2025-05-17, 23:37:28
Pages: 1 ... 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
Author Topic: Don Smith Akula, Ruslan, Stalker, device discussion and replications.  (Read 75128 times)
img  Maxolous
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #406 on: 2023-07-15, 07:43:10 »
Quote from: AlienGrey on 2023-07-15, 06:17:14
Itsu & Nick so lets ask a question are you ignoring some thing or doing some thing arse about face ?
I mean water looks like petrol hmm but would it power my fuel burning devices ?
think about it.
AG,
Phase is everything.
When we adjust Tesla length, we are trying to match phase angle of Tesla with grenades phase angle such as nodes to nodes, anti- nodes for anti-,nodes in their multiple proportion. This is one reason we shift pulses in controlled Tesla , phase lock in other ccts like suggested by " AG" and adjusting Tesla wire length in simple kacher.
img  Itsu
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #407 on: 2023-07-15, 10:04:41 »
Quote from: NickZ on 2023-07-14, 23:12:35
   Itsu:
   Thanks for the info.
   My kacher also runs at around 1,1MHz. So, not too far off...
   Interesting that your 37.5 meter kacher secondary runs best at 2MHz, by itself.
  Stalker mentions that everything needs to be tuned to the 37.5M grenade. Why, I don't know, yet.
Including the kacher frequency to match the antenna coil frequency. But you find that that may not be possible?
Maybe a different harmonic is needed, instead?
  I'm still trying to understand why what Stalker says does not compute. Hard to get anywhere like that...
Nick, what i find interesting is that my working frequency (2715kHz without antenna) when in a kacher circuit is somewhat close to the calculated value (3163kHz) of a secondary as caluclated by that java calculator here:
https://www.overunityresearch.com/index.php?topic=4471.msg105505#msg105505
But that the free standing resonance of 2054kHz (pinging it with a loosly coupled square wave and measuring the ringing with an attached probe) is so much lower.
I guess the probe (3pF / 10M) is loading it that much to cause that.
The antenna has a big (capaitive) influence on the kacher working frequency causing it to further drop in frequency (1160kHz) and thus totally disturbs the 37.5m length resonance frequency.
So to me this means that the 37.5m lengths as mentioned are just a starting point or reference point for building the coils (it also could have been any other random taken length IMO).
img  NickZ
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #408 on: 2023-07-15, 16:41:56 »
   Itsu:
   We have to keep in mind that neither Akula, Ruslan, or Stalker are experts in this field.
And what they thought and mentioned about all this, may just be only their guesses, at the time, instead of fact.
   Max may still be under the impression that he needs to add more high voltage and frequency to see any interaction.
But, as I mentioned, this is not a matter of adding high voltage to low voltage, this an INTERUPTION circuit. Nor will he see any useable interaction when placing 500 watt loads on, at all.
And needs to utilize the BEMP to vibrate the surrounding ambient. Without which no extra energy will be found. As we have all seen. No matter how much more voltage you give to the kacher circuit, put a real load on the grenade output and there goes any previous false interaction. You don't believe it, try showing what that interaction can do to the bulb at the output, at higher wattages.
  There are such things as real fish waves forms, as was shown by my uploading of Stalkers scope shot, not the fake scope produced ones, but the real ones, instead.
  So, now we know that the fake fish forms produced by the scope are nothing at all. As well as the "modulated" scope artifacts, produced by placing the unconnected scope probes next to the grenade. That was never the way to measure the two wave forms signals.
  We already have a 37.5M grenade, a 18M inductor, and an Earth ground line matched to 37.5, or 18M lengths. I believe those things are what are really needed, to start with.
« Last Edit: 2023-07-15, 19:56:50 by NickZ »
img  AlienGrey
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #409 on: 2023-07-15, 19:59:02 »
Nick the main thing I notice is this
Quote Nick
End quote
so have you actuly got 18 meters on your inductor winding ? So where did you see
to wind that amount for the inductor ?
Reply from Nick
  AG: Well, I tried the 1/4 size (9 meters), first. Then  I built the inductor to the 1/2 size, 18M, and it worked better, for me.
  So yes, I have an 18M inductor.
  As far as how do I know to make the inductor that length, I follow the schematics and follow the instructions. Sometimes...
« Last Edit: 2023-07-15, 21:27:02 by AlienGrey »
img  AlienGrey
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #410 on: 2023-07-15, 21:46:34 »
One other thing I did notice on the Tesla coil we found on the internet is all pick up is done
along the length of the tube and the other thing is Nelson R commented on this factor
5 or 6 years back he said it was energy was being thrown out along the tube length
into the environment wasted.
img  NickZ
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #411 on: 2023-07-16, 00:40:39 »
  Yes, but it can also be used to make free energy. Instead of wasting it.
   But, these are not like any other devices. These self runners.
   Nelson's rigs could not self run. I guess that's why he gave up on it. Like everyone else.
img  Classic
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #412 on: 2023-07-16, 11:25:04 »
I’m not sure that that principle is understood ? We need to connect 2 fields of the same kind that have a potential difference which we are going to exploit. Everything in universe is self balanced, so on our planet. Create a fight between those 2 identified fields, amplify only 1 side using materials properties while make sure the other side have a clear large path to bring its force to fight. Collection must happen on the side where we don’t intervene. Our collection is just a diversion path as nothing will be created or destroyed.
Keep it simple. The more transformation we bring to the system the more headaches.
If this post is considered off topic should be deleted and I apologise for inconvenience.
img  Classic
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #413 on: 2023-07-16, 13:03:37 »
Quote from: NickZ on 2023-07-16, 00:40:39
What is the reason to make it self run ? Would this change your perception about FE ? Do we need to make, let’s say, a hydroelectric generator self running ?
I just wonder if we fell into FE suppressors trap so often and so easy ? Huh
I can't help you if you don't know or care about the benefits of a free energy device.
So just keep paying your bills...
I just used bold to highlight your edit to my post …
« Last Edit: 2023-07-16, 15:00:29 by Classic »
img  NickZ
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #414 on: 2023-07-16, 14:44:28 »
   I can't get out of the previous post box, like I could before.
   Sorry about that.
img  AlienGrey
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #415 on: 2023-07-16, 15:18:22 »
Quoe from Nick
 Itsu:
End of quote
 I have one like that (some where stored) i used .8 en copper with .7mm fishing wire between
turns simple and 18.7m mtrs on 5 cm dia tube
img  forest
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #416 on: 2023-07-16, 18:36:28 »
Maybe it's simpler then we thought ?  https://patents.google.com/patent/US11588421B1/en
img  stivep
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #417 on: 2023-07-16, 20:37:14 »
Quote from: forest on 2023-07-16, 18:36:28
thank you forest.
I explained some  of it if you are interested. here: https://overunity.com/17735/kapanadze-and-other-fe-discussion/msg580252/#msg580252
Re: Kapanadze and other FE discussion
Wesley
img  Classic
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #418 on: 2023-07-16, 21:32:49 »
The only thing the this scammer did is replacing an elevated plate with an erected pole … I wonder if US office patent is prepared to have 1 million patent request per week s I’m planning to ask for a patent for every bit on Wikipedia as this muppet did. And I expect to have al requests approved on the spot. If you look up who is this muppet you’ll find out as he tried to scam Nike in the same way and he lost all his claims in court.
Would be interesting to find out who’s holding the strings of this muppet.
img  stivep
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #419 on: 2023-07-16, 22:17:41 »
Quote from: Classic on 2023-07-16, 21:32:49
Talking about the patent application posted by forest:
I feel great discomfort due to  your  words
It was a child not a scammer. Patent was filed with help of his parents.
look here :
https://overunity.com/17735/kapanadze-and-other-fe-discussion/dlattach/attach/192226/image//
 and I was surprised - it was ~4 years old boy. today this kid is ~8 years old
https://d10j3mvrs1suex.cloudfront.net/s:bzglfiles/u/552148/5651d97622e84dc5f8bd23134d35ffaaa53f886e/original/rob-and-kieran-santa-monica.jpg/!!/b%3AW1sic2l6ZSIsInBob3RvIl1d/meta%3AeyJzcmNCdWNrZXQiOiJiemdsZmlsZXMifQ%3D%3D.jpg
of course we don't know how old was the picture .
I hope it helps
Wesley
« Last Edit: 2023-07-17, 02:59:24 by stivep »
img  NickZ
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #420 on: 2023-07-17, 01:16:14 »
   Guys:
   This is not a rants thread, so please stay with the topic of this thread.
img  stivep
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #421 on: 2023-07-17, 13:46:16 »
Quote from: NickZ on 2023-07-17, 01:16:14
I absolutely  agree with you.  Thank you for that comment.
Corrected :
Forest delivered  solution proved to be right:
https://overunity.com/17735/kapanadze-and-other-fe-discussion/msg580256/#msg580256
in accumulation of energy from lightning  by slowing it  down..
we deal with electrostatic energy triggered by lightning  or e,g. atmospheric 1V
that uses e.g. wind powered  interrupter-switch( look at video there ).
Constant current of  0.1Ax10000V=1000W in its form can be in a constant discharge into .....energy storage and processing.
For 10kV we need 100m hill and some  easy trick.
Look at 30 seconds of this video: https://youtu.be/2rVdEhyMR6A?t=111
Kapanadze and his first replicator  SR used weak spark and ground wire, so was Akula, Ruslan. Stalker.
It is inflammatory or aggressive or insulting sight kicking  triggered by member "classic"  that makes audience  reaction  defocused.
Wesley
« Last Edit: 2023-07-17, 18:15:02 by stivep »
img  NickZ
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #422 on: 2023-07-17, 15:28:26 »
   Wesley:
   My comment was mainly directed at you. As we already know that you like to write long essays about yourself and your dealings in Russia and other Slavic countries. However if you do this here again, you will be moderated. And any one else that is here to rant. We've heard it all many time before...And I asked you nicely, and you keep it up.
  This is a research and development thread concerning Akula, Ruslan, and Stalker replications. Got it...
   Glad that you "absolutely agree" with me
img  forest
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #423 on: 2023-07-17, 20:37:42 »
I didn't mean to disturb but had a flash of idea looking at this patent : what if our Akula, Ruslan, Stalker or similar device is just an antenna capable of retrieving electrostatic energy from air at high rate, what if there is no necessity to go up in elevation like Tesla once said but to construct proper antenna with proper electronic switch ?
img  verpies
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #424 on: 2023-07-17, 22:42:20 »
Quote from: Maxolous on 2023-07-13, 19:06:39
I have seen your cct. but ity not 4046 as described.
Is the 4046 PLL circuit supposed to affect the push-pull's frequency and phase ?
page 18
img  stivep
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #425 on: 2023-07-17, 23:04:29 »
Quote from: forest on 2023-07-17, 20:37:42
I didn't mean to disturb// what if there is no necessity to go up in elevation// with proper// switch ?
Comfort of  Voluntary contributor needs not to experience scrutiny but evaluation.
Lightning as an electrostatic charge created at equipotential of 1km+  that reaches medium ionization level  evaluated
in relation to associated EM at TM mode, based on denoted 1936, Seneca Lake Experiment  repeated in 2013 and later in 2017- stands now for results  published by Sommerfeld.
The electrostatic pump as whole  e.g. from application  https://www.nuenergy.org/uploads/Plauson-GB157263-6.gif
used  in evaluation of SW energy extraction in relation to  Kapanadze and/or replicators, subject needs clear conditions for me to fallow
mainly- does electrostatics and EM  as well as  propagation fit within the boundaries of this discussion?
img  Paul-R
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #426 on: 2023-07-17, 23:16:58 »
Quote from: stivep on 2023-07-17, 23:04:29
Wesley
Anything that propels us towards inexpensive Putin-free energy for next winter deserves space either here or in a new thread.
img  stivep
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #427 on: 2023-07-18, 00:39:09 »
Kapanadze and/or listed  replicators, optimal applied conditions tested at 18.6KHz for representing at OUT 50 Ohm as a Standard (30 Ohm for power handling and 70 Ohm for loss.)  requires
Impedance Match:
Matching transformer, Transmatch / pi/t network tolerating V/SWR 1:1 ~ 2.5 that compensates  energy transfer between an electronic circuit source and load
(or in case of energy conversion between source - conversion device  -load) if not applied or not tuned to impedance of DUT by experimenter, causes negative outcome (or testing failure.)
For past 15 years not discussed widely or at all in dedicated  forums.
F of Test  in both Rx and Tx is low ( applies not only  to generators / filters Tesla Coils, Air and/or ferrite based transformers etc.)
-above requirement is a must at any frequency.
Successfully applied in projects handling most of Tesla coils as well, inexpensive now commercial PLC typically present at 500kV - equipment .
https://overunity.com/17735/kapanadze-and-other-fe-discussion/msg579717/#msg579717
https://overunity.com/17735/kapanadze-and-other-fe-discussion/msg579721/#msg579721
e.g of focused educational material reg. to  impedance :
https://kaizerpowerelectronics.dk/tesla-coils/drsstc-design-guide/secondary-coil/
Note: avoid  spark loading if you can unless required by application.-TK design should be  seen as Rx !
http://tuks.nl/pdf/Reference_Material/Johnson%20-%20Tesla%20Coil%20Impedance.pdf
spec sheet  is here:
http://www.signalcrafters.com/Files/Model%2070.pdf
http://www.signalcrafters.com/Files/Model%2060.pdf
http://www.signalcrafters.com/Files/Model%20SC30%20Manual.pdf
https://signalcrafters.com/Files/Model%2090.pdf
https://signalcrafters.com/Files/Model%2090A.pdf
http://www.signalcrafters.com/Files/Model%20110%20Short%20Form.pdf
All of them personally tested as  general solution to testing apparatus.
Bench technician comment: "nothing more I need  now."
Note: S parameter with VNA can be  discussed upon request.
Note: inexpensive EU and  GDR/Russian based equivalent of mentioned above also tested and used in  lab
         can(but don't have to) be discussed  in next comment.
Wesley
« Last Edit: 2023-07-18, 02:18:13 by stivep »
img  AlienGrey
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #428 on: 2023-07-18, 02:39:38 »
Quote from: verpies on 2023-07-17, 22:42:20
Why would you think that ?
I think the idea is to sample the the i leg of the push pull and use the vfo in the 4046
to drive the kacher at 50 times the speed of the pp, thus locking phase and frequency
in a tracking mode it would be quite easy to do so.
img  Maxolous
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #429 on: 2023-07-18, 07:52:22 »
It's not supposed to  effect the Push-pull and phase but to register it operation and make the Tesla resonate in it multiple   proportion with regards to Push-pull's nodes  to Tesla's nodes . This also means aligning the phase angles of both Push-pull and Tesla's.
" Phase lock"
img  Itsu
Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #430 on: 2023-07-18, 10:23:33 »
There were some attempts in the past for the current and the voltage phases from the series LC in the inductor circuit (3 turn secondary / Wima cap) to stay in phase with each other (thus in series resonance) using a 4046 PLL circuit (pushpull / synchronizer) discussed from here: https://www.overunityresearch.com/index.php?topic=3926.msg90986#msg90986
I guess verpies is pointing to that.
Max is talking about phase locking the Push-Pull signal with the kacher signal i think.
Itsu.
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-05-17, 23:37:28
