, 20:17:43 »
   "That's what it does", does not answer the question. Nor that's what it did, at one time.
What does that do at the output, once disconnecting the supply feed? Or are scope shots enough to know if that circuit allows " correctly" for self running. Scope shots are great,  but don't tell the whole story. And we've seen a lot of scope shots, but not a single self runner.
« Last Edit: 2023-08-15, 22:21:03 by NickZ
img  NickZ
     AG:
img  NickZ
   AG:
Same with Max.
   Thanks again Grum
   Cheers,
img  Grumage
img  NickZ
img  Grumage
img  Chet K
img  NickZ
img  NickZ
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #515 on: 2023-08-21, 17:23:37 »
img  verpies
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #516 on: 2023-08-21, 17:57:23 »
Quote from: NickZ on 2023-08-21, 17:23:37
I can post now
img  AlienGrey
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #517 on: 2023-08-21, 18:37:59 »
What if it's not ?
img  verpies
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #518 on: 2023-08-24, 17:09:52 »
Quote from: NickZ on 2023-08-14, 14:51:05
Why are you wanting to lock the frequency?
I don't think he does.  He's just exploring the detail suggested by someone else.
It is as if I told him that this device must have a thick-walled slotted aluminum tube inside the coils to work and him exploring this detail despite not being the author of it.
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-04-01, 01:22:29
